Headbadge re-mounting
Half way there
Quoted: 987 Post(s)
Liked 880 Times
I've tried drive screws (AKA screw nails) and found that I didn't like the look of the head - larger and more round than the original. Nor have I had any luck with brass screws. It seems that every frame I've worked with has different diameter holes. I've since used rivets that I've made from short lengths of solid copper wire. I first form the head on the wire by inserting it into a shallow hole drilled into a piece of metal and then using a small punch with a concave end to round it off. The punch is just a bolt that I've modified by grinding the concavity into the end. To install the head badge, I place the head tube over a short piece of iron pipe clamped to a bench, insert the formed rivet through the hole, and then use the same concave punch to expand the back end against the pipe.
Quoted: 176 Post(s)
Liked 245 Times
The Simplicity of Vintage Cycles
Half way there
Quoted: 987 Post(s)
Liked 880 Times
1. Picture of the bolt that I form the rivet head with as well as drive the rivet through the headbadge/headtube. You can form the concavity with a drill bit or dremel tool and then taper it.
2. This is the device that I use to form the head. It's just 2 plates of aluminum with a short hole drilled through the joint. The plates are clamped together when forming the head. The head forming process will expand the shaft of the wire in the hole so this split plate system is necessary in order to get the formed rivet out.
3. Here's what the finished product looks like:
Likes For Moe Zhoost:
Quoted: 457 Post(s)
Liked 462 Times
Sure:
Do you know if you used 12 gauge wire or 14 gauge wire?
Quoted: 472 Post(s)
Liked 1,028 Times
I also created rivets from 12awg copper wire for my Raleigh. I drilled a hole in hardwood (maple or oak) to hold the stubby little length of copper wire. I then and "tap tap tap" formed a head with my quite small ball peen hammer. Inserted each one from inside the head tube and backed that on an iron bar, clamped in the vice. I then put the headbadge on and "tap tap tap" formed a wee head on the outside. No where as nice as those copper rivets shown above but just as functional. It's all held for 6 years now. Not much stress on a headbadge.
I much prefer the subtle look vs drive screws or the large rivets that Raleigh and Carlton used on some head badges.
