Stuck cork in handlebar?
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Obviously a cork screw is the way to go if it's long enough, but if you need something longer I'm sure the hardware store has a long coarse threaded screw (something designed to screw into wood) that you can use like a cork screw. If it's loose enough that it rotates, try to wedge a spoke (or something thin) in between the cork and the handlbar wall. If you can get enough spokes in there, and move them around so they aren't all in the same place, then pull them all out at the same time at the same time, that might bring the cork with it.
www.rhmsaddles.com.
www.rhmsaddles.com.
Habitual User
Quoted: 4971 Post(s)
Liked 8,123 Times
The obvious answer...
...buy another bike.
Quoted: 236 Post(s)
Liked 352 Times
Get stick with blob of strong epoxy on end. Carefully place in center of cork. (Use "Operation" game skills). Pull on stick when dry and hope cork and stick will not both be stuck there.
or... Will a flexible drain snake fit through the other end?
Shifting is fun!
Bikes: Yes, please.
Quoted: 2200 Post(s)
Liked 4,627 Times
I bought a cheap compressor years ago. $100 well-spent. Top 3 use cases:
- removing handlebar grips (POP!)
- unscrewing freewheels (KRFWZZZZZZING!)
- cleaning nooks & crannies (PSHHHH!)
You all crack me up. Love these. Glad I'm giving you all an interesting puzzle to solve. Oh btw, the handlebar is on the bike. I may try the epoxy route. That sounds like it might be a fun game except no buzzing but still probably some good cursing.
Off grid off road
Is that cork still in there?
