Metric Century used to be called 62 miles
#76
Perhaps the question should be expressed this way: In counties where the metric system is used, are 100km rides called metric centuries or just centuries? Do they use the optional nomenclature of "62 miles" as well? In countries that use the English measuring system why call a 62 mile ride a metric century? Why not just call it what it is, 62 miles? Seems to me that calling a 62 mile ride a "metric century" is trying to make it something it is not. It is not a "century ride", which is 100 miles, however it must make a lot of people feel good about themselves because they did some kind of century ride, although they did not do a century ride.
#77
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
#78
Well, I'm doing a granfondo in Europe and they have a mediofondo of 97km and the granfondo is 174km, I think that's the nomenclature they use and that century term may be more of an American doing.
#79
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
I'm getting increasingly tempted to cancel this weekend's ride as I just can't shake the nagging fear that the wheel diameter I enter into the computer might be off by a few millimeters, or that I might go over a bump and have the battery jiggle enough to reset it again.
I mean, what if I sweat it out all day and come back with no idea what I actually accomplished????
(In all seriousness, in thinking about exploring on a network of paths with some repeated sections, it is more of a thought than a typical point A to B and back to A ride)
#80
Bikes: Specialized Diverge E5 Comp, Specialized AWOL Comp, Scott Solace 10
Quoted: 137 Post(s)
Liked 27 Times
I don't particularly care what someone calls it, just be clear about what distance you are talking about!
#81
Winston63, you just sparked the answer. I see now it is a "name" for a certain distance. Easier to say and somehow easier to understand than 62 miles. I get it. Problem solved.
#82
I was in elementary school when Canada switched and learned both as a result. Over the years I've adopted metric for everything except temperature; my brain simply thinks in F (even though I know the basics in C).
Today I was describing the weather as being about 65 degrees to a 95 year old lady I was walking and she couldn't relate - She only thinks in Celsius! I couldn't convert for her. There was something very odd about that encounter.
#83
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
#84
Yes indeed! ;-)
Hmm, this is an interesting thought, I've never considered it from this point of view (as if this temperature system is really designed around 0 - 100 scale). I guess for me negative - cold, positive - warm makes more sense. May be this is just a software developer speaking in me... Zero as a center just somehow feels logical. Zero also happens to be more or less halfway between the general average extremes of temperature. Did I mention that I grew up in Russia? Casual temperature range is about -25 to +25.
Or, it definitely is! Pretty much all living beings on this planet, including ourselves, are made out of water for the most part, so these two particular temperatures have everyday practical implications in all areas of life. E.g. refrigerator in the kitchen that will have (usually) two sections: freezer (below 0) and just cold. There is a bid difference between just cold water and piece of ice.
Celsius scale is actually for casual use, not for engineering or science, it is not a SI unit - it'll be Kelvin (which is compatible with Celsius in size but highly impractical in "normal" life due to its scale).
Exactly the same experience. No problem with other measures but temperature in F always feels as a riddle.
BTW, in metric countries measurement systems are also composed of the mix the of scientific SI units and customary metric units outside of it. Like Celsius, for example. At least conversion from C to K is straightforward (and no one uses K temperatures in real life). There are much worse cases, the most obvious one will be speed measurement. Everyone measures vehicle speed in km/h. This is what you see on your speedometer. Yet wind speed in weather forecasts (at least in Russia) is always listed in m/s. I can't relate m/s to km/h, I know how fast is 60 km/h, how fast is 60 m/s I have no slightest idea (except that it'll be exceptionally strong wind, probably a hurricane or so). Also, someone mentioned pressure units... This is another oddity - in Russia weather forecasts use mmHg as a pressure unit. If I select metric temperature scale then the majority of weather software will show me pressure in mBar - which tells me absolutely nothing. Old habits die hard!
Originally Posted by prathmann
I think this is true for many people and is due to the 32F offset between the two temperature scales. I.e. it's not just a ratio but also a fixed offset. For most things we don't need the exact conversion so remembering that a meter is just a bit longer than a yard, that a mile is a little more than 1.5 km, or that a liter is barely more than a quart is sufficient to let us feel comfortable with both sets of units. But with temperatures you need to apply the 9/5 ratio but then also factor in the 32 degree offset to convert C to F and that makes it much less intuitive. My mother had the same comment in the opposite direction having grown up with the metric units before moving to the US. She felt that she always had to convert temperatures to degrees C before they made sense to her.
#86
Quoted: 56 Post(s)
Liked 14 Times
Scientifically, Celsius obviously makes more sense, as does Kelvin (which is just Celsius with the goalposts shifted by 273). For people to describe temperature commonly found in nature, Fahrenheit does make more sense. 0F to 100F is a more or less even range of habitable temperatures. It is also more 80% more granular without having to resort to decimals.
#88
Liked 81 Times
By that logic, it makes even more sense to make 0 absolute zero. Are you a fan of the Kelvin scale, or would calling out room temps as 296K not be acceptable to you
#89
Quoted: 6203 Post(s)
Liked 4,816 Times
If metric makes so much sense, why was it one of the last measurement systems developed?
#91
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
#92
Made us USA folks be able to say
“Rode a Century today” & feel we accomplished something special.
“Did a Metric century today” sounds cool ...compared to “rode 62 miles today”
But we still know it as a 62 mile ride.
Which in its own right, is something special
#93
My point is, you're only a virgin once.
#94
Bikes: 89 Paramount OS 84 Fuji Touring Series III New! 2013 Focus Izalco Ergoride
Quoted: 285 Post(s)
Liked 74 Times
So, what's a 100 nautical mile ride called?
scott s.
scott s.
#95
Passista
Quoted: 870 Post(s)
Liked 721 Times
I'm not understanding this. If metric countries don't use metric units but use a combinatiion of metric units and customary units, what's the point? If you use the non-metric speed km/h instead of the proper SI metric unit m/s, what's the difference if you use mph instead?
#96
Quoted: 1027 Post(s)
Liked 326 Times
#98
Quoted: 2236 Post(s)
Liked 1,314 Times
In Imperial you could also use feet per second (fps) as in ballistics which would equate to meters per second. But for car or bicycle speeds those numbers would be too large and complicated so they use MPH or KPH which, in context, is correct.
#99
Bikes: Novarra Randonee 2016, Trek Verve 2 2015
Quoted: 97 Post(s)
You asked whether km/h is metric. It is not!
Any customary use or contextual argument dos not make it metric. Metric units are the basic units (m/s in this case) or decimal multiples (km/s, mm/s etc).
#100
Liked 2,982 Times
a century translates to me as a ventury.
Venting along the way for a rather longer then usual distance.
-Oh Hey!
-Oh Hey!
