Two people on top of a hill?
Quoted: 18883 Post(s)
Liked 10,646 Times
Bikes: 2006 Raleigh Cadent 2.0, 2016 Trek Emonda ALR 6, 2015 Propel Advanced SL 2, 2000 K2 Zed SE
Quoted: 115 Post(s)
Gravity (g = 9.81 m/sec2) is really the same for heavier and lighter riders. At high speed descent, lighter riders tend to experience a higher wind resistance (per unit weight). As a result, "net acceleration" going downhills (gravity - impact of wind resistance per unit weight) favors the heavier riders.
G is constant, distance from the center of the earth (r) is the same, and unless a huge amount meteors strike between the two riders setting off, the mass of the earth isn't going to change. The gravitational constant won't change. The heaver rider in the OP's example will have more force applied. 1 + (0.673x10-24) times as much, I think. Not at all an insignificant amount if the rider already has shaved legs and an aero stem on their bike. The ratio shouldn't change much as they descend, but the force will (at least until they reach the center of the earth), so the force difference gets even bigger. By bigger, I do mean really, really, really small but relatively larger...
I'm sure, given enough computing power we can figure out how much more the bigger rider affected the earth's orbit climbing the hill in the first place than the lighter one.
I may or may not be torturing Newton a bit here, and I probably made an arithmetic error somewhere.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
For example even in this discussion, which granted should be simple and correct in layman's terms, people have explained the factors of weight and wind resistance, but no one has mentioned the effect which is likely the larger part of heavier guys going faster down the bigger hills. More than the greater acceleration of the bike; it's the greater terminal velocity that will make more difference. The top speed we will attain coasting depends on weight and drag. Acceleration is how fast we get to that speed.
I don't know why you attack his second paragraph, answering his question, as yakety-yak. The first maybe, I won't comment, but the second was OK IMO.
F = G * ((m1 * m2)/r^2)
Lol
Stoke's Law (usually used for particle settling velocity in viscous liquid) can also be somewhat applied here.
Terminal Velocity is proportional to R (radius)^2
Bigger riders (assume all other factors are the same, such as density, aerodynamic position...) will likely to reach a higher terminal velocity than smaller riders.
Quoted: 507 Post(s)
Liked 237 Times
What about the increased friction and tire deflection for the heavier rider?
Also, what if we ask the question "who reaches the bottom first?"
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
in bagnomaria
Quoted: 1422 Post(s)
Liked 7 Times
Okay you have two people on top of a hill on identical bikes. One person weights 100 lbs while the other weights 200 lbs. If all things were equal and they costed down the hill would they both go the same speed?
If they both exerted the same amount of energy would they go the same speed?
Why is it when I am going down hill with my 200 lbs it appears I am going faster than everyone else?
They only fall at the same speed in a vacuum.
So put the 2 riders in a vacuum at the top of the hill. Give the big rider the bowling ball and the smaller rider the feather. Then let them cost down. They will cost at the same speed until they pass out from lack of oxygen and loss control of the bicycles. Also their heads might asplode in a vacuum.
Science is fun, but dangerous sometimes. Can't be helped.
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
So a 5% grade = 5 down for every 100 run.
The Sin is that 5/the actual distance, which is almost the 100 (which works for 99% of the cases) but exactly 5/(5^2+100^2)^.5 or the Square Root of 10,025 = 5/100.12. Or .04993.
Multiply that by mass and gravity where you are ~9.8 and you get the force pushing you on the road.
It is proportional to mass. The more massive rider will have a wee bit more friction and more aero resistance in total. But the increased force makes up for it.
Liked 10,646 Times
But what if there's a McDonald's on the way down the hill and they're having a sale on fries? Skinny rider gets to the bottom of the hill first every time.
Quoted: 6556 Post(s)
Liked 58 Times
Times the Sin of the angle of the road. I am leaving units out.
If it weren't for the wind resistance (and friction), you would never have to consider the mass and resultant force. Acceleration from gravity alone would define the situation and all masses would descend at the same rate. You only have to calculate the force in order to subtract the force of the wind (and that small amount of friction again) from it. Then when you divide this net downward force by the rider/bike mass, you get the actual net operating acceleration. That determines the speed after a time. So it is more like knowing the net force, you divide by mass to get the net acceleration, not so much that you find the force by multiplying acceleration by the mass.
Of course the descending angular effect on the acceleration is a given.
Liked 371 Times
Of course it was not exact. I didn't even give units. I gave only the component of force from gravity making the rider go. The wind resistance does not care about the grade. A very wee bit the friction does care as there is less force on the bearings the steeper the grade.
Quoted: 507 Post(s)
Liked 237 Times
Totally, absolutely wrong. What if the fatter guy has a giant non-aerodynamic beard and is more into avocado toast and beer rather than fries? Oh, and they're both on fixies?
Sr Member on Sr bikes
In your "all things being equal" consideration...does that include identical tires, and equal inflation, on all bikes?
One thing that I didn't see any of the egghead formulas include is rolling resistance of the tires involved.
Bicycle Rolling Resistance | Rolling Resistance Tests
Dan
Dan
Liked 58 Times
Dan
Dan
pan y agua
Quoted: 1451 Post(s)
Liked 731 Times
Dan
Dan
I'll leave it to our geek friends to give you the numbers, but real world observation easily confirms this.
You could get lost and die.
You could hit a tree and die.
pan y agua
Liked 731 Times
And if you want to see something go down hill fast, follow us, 350lb tandem team with pretty good aero position. We fall like a rock.
Quoted: 4260 Post(s)
Liked 1,364 Times
So, a 200 lb person is providing 2 times the energy as the 100 lb person (this is important).
In air, some energy has to be spent in moving the air away (air resistance) (this is the missing piece). You know that a more streamlined car uses less gas (energy).
As it happens, the 200 lb person and the 100 lb person have nearly the same aerodynamic shape*.
That means the energy taken away by air resistance is the same for both people.
Since the 200 lb person has twice the energy, he has more energy left over after the energy loss due to air resistance (which is the same for both). Which means the 200 lb person is faster down hill (because he has more energy left over to move him).
(After taking the loss energy due to air resistance, the energy/pound available for moving is larger for the 200 lb person.)
* The aerodynamics of the 200 lb person might be worse but it's not different enough to matter.
Rubber side down
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 225 Times
For me, going faster on descents because of size is simply confirmation that God loves me and is pleased with me for hauling my fat butt up the hills...
For Taylor Phinney, it is the karma compensation for the injustice of being a prodigy junior racer and growing to over 6'-5".
Bikes: Specialized Roubaix, 2011 and 2017
Quoted: 165 Post(s)
Are we talking about a name-brand hill that has been wind tunnel tested, or an open frame hill sourced from a questionable factory?
