Show us your NON Brooks LEATHER saddles
#180
Myrtle Beach Crab
Bikes: enough one would think, but thinking isn't my strong point
Quoted: 271 Post(s)
Liked 542 Times
RMH custom made saddle with Italia stamps and badge, on an old chrome brooks pro frame. Rudi is da man!
#181
Total Scrounge
Bikes: 71 International 72 Super Course 83 Gap
Quoted: 327 Post(s)
Liked 924 Times
Found this at an estate sale today. Doesn’t look like something I’d want to ride, but it might look good on something precious and French.
#183
Bikes: 1980 Marinoni Special, 1987 Ciocc Microf. C40, 1978 Raleigh Competition GS, 1982 Colnago Super, 1972 Gitane Pro TdF, 1976 Belgian Diamant by Martelly, 1989 Trek 520, 1972 Dawes Galaxy 2014 Cervelo R5, 2020 Salsa Warbird, 2013 Giant Trance X1
Quoted: 91 Post(s)
Liked 61 Times
Middlemore
This came attached to an early 70s Gitane I picked up today. Pretty saddle on a sweet bicycle.
#187
Polymultiplié
Bikes: Yes, please.
Quoted: 2220 Post(s)
Liked 4,778 Times
A Lohmann 75B:
Likes For non-fixie:
#188
Palmer
Quoted: 1701 Post(s)
Liked 1,881 Times
Gyes TI-17A
Likes For John D:
#190
Polymultiplié
Bikes: Yes, please.
Liked 4,778 Times
That is a good-looking Idéale!
#192
FalconLvr
Bikes: 62 Falcon, 58 Raleigh Lenton Gran Prix, 74 Raleigh Pro, 75 Raleigh Int, 75 Raleigh Comp, 76 Colnago Super, 75 Crescent, 80 Peugeot PX10, plus others too numerous to mention!
Quoted: 52 Post(s)
Liked 115 Times
Sella Italia “Epoca”, nice saddle, B-17 dimensions.
Likes For evwxxx:
#193
Making up the numbers
Quoted: 112 Post(s)
Liked 525 Times
Almost gave up on this Selle Anatomica when the leather stretched so much the tension bolt ran out of adjustment. However a new set of holes in the nose and a coincidental set of holes along the sides for a shoe lace has given it a better shape and a new lease of life - after a year or two it hasn’t noticeably stretched further.
Nothing quite says wall hanger like drillium toe straps
#194
Quoted: 1869 Post(s)
Liked 666 Times
1. What is that lace or string you used to lash the skirts together? It's amazingly neat, but it looks like copper hook-up wire.
2. S-A recommends using the nose screw to maintain a gap in the carving of 6 mm. This is not a religion, but I've found that following that advice helps me a lot to eliminate pinching. In weight I'm between an X-range and an H, about 190 to 195 #. I can be very comfortable on an old unmarked one, probably now equivalent of a T, set to 6 mm. Have pinching or other discomforts related to the carving been a problem after your surgery?
Likes For Road Fan:
#195
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Quoted: 144 Post(s)
Liked 317 Times
Nice work--very clean all around! Did you use a punch for the holes?
Have used the brand for awhile, 1-series and then 2-series. "Releathered" an X2 with H2 leather last year, figuring the higher weight range probably slows stretching. Interestingly, the two leathers are within a couple grams, so not a hit on total weight. No difference in pliability as far as I can tell.
All my SA saddles develop creaks, and it's devilishly tough to track the source. Most commonly at the nose but occasionally from the rear. But they're sooo comfortable and the fore-aft range is pretty vast. Tension slides used to break but the redesign seems to have stopped that.
#196
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,477 Times
lol my SA-X has creaks undoubtedly because the rails got bent when it flew off my car on the freeway because I forgot to secure the straps on the rack
#198
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,477 Times
lol I posted about it at the time, but can't find it. Maybe 3-4 years ago. Had to replace the rear wheel (bought a rim and laced it with the same spokes) and the bar tape. Otherwise that crosscheck is bullet proof (and apparently freeway proof). I'm just still very thankful that it flew off when I was just entering the freeway, so I was on an extra wide place way off to the right, and nobody was behind me
#199
Quoted: 112 Post(s)
Liked 525 Times
Great work on that S-A! Couple questions:
I have two Selle Anatomica saddles, the X version pictured here and another H version. I bought the T first being a bit under the weight limit but bought the H after the T stretched too much (leading to the fix pictured). Initially I followed the 6mm guidance but now just tension based on the guidance of 1/2” or 13mm dip in the middle. Either way no issues and both have stayed around 6mm cutout width.
When I get around to it I’ll have the H punched as well but will use six instead of four holes to spread the load, not that four has caused issues.
I’ve had issues with creaking on both saddles and have tried various fixes. All that seems to work for me is spraying silicone lubricant onto the U-shaped carrier where it contacts the V of the rails under the nose. A little from either side every few rides.
Just swapped a Rivet Ti-railed saddle onto my Ron Cooper, will see how that compares…
Likes For seagrade:
#200
Quasi homeostatic system
Bikes: '81 Fuji America, '82 Team Fuji, '85 Nishiki Bel Air, '98 Klein Stage Comp R
Quoted: 48 Post(s)
Liked 205 Times
I'm picking picking up a Rivet next week. Leaning towards Ti rails as well. Not that I'm after the weight savings but the extra flex wouldn't hurt. Everybody I know ridding a Rivet comments on how much longer it takes to break them in vs a Brooks but it's worth it.
