Carbon Bar / Stem Question
Bikes: 1992 Clark Kent Custom Ti Dura-Ace Cross / Gravel Bike, 2017 Specialized Roubaix Di2, 2022 Specialized Roubaix AXS, 2021 Kona WOZO Fat Bike, 2022 Trek Farley 9.6 Fat Bike
Quoted: 8 Post(s)
Liked 10 Times
Interesting discussion, I really appreciate you all.
enjoy the ride!
enjoy the ride!
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Anyone who has owned an older alloy frameset/bar combo and gone to a really modern carbon frameset/bar combo that rides gravel or rough roads knows this is crap.
Same exact tires/pressure going from my old alloy Crockett with alloy bars to a modern TCX with carbon frame and bars it's light years different on rough terrain. The Crockett would beat the hell out of me. And I ran more bar tape on the Crockett.
Ignoring the perils of comparing two completely different bicycles and attributing the differences to "the materials", let's just talk about materials for a bit.
Aluminum parts have to be made strong enough not to break, which is why aluminum components are for the most part stiff. Generally speaking, an equally strong carbon component will be more compliant. But that is not always the case. It depends on the component design.
Neither type of component absorbs vibration, which would require it to convert mechanical motion to heat. Viscoeleastic materials like rubber absorb vibration. Metals and carbon composites do very little absorption.
Now let's talk compliance, the ability to deform under stress. Which component on the bike has the most compliance? If you guessed tires, you were correct. Another component that has similar compliance magnitude is a seatpost, when it is fully extended. Seatposts are long beams, fixed at one end, with a heavy weight (your butt) on the other end. And even here, the compliance difference between a super stiff aluminum post and a super bendy carbon post is about 2 mm (Velo Magazine test).
So whenever I read that carbon is so much more comfortable than X, I have to roll my eyes.
Likes For terrymorse:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
When subjective experience contradicts engineering prediction, then the engineering usually missed something.
I’ve swapped enough bars to know the difference is real.
And riding metal vs CF frames (especially road/gravel frames), the difference in feel is unmistakable to anyone.
That fact that you can’t explain it does not mean it does not exist.
Of course the assuption here is that the CF has been designed properly. But in my experience with reputable CF products, they generally are.
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
1. Aluminum parts have to be made strong enough not to break, which is why aluminum components are for the most part stiff. Generally speaking, an equally strong carbon component will be more compliant. But that is not always the case. It depends on the component design.
Compliance is comfort. So why are you rolling your eyes? You realize you can both be right about the materials, but also wrong about the compliance part. Right?
I'm not saying to mold a carbon bike to be identical to an alloy one in all shapes and sizes, I'm saying since you CAN mold carbon differently they DO mold them to their advantage.........for as I quote you "more compliant".
How is "more compliant" not more comfortable? That's an outright contradiction.
Either you stated something you didn't intend to saying carbon tends to be more compliant, or you need to concede that it can be more comfortable.
climber has-been
Liked 3,567 Times
Which is it? You say above "aluminum components are for the most part stiff. .........an equally strong carbon component will be more compliant."
Marketing copy: Our Wizzy Wiggy Techno Stuff[tm] increases compliance by 33%. Buy it for an unprecedented level of comfort!
<eye roll>
"Absorbs vibration" -- a false statement for metal or carbon composite.
Newbie racer
Liked 1,569 Times
I mean, in the bending of a seatstay or chainstay in a frame 1mm difference to me sounds like a mile. 1mm in a spring/damper system would be nothing, but for a "beam" 1mm sounds like a more tangible difference.
The "compliance" of your bartape is apples and oranges but 1mm in bartape thickness certainly matters. Or in your gloves.
I hear and agree with the science here, I think you're just discounting the practical application actually mattering. So will have to just chalk it up as I disagree.
I wish before selling my alloy cross bike I put the Notio on it. The Notio has accelerometers that easily for the same tire/pressure setup could have registered usable values.
As the ride feel on same tire/pressure on the carbon TCX is like fine ribeye compared to the dogfood of the alloy Crockett I had. I honestly went into that bike purchase wanting electronic shifting. I didn't care about a weight or "compliance" change. I didn't even believe it would matter for which bike beat me up more. Same tire pressure and tires...........I had to do a double take after riding the TCX. Like, I was shocked how different it felt. I checked the tire pressures, etc....
Quoted: 1461 Post(s)
Liked 1,486 Times
I got a bike fit a few years ago on my gravel/cx rig and the fitter recommended trying a wider bar - I splurged on an Enve G series carbon handlebar to replace the OEM aluminum one and it turned out to be one of the best bike purchases I've ever made. It fits better, rides smoother and has the fringe added benefit of shaving a few grams. I'll leave it up to others to argue if that is a result of the material (carbon vs alloy) or some other design aspect, but I have zero regrets on this purchase and would not hesitate to buy another one. The difference between this bar and my stock alloy bar is very clear.
Also for the OP - I have been running my carbon handlebar on an alloy stem with no issues. The Enve bar has a grippy material where the stem clamp goes, which (I think) negates the need for carbon paste.
Likes For msu2001la:
Advanced Slacker
Liked 2,537 Times
Quoted: 1109 Post(s)
Liked 1,202 Times
Thanks for pointing this out. It definitely changes the discussion. It points out a pet peeve of mine - people who post a model of bike and expect that the readers will know what the heck it is. For something fairly common like any Trek or Specialized product, maybe (but still...). In this case I know nothing about what is a Farley and since it's a fat bike, the comments I personally made, and probably quite a few others, are virtually irrelevant. If dphillips had provided this simple information, like "fat bike" "carbonfiber (or whatever) frame", "XYZ group", it would have been much better, imo. I thought I was talking about just a heavy road or hybrid type bike that wouldn't (IMO) be worth any upgrades other than fit/contact items. If it starts out as a pretty high end bike, I would probably have said, go for it. (I guess I kind of did in an earlier post).
Likes For Camilo:
Liked 1,486 Times
Oh, a fat bike...
Unless there's a fit issue being addressed, I can't imagine any handlebar upgrade changing the ride comfort on a fat bike.
Quoted: 4236 Post(s)
Liked 2,949 Times
It does seem like tire pressure is the first place to look when changing comfort of a fatbike.
Quoted: 1401 Post(s)
Liked 1,886 Times
link to handlebar review / deflection testing :
https://blog.fairwheelbikes.com/revi...dlebar-review/
Liked 1,886 Times
maybe
sorta / kinda
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,001 Times
Quoted: 8 Post(s)
Liked 10 Times
I will give more information when I have another question.
Thank you all for your replies.
just make sure to use carbon paste and torque to spec
