How Much Work Do You Put Into Your Bike?
I now carry a chain breaker after having to make a long walk home with 60lbs of cargo aboard due to chain breakage. Brake pads basically get the same treatment, my rims are too expensive to get torn up by trying to get the last ounce of use out the brake pads.
Oh, I like to make a fashion statement with my bike, so it gets cleaned regularly.
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
I don't need to work on my bikes very often because nothing ever goes wrong with them. All of my bikes are singlespeed or fixed gear, there is no maintenance except lubing a chain or replacing it when it's stretched. Things such as tires and brakepads last for a long time. I don't waste time or money giving my bike cosmetic beauty treatments.
Quoted: 4227 Post(s)
Liked 2,488 Times
Perhaps you can help me then, I have my first true fixed gear now (non conversion), when I set it up I was able to tension the chain to my liking with minimal slack and I was rewarded with zero drivetrain noise, the chain has slacked a bit now and makes a bit of noise so I retensioned it and lubed it up but the last two attempts I was unable to get the chain as tense as I would like so there's some noise.. how do you get yours to set well? I'd really love to have it permanently in place until the chain wears out as my carbon fiber saddle should be here soon.
Everytime you ride the chain stretches a little and you will end up with a bit of slack, it all depends how much and how hard you ride. I need to tension my chain once per month.
Also make sure to keep the axle nuts real tight. I also recommend using chain tugs, they make chain tensioning a lot easier and prevent wheel slippage, in case the axle nuts are not tight enough.
Hogosha Sekai
Quoted: 70 Post(s)
Liked 21 Times
There are few different reasons for experiencing a chain slack on a fixie.
Quoted: 261 Post(s)
Liked 11 Times
I'm almost the same because the bus and train are my transportation vehicles. They are maintained by the city so my bikes are for enjoyment.
I'll admit, when I used to commute by bike, it took alot of work to keep it running because it was a folder. If I had to do it again, I would have purchased a new mountain bike with slick wheels because an old bike in bad condition wears out fast.
I still think there's alot of unnecessary replacing of parts just for the sake of having new ones. I see people constantly thowing out OEM tires, brake pads and saddles off new bikes on this forum all the time. I like to wear out tires till they start balding from over use. I feel the same way about brake pads and saddles. (unless the saddle is horrible!)
Regardless, my bikes are only used one or twice a week in the sun with no rain or bad weather. I guess that's why they look so good!
Liked 2,488 Times
90% of the time I stop and slow down by resisting the pedals, without using brakes, but I keep them on for emergency/panic stops. Skid stopping looks "cool" but it wears out the tires very fast and it takes much longer to skid stop in an emergency then in does using a brake.
In the right lane
A set of rims that are maintained well should last at least 15-20 k miles unless you are doing a lot of riding in poor conditions. Front wheel even more.
I'd be checking the rims ever quarter for cracks around the spoke nipple and excessive wear on the brake surface (if a rim brake...). And, of course, truing the wheels once or twice a year.
No point replacing it if it isn't broke.
Quoted: 19 Post(s)
I replace things when they wear out. I add oil or grease when needed. Today I replaced a chain. The rear wheel needs work but I just don't feel like messing with it now. It also needs a new rear tire. Next weekend I might get around to changing the tire and adjusting the spoke tension. I might even replace the rear brake pads. I keep some extras in my tool box. Bicycle maintenance is not a priority for me and never will be. Things wear out and get old. I can live with it.
When things go really bad I either get a new ride or rebuild the whole thing at once. One time a top tube disconnected from the head tube. That happened when a chain came off on a coaster brake bicycle and I ran into a wall. A friends dad welded it together for me.
Low end parts last a long time because they are heavy duty. Steel sprockets last a long time compared to alloy ones. I do wish belt drives would get into the marketplace at cheaper rates. I hate having greasy hands, especially if I must do something to the chain on the way to work or the grocery store.
bragi
Bikes: LHT
Sure thing.
I haven't taken a photo of this bike in 2 years, so this is an older incarnation of the KoM from when I lived in the city. Maybe I'll dig out the camera and post some up to date pics tomorrow in the "what do you ride" thread. I have since switched to a regular Technomic stem and the Nitto Noodle bars, and no longer use the Ortlieb handlebar bag. I went with Sheldon Brown's solution for the Rohloff shifter with the drop bars, mounted to a sawed-off MTB bar end extension.
Closeup of the Rohloff OEM sliding dropouts on the Mercian frame:
Loaded for touring, again in its original form.
Love this bike.
Love this bike.
bragi
Bikes: LHT
I replace the rims every 18 months or so because they just wear out, honest. It's not that uncommon in Seattle. It's wet nine months a year, grit sticks to things, there are steep hills everywhere, which means you're applying a lot of pressure on the brakes all day long, and, if you ride a lot, the result is that you burn through rims like they're made of butter. In an ideal world, I'd clean my rims after every wet ride (i.e., most rides), but I'm working 12-13 hours a day, so the best I can manage is about once a week. I've considered getting a bike with disc brakes, but there's absolutely nothing wrong with the bike I currently own (2008 LHT), and I'll be dead and long buried before that thing ever wears out...
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,538 Times
Bicycle Repair Man !!!
Drum / coaster brakes have their pluses but they are not going to offer the same stopping power as rim brakes or disc brakes and disc brakes also require regular service.
Besides SA, there are not a lot of cassette options that come with a rear drum brake and some folks like a lot of range for those aforementikoned hills. I have one of these SA cassette / drum hubs I have been planning to use although the right project has not presented itself yet and I have a front drum hub to mate with that.
As it is, I don't do nearly as much to my bikes as people would think save for making sure the tyre pressure is adequate as once they have been built and properly set up they don't need much save fore regular maintenance.
One reason I prefer drum/roller brakes... weather proof. Also if the rim gets bit out of true it is a non issue. Sturmey-Archer makes a drum brake hub that takes cassettes. If I lived somewhere like Seattle drum brakes would be my first choice. I use roller brakes on my city bike, tour bikes still run canti's.
Aaron
Aaron
Been Around Awhile
Quoted: 12 Post(s)
Liked 1,538 Times
I beg to differ about stopping power if the bike is ever used in a wet, snowy, slushy, or freezing environment. You being from Portland should recognize that fact.
Been Around Awhile
Quoted: 12 Post(s)
Liked 1,538 Times
That always was the problem with so many ten speeds that were sold when derailler equipped bikes were first heavily promoted in U. S., the lowest gear was still too dang high for the average cyclist to handle steep hills. I understand that still may be a problem with many derailler equipped bikes sold to the public.
You make a good point in that hub brakes can offer better stopping power under some circumstances but I deal with wet, slushy, snowy, and colder than most people and rim brakes have always served me quite well.
There has been a lot of movement toward equipping bicycles with disc and hub brakes in the PNW as you get maximum stopping power out of discs and can preserve your rims which may only last a season if you are a high mileage commuter. For some a coaster brake might be limiting on it's own (I have always run a front brake with these) and hub brakes strength is that they offer decent stopping power on a consistent basis and have a long service life but don't match rim / disc brakes.
If it is just wet, rim brakes provide a lot of stopping power and there will be some degradation at extremely cold temperatures for some set ups... enclosed brakes are best when you have to deal with weather that cycles quickly between warmer and wetter and then colder and freezing.
Horses for courses, as they say.
Folks who ride fast in all conditions might be able to deal with rim wear because they need more braking performance than drum / coaster brakes provide... lots of these folks transition to disc brakes which are becoming pretty ubiquitous on a lot of entry level bicycles now.
Quoted: 70 Post(s)
Liked 15 Times
I don't find the drum/roller brakes to be limiting at all, there are some crappy ones out there on the market (Shimano IM-F41) that have "limiters" built in to keep you from locking the wheel. I use Shimano roller brakes on my big city bike, fully loaded I am pushing 350# rolling weight. But then again I rode on chrome steel rims with cheap brake pads for years...
Aaron
Aaron
In the right lane
I understood this right off... my wife's primary commuter would get new rims every 10,000 miles when she lived in Portland due to to rim wear as this kind of environment will cut a rim's life in half and this got better when we changed her brakes to Kool Stops. The original Tektro had a pretty good reputation for eating up rims.
I do know that winter bikes (that pick up a lot of road salt) end up grooving pretty quickly.
Maybe I should move to salmon colored Kool Stops on my winter beater. I have a set on both summer commuters and the pads last a really long time.
I never realized moisture would eat up a rim like that.
bragi
Bikes: LHT
Do you have any suggestions for cantilever brakes besides Tektro? I've never been happy with them; they're very fussy on a daily basis, and changing brake pads is a major production involving a half dozen nested washers, or whatever they are, and God help you if you get them out of order...
Shimano makes nice cantis in the CX50 and CX70 (105 and Ultegra level)... and the prices are reasonable.
bragi
Bikes: LHT
I find Tektro brakes to be generally quite good, I am just not a fan of the brake pad material they were using and have always preferred Kool Stops since they were called Matthauser.
Sophomoric Member
It's usually below freezing here, but they treat the roads with a blend of salt and sand that totally chews up a bike.
"Think Outside the Cage"
JaclynMcKewan
Living Car Free
39
08-28-11 10:12 AM
SlothPaladin
Living Car Free
11
04-15-10 09:18 AM
