Schrader and Presta valves
Mad bike riding scientist
Quoted: 6242 Post(s)
Liked 4,258 Times
Actually... I think my two most recent fails were structural. One was at the junction where the valve stem meets the tube, another was a couple of very small, slow leak holes along a manufacturing seam. There may have been some "circumstantial causes," but not that I could find. I think it was the admittedly-low-cost tubes. Will never know for sure. Or care <snicker>
Small, slow leaks are a fact of life where I live and I would never blame the tube especially if the tube is inflated in the tire. We have goat heads in addition to the glass and other road debris that people elsewhere have. Punctures on the outside part of the tube should always be assumed to be due to something going through the tire but leaving no evidence behind.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 4,258 Times
Well that is certainly not true. Cheaper tubes have less consistent seams, more variation in the rubber thickness, lower quality of the valve materials, and the QA is by sampling rather than testing each tube. I've had more than one QTube come apart at a seam, and lots of Kendas or other cheap tubes that just didn't hold air very well, even overnight.
The lines you see on a tube are from the curing mold and have nothing to do with the structural integrity of the tube. They are not “seams”.
In addition, no one tests each tube coming off a production line. That would take hours per batch and be cost prohibitive. Any quality assurance is done by random sample testing…even from your supposed higher quality tubes.
And, better tires do have better puncture resistance.
I switched to "premium" tubes a while ago and never looked back. I have a lot fewer flats and I don't have to pump up my tires as often.
Stuart Black
Stuart Black
Liked 4,258 Times
Thanks every one for your input. yep, they only had the size for my bike with the presta valve. looked high and low. saw the inner tube with the correct valve on Amazon. so, will purchase on line. another question, can you ride with a patch tube indefinitely? if you can, would you, or would you stick a new tube on? Pros and cons. thanks again
That’s just penny-wise and pound foolish. A box of 100 Rema patches cost me $15. A can of glue about the same. A can of glue can be used through 3 or 4 boxes of patches. At 15¢ each for the patch and about 5¢ for the glue, that 20¢ per patch vs $9. Those 30 patches cost me $6. 30 tubes at $9 each is $270.
Stuart Black
Stuart Black
Old fart
Quoted: 3608 Post(s)
Liked 3,433 Times
Bike shops don't patch tubes because they'd have to charge for the labor, which makes patching a tube cost more than simply replacing it. If you're doing the labor yourself, you can (as @cyccommute suggests above) save a great deal by patching tubes instead of using a new tube every time you get a flat. And it's better for the environment. Butyl rubber takes forever to decompose in a landfill.
I have a local shop save the punctured tubes from flat repairs to be patched and used by our clients at the charity bike shop/community farm/jobs skills program where I volunteer and labor is free. Our shop is entirely supported by donations, and our clients (homeless people, people recently released from prison, and chronically unemployed people) learn jobs skills on the farm. After putting in 15 hours of work on the farm, they get a (donated) bike, and we repair and maintain their bikes free of charge as long as we have the necessary parts to do so. Patched tubes are standard fare for flat repairs. Any tubes that cannot be patched, we give to the farm, and they use them to tie back plants, bundle stalks, etc. Very little gets wasted.
Likes For JohnDThompson:
Quoted: 5234 Post(s)
Liked 3,602 Times
th trick is finding the hole, right?
Quoted: 1088 Post(s)
Liked 701 Times
"All tubes are inflated and stored for 24 hours in order to test for air pressure retention. Afterwards each, individual tube undergoes a careful visual inspection."
Continental also tests each tube. That's why they're more reliable, and also more expensive. You get what you pay for, especially with tubes and tires.
Quoted: 4846 Post(s)
Liked 3,977 Times
+1 If I were given some sweet wheels but they were schraeder, I'd epoxy or silicon in an adopter and always use presta.
Likes For 79pmooney:
Quoted: 4227 Post(s)
Liked 2,489 Times
Likes For wolfchild:
Liked 2,489 Times
Advanced Slacker
Quoted: 2764 Post(s)
Liked 2,539 Times
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Sure they do. From Schwalbe's web site https://www.schwalbetires.com/bike_tires/tubes/all
Likes For GlennR:
Liked 4,258 Times
Stuart Black
Stuart Black
Quoted: 2531 Post(s)
Liked 3,014 Times
Well that is certainly not true. Cheaper tubes have less consistent seams, more variation in the rubber thickness, lower quality of the valve materials, and the QA is by sampling rather than testing each tube. I've had more than one QTube come apart at a seam, and lots of Kendas or other cheap tubes that just didn't hold air very well, even overnight. And, better tires do have better puncture resistance.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,324 Times
Right now it is just a barely an argument over the quality of tubes based on name brand. Once it evolves into a debate over which valve is better, it will really take off.
Likes For Chuck M:
Quoted: 236 Post(s)
Liked 196 Times
So sure, if I had abundant free time and flatted so often that the cost of tubes caused a discernible disturbance to my finances, then I too might patch vs replace. That's not my situation though and the cost of a tube once or twice a year is immaterial to me.
Senior member
Quoted: 946 Post(s)
Liked 663 Times
And a fourth called Fillmore. https://www.reservewheels.com/fillmore-tubeless-valves
Actually, it is tubeless only, and although I have never tried them, I think I will.
Likes For Dan Burkhart:
Advanced Slacker
Liked 2,539 Times
You ignore the opportunity cost of the time invested in performing the patching and swapping the tube back. Convenience has a cost, and the value of free-time depends on the individual and their situation.
You don’t have to do any extra swapping out. You keep a spare tube on hand and use it when you get a flat, Then patch the flat one at the time and place of your convenience and it becomes the spare.
Likes For Kapusta:
Quoted: 7666 Post(s)
Liked 3,534 Times
True it can take as much as five minutes to patch a tube, if the hole is really small .... I might have to immerse it in water---and that is Really hard, exceedingly time-consuming, back-breakingly laborious. To me though, t is really worthwhile because the sort of invisible punctures thus located often also reveal the location of that hidden bit of tire wire which will puncture the new tube, and every other tube I use, until I scrap and flex the tire enough to get the wire to poke out so I can grab it with tweezers.
I usually buy a eight or a dozen tubes, about every five years or seven years .... I keep two on each bike (which is a dozen right there) and a bunch more on the shelf, some patched, some new, all ready to be used as needed. I buy patches and glue in bulk online every few years .... and for some reason I get more flats than any two riders I know (bad flat-karma?) Most of you who seem to get maybe two flats in every 5000 kms .... you could get by on a seventh of what I use.
Liked 3,534 Times
Anyway ... just for the sake of controversy and longevity---what sort of lube do you use on your valve stems?
Or ... if that is too inane even for BF ......
Valve caps, yes or no?
Likes For Maelochs:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,572 Times
Liked 3,534 Times
Three times the price is a lot for a brand-new product which justifies its cost with longevity---you Expect it will last the rest of my life, but they have only been on the market for a short time so .....
But they sound like an improvement over regular vales if they really never clog, the seal never wears, etc ..... I'd like some unsolicited testimony from third-party sources before I invest, but they sound good .......
Likes For Maelochs:
Liked 2,572 Times
Yeah ... even though we are not Supposed to learn anything here, sometimes it happens.
Liked 3,602 Times
Advanced Slacker
Liked 2,539 Times
So now instead of replacing a clogged $1 valve in about a minute, you replace a clogged $25 valve/stem combo that requires you to remove and remount the tire.
Likes For Kapusta:
Liked 4,258 Times
Stuart Black
Stuart Black
