Lezyne floor pump question.
Quoted: 1814 Post(s)
Liked 923 Times
I wouldn't get my hopes up with that one either- Silca used to be good, but now
many dissatisfied users.
Check out the top of the line Specialized Air Tool pump- it's good.
Or Bontrager super charger as suggested by Sy Reene.
Analog easily seen so like that and the screw-on chuck is the only way to go-- a bit tricky undoing ('gotta use both hands and hold the bottom of the swivel). Even so, digital sounds okay too if it's easy to read but not for over $100
Bikes: 2017 Cannondale CAAD Optimo Disc 105
Quoted: 39 Post(s)
That is disappointing to hear. The pump looks like an engineering marvel. Seems like it should work amazingly well and hold up for a long time.
Bikes: 1979 Raleigh Team 753
Quoted: 3377 Post(s)
Liked 371 Times
I have two of theirs. The part I like the most is the thread-on pump head. I can get very short valves do on a larger profile rim, I don't need as long of an extension.
I have the digital gage one. Nice, no big deal IMO. I have the Air Tool and a Silca (30 years old). I use the Lezyne most because of the head.
Farmer tan
I like the twist-on head as well. It needs a new o-ring occasionally, but easy to change.
It takes a bit of skill, but I don't lose any air when connecting it.
Threading on just seems gentler on the inner tube valve for some reason.
The steel drive floor pump has worked fine for me for years.
Liked 371 Times
Adding. The Air tool is a better pump. Heavier and bigger. I may switch heads. The Air Tool is bigger than I like for travel.
Liked 923 Times
Apparently quality control is not so good.
This one looks promising. The only negative that I see is that the gauge goes too high
so that 0-100 psi is about 1/3 of the dial.
https://www.amazon.com/Velowurks-Pri...oor+pump&psc=1
Quoted: 39 Post(s)
Advocatus Diaboli
Quoted: 4760 Post(s)
Liked 1,541 Times
Quoted: 39 Post(s)
Bikes: Soma Saga, 1980 Schwinn Voyageur 11.8, New Albion Privateer
Quoted: 76 Post(s)
Liked 9 Times
I have a lezyne and a joe blow. For the money the joe blow is a great pump. It's my garage pump. The lezyne is also a great pump, smoother operation and very accurate, although it does take a little practice with the threaded chuck. I keep the lezyne in my basement workshop out of the elements.
Quoted: 39 Post(s)
Well I ordered a Lezyne CNC Digital floor pump from REI going to give it a try. I have to say I was very close to ordering a Super Pista on Amazon with a small credit I had on there. But part of me struggled with a $235 bike pump even though it was less than double the cost of the Lezyne I bought.
Quoted: 20810 Post(s)
Liked 9,456 Times
REI has a generous return period, if nothing else.
Quoted: 39 Post(s)
Although I have read a bunch of great reviews on the super Pista I'm half tempted to cancel the order and REI and just get the Silca. They have an amazing warranty if anything ever does go wrong.
Forum Moderator
Bikes: Fuji SL2.1 Carbon Di2 Cannondale Synapse Alloy 4 Trek Checkpoint ALR-5 Viscount Aerospace Pro Colnago Classic Rabobank Raleigh C50 Cromoly Hybrid Legnano Tipo Roma Pista
Quoted: 3108 Post(s)
Liked 6,678 Times
I received the Lezyne Steel Floor Pump for Xmas. I find it a smooth operating, and well built, pump. It has a stable base, a long hose, and an easy to read pressure gauge. After a bit of practice with it I have no issues with connecting and disconnecting the chuck.
Likes For cb400bill:
Liked 923 Times
I ordered the Velowurks pump, & it arrived today.
Initial report: pretty good but gauge doesn't work.
At least my disappointment is $65 worth & not $235 worth.
Quoted: 39 Post(s)
It's a shame about the velowurks pump gauge not working. It is a good looking pump.
Liked 923 Times
Well I didn't order a $235 pump either. I was tempted but realized it was a bad idea. I decided to give the Lezyne a try and will be picking it up at REI tomorrow. Worst case scenario, I have to return it to REI and get something different.
They're going to send another one.
Long hose, tall w/ long stroke, stable.
Chuck is metal & a bit heavy so can bang into things.
Quoted: 39 Post(s)
Well I went to REI to pick up the Lezyne as I set it up for in store pickup and it was damaged in shipping the tab that holds the Chuck at the bottom of the base was snapped off in shipping so they had a new one shipped expedited to my house and gave me 20% off for the hassle. REI has always gone above and beyond for me which is why I continue to buy stuff there.
