Looking for inexpensive way to add a water bottle.....
Half way there
Quoted: 990 Post(s)
Liked 884 Times
This was the method of attaching a water bottle cage to the frame, either seat tube or cross tube, in the 60-70s. Even top of the line bikes used this method.
Water Bottle Mounts
Water Bottle Mounts
Quoted: 346 Post(s)
Liked 398 Times
ZEFAL pulse Universal Mount Bottle Cage with Velcro Strap
UPC Code 7 68661 55039 4
Cost is about $8.50 and it is typically found inside Walmart and Target stores in my area
This is a great simple way to add a bottle cage mount on to any bicycle without existing cage mounts.
I have installed more than a twenty of these on to vintage bicycles BUT I SHOULD WARN YOU THAT
FOR PERFECT, NO WORRIES, FLAWLESS OPERATION, You need to use 3M SuperWeatherStripping Adhesive
so that the bottle cage does not wiggle/slide around/slide down.
You can purchase a small tube of 3M SuperWeatherStripping Adhesive at any Auto Parts Chain Store (Auto Zone, Advance, O'Reillys, NAPA, Pep Boys...etc)
Advanced Slacker
Quoted: 2764 Post(s)
Liked 2,537 Times
The Minoura handlebar mount Is cheap (about $10) and effective. It fits diameters from 22mm to 35mm.
Quoted: 1324 Post(s)
Liked 927 Times
Cheers
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times
Start with two big bottles to begin with, and it might help. The Zefal magnum, the newer model, holds 32oz. Two of those can get me 60 miles.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
That's a picture from Amazon, so I don't know if there are steering issues with that setup. Very short stems might be problematic with those bags, but I've never heard of anyone complain about that.
Liked 927 Times
Cheers
Quoted: 722 Post(s)
Liked 353 Times
I've been up and down on Google and Ebay, till my eyes crossed, and figured I'd better just consult The Matrix here.
I ride in a rural area, with water sources relatively few and far between, and with summer coming on, I'd like to add a small water bottle, either on the seat post, or more preferably, on the handle bar.
I found a inexpensive, decent-looking clamp on ebay, but it looked to be too small for my 31.8mm handlebars.
I figure there's gotta be some decent, cheap options out there, but I'm not seeing them. As always, any help, advice, warnings, points-in-the-right-direction,etc, are all much appreciated.....
or seat bag with bottle holder.
A pair of stainless steel hose clamps with some inner tube to protect the frame.
Quoted: 1364 Post(s)
Liked 1,686 Times
If you are running a dehumidifier on your bike it should be pulling about a liter of water out of the air an hour, depending on the climate. Wouldn't that obviate the need for additional water bottles?
Quoted: 1463 Post(s)
Liked 1,488 Times
This doesn't specifically address seat post or handlebar mounting, but Wolf Tooth makes a system that allows you to connect multiple bottles to a single set of frame mounts.
https://www.wolftoothcomponents.com/...s/b-rad-system
Liked 927 Times
Likes For Miele Man:
Bikes: Wahoo of Theseus, others
Quoted: 428 Post(s)
Liked 67 Times
How cheap are we talking? I'll assume you want it pretty cheap if amazon not good enough. You could probably get a cheap broken down bike on craigslist that has one and cannibalize and flip it, might even make a profit especially if it has other parts better than what you have now to swap out like good tires or wheels or whatever. Also nearly free get a plastic bag and some zip ties.
Quoted: 34 Post(s)
Liked 8 Times
Thanks everyone
The Minoura under the seat may work. You can keep the Topeak bag in place.
The wolftooth double bottle looks very promising too.Will look into these possibilities.
I have looked at Wheel up and other bags that have an attached bottle holder. My concern was how much of the seat post has to be free for it to attach since the bags are vertical and the other concern is the position of the rear light. Ideal thing is a bag that you can
replace the Topeak with in just a couple of minutes when you are going for a long ride
The double bottle saddle carriers( Velo Champion) may interfere with the saddle bag. (I guess the bag could be moved to the front-- has tools, tube,gas cylinders, patches etc)
Will consider dehumidifier since it is my wife carrying it and not me....
Trying no not put it in the front like the Moosecreek although it may end up being that way.
Hi which water bottle holder is this I am looking foe a very nice designed one .
the silver one at the top of the page ,please
