What's the worst part about loving old cantilevers?
Certified Bike Brat
Quoted: 5 Post(s)
Liked 6 Times
When Shimano's "V" brakes were first introduced, they were initially referred to as direct-pull cantilevers.
One of the main differences is that traditional cantilevers have a variable mechanical advantage whereas V-brakes had a fixed mechanical advantage.
IMO the popularity of V-brakes is largely due to the fact that they can be installed and setup by just about anyone. The proper setup of a cantilever requires a skilled bicycle mechanic with experience in that area.
Consumers have for the most part consistently traded performance for price and convenience in just about thing you can think of - including bicycle accessories.
Magura's hydraulic brakes and Shimano's XTR and XT parallel push V-Brakes outperformed anything else on the market in braking power. But not in price.
So performance obviously isn't the only criteria. And brakes are like everything else. There's a wide range of quality in both V-brakes and traditional cantilever designs. Some are junk and some perform extraordinarily well. A decent cantilever set up properly can easily outperform any of the plastic coated stamped steel V-brakes found on most department store bikes.
No - I have no particularly bias. Personally I own bikes with all of them including those XTR parallel push V-brakes mentioned. They all work well if properly installed and maintained.
Quoted: 4236 Post(s)
Liked 2,949 Times
I have a set of old xt canti's. In my case the plastic cover just made it easier to adjust which hole on the bike the spring went into without taking the brake entirely off the bike. I think 2 or 3 of the plastic covers have broken making the adjustments a lot more of a pain (but part of the pain is the way my front rack attaches making me take it off when I want to adjust which hole the spring is in), but they're still perfectly usable. This isn't the case with yours? Sounds like a dumb design (not that the design on mine was any better. A few extra cents for them to have made that plate out of metal and the brakes would still be awesome.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
Kid A
Liked 5 Times
I generally like the modulation of cantis better than Vees. If I'm on a project that warrants purchase of new brakes I typically go for V-brakes however, for simplicity's sake and bang-for-buck.
Tough break on those brakes! For my $, I actually prefer the hated tektro oryx over other cantilever brakes. They're cheap and work great. The CR 720's are decent, but interfere with my front rack and have very low leverage with mountain levers (but great travel). Hook yourself up
When cantilever brakes were first introduced, they were considered exotic and were used mainly on high-end touring bikes.
The Data Book, starts showing them in the 1946 section.
Old. Slow. Happy.
Quoted: 5 Post(s)
I don't always run cantilevers, but when I do, I look for the following features:
- No plastic bits
- Minimally exposed springs
- V-style pad mounting (i.e., no post-style pads)
- Self-contained pivots (i.e., brake does not rotate directly on canti boss/stud)
Kid A
Liked 5 Times
Data book , originally '83 Japan, of old French drawings
like those done by Daniel Rebour.. famed illustrator..
Reprinted in '98, by Bicycle Books of SF..
ISBN 1-892495-01-5
ISBN 1-892495-01-5
Certified Bike Brat
Quoted: 5 Post(s)
Liked 6 Times
But yikes - I can remember when things like flush toilets and showers and color TVs were new and unusual too
Yeah - we've got more 'stuff' today, I'm just not convinced we're more civilized .
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
Fighting words! Bad cantis suck for sure, but a good pair of cantis are really nice and quite effective. Thanks to the new VO brake pad holders for them they are easy to swap out pads once you get them set-up the first time.
That, and aesthetically I find cantis more pleasing than V brakes.
Having used some tektro CR-720 on a bike with 1-1/4 steerer that shuddered no matter how the pads and brakes were adjusted, I find that cantis are just a waste of time.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12781 Post(s)
Liked 7,696 Times
Guess I've been lucky. I've had plenty of canti equipped bikes and none exhibitted shudder. I even have one with cable stop in stem ATM.
My old Raleigh Sports had shudder, almost seemed like it was from fork blade flex in that case, but it didn't have cantis.
Certified Bike Brat
Quoted: 5 Post(s)
Liked 6 Times
no matter how good the cantis are, they have a flawed design from the start. The problem is the way the cable gets anchored to the frame. Any front end flex results in brake power changes that cause pulsing. No other brake on a bike does that.
I test drove a Kona Jake SE last year and the cantis sucked big time - at least compared to the cantis on the bike I normally drive. All that told me is that they were a poor choice to stick on an $1,100 bike and would be the first thing to upgrade - even if it meant only the pads.
And that's exactly the kind of info I'd be passing on to anyone potentially interested in buying the bike.
Liked 5 Times
Are you really going to make a decision for life based on a poor introduction with a $30 brake?
If cantis work, they work, but when they don't, nothing will fix it. This is unlike other types of brakes available, where their problems are fixable with adjustment.
Kid A
Liked 5 Times
Learn to adjust cantilever brakes and mate them with proper levers and you'll probably like them a lot more. All my v-brakes sit in my parts bin, though I used to swear by them. Need any?
Kid A
Liked 5 Times
CR-720 is one of the best cantis out there, and they worked perfectly on my CX bike. For some reason, they worked TOO well on my XC bike. When the cantis grip too hard, that's when you get shuddering.
Shuttering merits no further discussion. Actually, I had one bike with mild shuttering that was never a big enough deal to bother with -- bike still stopped extremely well.
Liked 5 Times
You're entitled to your opinion, but you should realize that v-brakes are just a cantilever brake for idiots (in terms of adjustment, or lack thereof). V-brakes suffer from many things too, like barrel adjusters that barely do anything, crappy noodles with inner plastic liners that crack and cause friction, stirrups that bore out and fail, and **** for pad travel -- and you're powerless to do anything about it.
This is why cantis are flawed. They require some fixation point on the frame and if the frame flexes, you get a change in braking power.
Quoted: 239 Post(s)
Liked 7 Times
actualy, as much as I love cantis, I had been thinking that perhaps a brake lever with adjustible mechanical advantage could enable a v-brake to work nicely.... only problem is that the only such levers i know of (avid speed dial) have short 2.5finger levers, thus safeguarding me from the dark side.
Or does anyone know of an adjustible lever that has old styled 4-5 finger long levers?
Liked 5 Times
to eliminate flex, use a Brake Booster, have them on all my cantis and works wonders.
Certified Bike Brat
Quoted: 5 Post(s)
Liked 6 Times
I'm interested - seriously!
Bikes: '97 Specialized rockhopper, '80s Motobecane Super Mirage
I just switched my commuter over from V-Brakes to cantis for one big reason, centering.
No matter what I did I could not get my old v-brakes to center, I played with the adjustment screw and the mounting holes but one brake would alway overpower the other, pulling the weaker one into the sidewall causing rub.
Now that I have cantis, one side doesn't affect the other, the return spring doesn't fight the one on the other side and they are perfectly centered, no rub and work beautifully.
I am also using a very short straddle cable possible, creating a very high mechanical advantage and awesome stopping power.
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
Now I have had brakes that squeal horribly...the Avid Shorty 4s were almost the worst offenders. The worst squealers I've ever run were the XT linear brakes. I'm sure the echos of those brakes are still reverberating around the mountains of Colorado.
Stuart Black
Stuart Black
Constant tinkerer
I don't understand the complaints of poor modulation on V-brakes. It just takes a trained hand to operate them. I put Kool Stop pads on my V-brake MTB to make them even stronger. I like being able to jam the brakes with a couple fingers and stop on a dime, rather than hanging on for dear life with a canti and still barely able to lift the rear wheel with the front brake.
Bicycle Repair Man !!!
The 55 year old Mafacs here work just fine and will probably last another 55.
I've had 13 bikes equipped with cantilevers of various levels of quality from the lowest Shimano to Paul's. Of the 13, 4 have been on road bikes including two touring bikes and two tandems while the other 9 were on mountain bikes. I've never had a single one shudder or have braking problems...and I live where gravity gets you moving quickly very easily. On one of the tandems, I even removed the drum brake and left the cantilevers to handle all of the braking duties. There's really nothing wrong with them if they are set up properly.
The XTR linear pull is also known to be pretty noisy until you pair it with XT or LX levers... seems like a small change in the lever makes quite a difference.
I’m destined to lose this argument up against such powerful forces. However, running out to buy cantis because of the glow of some of the best bike mechs on this forum may not be a good idea for the novice. Cantilever brakes may have the braking power of side-pulls when properly set-up, but they require a lot of things to work properly together to be as good as they can be. Side-pull brakes are pretty idiot-proof and the leverage achieved from the short pull of the cable from the side is why they replaced cantis on MTB’s. That and because they are cheaper to produce, granted.
I feel conflicted because I should be on the other side of this argument.
