Show your French bikes!
#3826
Bad example
Quoted: 847 Post(s)
Liked 263 Times
A circa 1975 Gitane Fédéral with 531 tubing, which I built from the frame up.
Likes For Aubergine:
#3827
Bad example
Quoted: 847 Post(s)
Liked 263 Times
1988 Peugeot Sante. Light, stiff, and functional. The photo shows the bike as bought; I added proper pedals and swapped out the seat for a white Terry that fits me better yet conforms to the style of the bike.
Catalog is here: https://www.bikeboompeugeot.com/Broc...20Page%205.jpg
Edited to add a photo of the bike as I have set it up. Terry saddle (which I need to clean, ahem) and Speedplay Frog pedals.
#3828
Bad example
Quoted: 847 Post(s)
Liked 263 Times
1972 Motobecane Grand Jubile. Another bike that I built from a repainted frame, using parts that I preferred. The bike is a bit too big for me but rides very well.
The bike is next to the Canal between the Aisne and the Marne, a few KM from Reims.
#3829
Bad example
Quoted: 847 Post(s)
Liked 263 Times
Follis 172 circa 1973. I built this from the frame with some original parts. Three tubes Reynolds and a superb ride, comfortable yet controlled. Since I took that picture I put on a Nervar crank, as would have been original on this bike.
#3830
Bad example
Quoted: 847 Post(s)
Liked 263 Times
Another old Pigeot, also modified here and there.
#3831
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1301 Post(s)
Liked 942 Times
That looks really super. When did you paint it, and is that a 30T inner chainring? Good job!
"In every job that must be done, there is an element of fun. You find the fun, and - SNAP - the job's a game!"
#3832
Bad example
Quoted: 847 Post(s)
Liked 263 Times
I had it powder coated some years ago . . 2018? The chainring is 26. I am a wimp. But seriously, the bike is amazingly nice. Very comfortable with the long wheelbase and 42mm tires, yet with a sporting feel that encourages you (well, me) to press onward.
#3833
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 671 Post(s)
Liked 985 Times
#3834
Steel is real
Quoted: 671 Post(s)
Liked 985 Times
#3835
Bad example
Quoted: 847 Post(s)
Liked 263 Times
My ride today, a 1973 PR 10. Three tubes Reynolds, lots of decent but heavy parts compared to a PX. It is twitchier and less compliant than my Follis, which is also 3 tubes Reynolds. One of these days I am going to put a Reynolds fork on this beast to see how it affects the ride.
The bike is original except for the shifters, which were added by the original owner, and the Delrin brake levers, which I replaced with Weinmanns.
#3836
Bad example
Quoted: 847 Post(s)
Liked 263 Times
#3837
Standard Member
Liked 942 Times
I have been in touch with the French consulate, and they say you are not a whimp. If you ever find yourself in dirt, or decide to go touring, you will be glad you have that 26T. I have a 30T on the inside chainring on my Manufrance's Nervar triple. I've always been partial to the UO8. That is a great color.
Likes For 1989Pre:
#3838
Bad example
Quoted: 847 Post(s)
Liked 263 Times
#3839
Bad example
Quoted: 847 Post(s)
Liked 263 Times
1971 PA 10. The frame uses Peugeot's Cadre Allégé (Light frame) tubing, which is rather a misnomer, but it does make a bike that is pleasant to ride. The bike is a lower end race bike with cottered steel cranks and other heavy bits, but with sewup tires standard. This inexpensive boy (or girl) racer was a common type of bike in the early 70s. And to be honest, the bike is a delight to ride. I've put fat Veloflex sewups on the bike, and it just rooooolls. Fun!
It is entirely stock except for the brake levers. The originals had white Delrin bodies that were starting to crack, so I replaced them with Weinmann levers.
#3840
Bad example
Quoted: 847 Post(s)
Liked 263 Times
1962 Peugeot AO-8. It has the original white Delrin Simplex derailleurs. Note that the rear derailleur does not have the metal box that stiffened the Delrin for later versions. The paint is badly worn; I think it spent too much time in a damp garage near the ocean and suffered from the salty wet air. The photos show guidonnet brake levers, but I could not get used to them and swapped in a pair of Mafac levers with the extra "safety" levers.
The bike has original steel wheels so I don't ride it unless the weather is sunny and dry. I usually keep it on the local trails, where it is quite pleasant. Even the derailleurs work well enough to keep me satisfied!
#3841
Bad example
Quoted: 847 Post(s)
Liked 263 Times
Here are a couple yellow 'bécanes from around 1973. First up is a Mirage, totally stock save for the addition of toe clips. Second is a Grand Touring, which I built up from a bare frame. Both bikes used 1020 high-ten steel and had similar riding characteristics. They were not stodgy but were steady and substantial. I preferred the happier presence of my Peugeots, and these frames were a bit too big for me, so is passed them on to other riders.
The Mirage:
When I got this bike it still had the original Hutchinson tires and tubes! They were too badly warped from disuse to keep, alas.
The Grand Touring:
The Mirage:
The Grand Touring:
#3842
Bikes: Motobecane C41, Matsu$hita Nashonaru
Quoted: 215 Post(s)
Liked 438 Times
The Mirage:
The Grand Touring:
The Mirage:
The Grand Touring:
Likes For VintageSteelEU:
#3843
Bad example
Quoted: 847 Post(s)
Liked 263 Times
Yes, i also have a Grand Jubile with three tubes 531 and it is a very nice bike. Still too tall for me but I ride it when I am in Reims. I posted about it above.
#3845
My old LEJEUNE Stayer bike that I sold. I alway wondered if it was a real French LEJEUNE since it had 2 holes for a head badge (decal covered up the holes)
Likes For 1oldtrackie:
Likes For FrankScott:
#3847
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Quoted: 351 Post(s)
Liked 606 Times
Likes For browngw:
#3848
Bikes: Still have a few left!
Quoted: 467 Post(s)
Liked 540 Times
PX10, Stella, a Gitane Super Grand Sport given to my Grandaughter, + another setup of same PX10
PX10
Stella Series 70
Stella
1969 PX10
PX10
Stella Series 70
Stella
1969 PX10
Likes For ollo_ollo:
#3850
Quoted: 467 Post(s)
Liked 540 Times
PX10 Detail Post 2019 Cino Montana Ride
