Track Cycling World Cup
#151
I ran sponges/pads for UCI Master Worlds in LA last year. We were told to put the sponges about 3" off of the cote. It was explained to me that it made riding on the blue impossible, but you could still be below the black line without a pedal hitting the sponge. Otherwise you can't ride below the black line if the sponges are set right on the edge. Since it is only the cote that is forbidden, this makes sense. And yes, it will affect the times if you manage to ride below the black line at all times.
From a mental standpoint it might be slightly advantageous as well, you could ride tighter to the black line without as much worry.
#153
Lapped 3x
I'm not a pursuiter by any means, but I've seen deliberate path techniques where a rider will:
- Ride wide of the black line down the straights, and
- Ride under the black line in the turns
My guess is that this helps mitigate the speed losses in the turns by making the path less cigar-shaped and more oval shaped.
Marginal gains.
Having the pads further inside, off the track helps even more.
On a related note, I think that riding a great line is often the difference between winning and losing.
Marginal gains.
#154
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
Thanks! I didn't get to see the ride.
I once heard a roadie comment, "It's only 4 laps. How hard can it be?"
I don't speak Dutch (?). But, there is a point in the video when Hoogland collapses motionless on the ground and the commentator says, what I interpret to be, "This is the Kilometer."
That pretty much sums it up.
It's a brutal event. And if you do it right, it'll make you swear-off track racing for life
It's a shame that the Time Trial and the Individual Pursuit are no longer Olympic events. It's evident by this week that progression is still being made in the events and athletes still care about them.
*DLV is an exception, as it literally has an uphill straight and a downhill straight (lol). It's a 100w difference for me to maintain the same warmup pace on the two.
#155
Lapped 3x
Nope. Most tracks have the bottom of the Cote d'Azur as level. So there can be quite a variance in elevation on the black line.
#156
Quoted: 75 Post(s)
Liked 6 Times
Bring back the kilo IOC!
There's not much kilo racing here bar state and national champs, which I find a bit sad as it would probably be the event I'd suit best, but it's a tough mistress
#157
www
nadovich.com/chris/track/vdrome01.gif
more on
www
Zero-bubble pole line
Optimized Asymmetrical Superelevation
Cornu Spiral Transitions
Twisted, Radius-Cupped Panel Segments
Sorry it's out of post subject. Naval Architect, here..
#159
Elitist
Liked 92 Times
"zero bubble" pole lane concept.
www
more on
www
www
more on
www
I've always wondered, should tracks by symmetrical (turns 1, 2, 3, and 4 being the same) even though we only ride in one direction? Would there be any benefit to having turns entry turns 1 & 3 having an "entry gradation" and exit turns 2 & 4 having a "exit gradation"?
I'm not asserting that they should, but just wondering if there would be any benefits.
#160
Lapped 3x
www
more on
www
www
more on
www
Tracks have used some form of easement curve for decades. Whether they be Cornu Spirals, Euler curves, or based on a proprietary mathematical relationship, there is nothing new here.
And a zero bubble pole hasn't been proven faster at all. In fact, I don't think it really matters much, especially since most riders will naturally drift out a little on the straights, and hold, or dip below the black in the banks, naturally cancelling this feature out. Because of this I would actually think this "feature" would be slower as it now forces a rider to perfectly ride the black the whole time.
And the twisted, and cupped panel segments? This would happen to any piece of board that is affixed to a sufficiently sturdy frame, simply because it would have to conform to it when attached.
Optimized Asymmetrical Superelevation? This is just a natural consequence of using an easement curve and maintaining the same track width.
Thanks!
The lean that a trackie exhibits going through the bank is a reaction the the G forces they are experiencing. This is again, a reaction, which means there is a delay in the rider's movement compared to the force they are experiencing. By using an easement curve, you can delay the severity of the onset of the Gs into something that matches a safe rate of lean for the rider.
On a well designed track, the bank does most of work based on the forces a rider is expected to encounter. An easement curve gets the rider to slowly dip down at a manageable rate, holds them there, then "drops out" from under the rider as the track straightens out, forcing the rider "up" by moving them "out". The rider reacts to this by allowing their center of mass to come out (the body), but by steering straight, the bike stays put, and the rider moves back out over the bike.
If the curves were symmetrical (split the difference between the two), then the rider, on entry, will have to actively drop their center of mass, and time it right depending on the speed they are travelling. At the exit, they will have to actively steer inwards (left), as the banking levels off, to prevent themselves from being thrown outwards, while again, timing their "lift" based on speed and location in the bank.
We still have to do these things to a certain degree, but a properly banked track REALLY takes a lot of the guess work out of it.
#161
Lapped 3x
Watched a video of Hoogland's kilo. 10.8s 125, and a 17.3s first lap. This used to be the domain of TS starters. Top that off with a 30.1s 500 and a 43.9s 750m. We are certainly in a new era of sprinting these days.
#162
The US women team pursuiters have been riding left hand drive train Felt bikes for at least two years. I'm surprised no other team has tried this concept. The US successes leads me to think there may indeed be a slight advantage.
The tech manual for these bikes is available here https://www.feltbicycles.com/Resource...ons_110216.pdf
#163
Quoted: 75 Post(s)
Liked 6 Times
It's interesting that even with the slightly differently styles it's still so close
#164
#165
Elitist
Liked 92 Times
Yeah, I don't think LSD (left side drive) even provides marginal gains.
I'd like to be proven wrong, but right now I can't see it being anything more than marketing hype.
The extra weight of the crank spider, chainring, chain, and cog being 10 inches to the left can't make any real difference. The CdA is the same as if it were on the right.
Maybe it provides a psychological advantage.
#167
Elitist
Liked 92 Times
Aren't these those new 3T bars? The drops seem really far forward. Anyone got a video of Bos' ride? I'm curious as to what standing starts are like on these.
Oh...and Shimano red cleats
#168
look like standard Revo's to me, I think the angle of the pic is an illusion. (that and how short his extensions are)
As far as the left hand drive... there is some science behind it that makes sense on paper... doesn't mean it translates to on track though. Overall, I tend to also think it's neutral (or very, very close, within margin of error certainly) to "normal"
Fwiw - here is the article I was thinking of with Dean Phillips. Was a TK1 not a T4 he tested it against. He sees some significant gains... (almost unbelievable gains really from a bike change) but the T1 is a fairly old design so you'd expect the new "supertrackmachine" to be a good bit better.
#170
................. here is the article .................
"Asymmetrical tubing shapes and component placement are used throughout the bike based on CFD modeling showing optimal aerodynamic drag for these conditions."
I would like to know more on why asymmetrical tubing is used.
#171
Quoted: 30 Post(s)
In testing indoor velodromes show an average yaw angle of 2.5 degrees. Thus, they designed a bike that is most efficient at 2.5 degrees of yaw. Hence the left side crank, and everything else.
#173
Lapped 3x
According to one of the engineers I work with, who knows some of the engineers at Felt:
#174
Quoted: 40 Post(s)
1:09 onwards. You'll probably still need a VPN as it's the UCI channel. I'm currently downloading a video and will put up his kilo segment later if you'd like. I've seen them in person and they're a bit like short scattos (similar to the FES bars Eilers uses). The grip-able area does seem alot shorter IRL than it does in that photo, and that little dip between the typical end of the bars suggests he might have just gotten long AF bar ends to plug in there to extend their length.
#175
[QUOTE=SyntaxMonstr;The grip-able area does seem alot shorter IRL than it does in that photo, and that little dip between the typical end of the bars suggests he might have just gotten long AF bar ends to plug in there to extend their length.[/QUOTE]
Yeah, those look longer than the ones I've seen in person. They're pretty stubby.
