Ever get that feeling a bit into a ride like your tires are flat?
well hello there
Quoted: 503 Post(s)
Liked 336 Times
Sure. And every once in a while, I'll stop, lean over, squeeze the tire and be surprised that it's NOT flat.
Klaatu..Verata..Necktie?
Quoted: 10444 Post(s)
Liked 11,925 Times
I have a term for the feeling of weariness and annoyance you get when you try yet again to shift to a lower gear, only to discover, yet again, that you're already in your lowest gear - exhausperation.
Likes For Flip Flop Rider:
lol. happened yesterday to me toward the end of my 50 mi ride. I think it was because my legs were tired after a 200mi week. Time to recover I guess. I actually stopped to check the tires and the brake pads haha.
Funny question because I get the flat/low pressure feeling once every few weeks. Glad to hear I’m not the only one this happens too. It often isn’t just the fatigue but it’s that my rear wheel feels kind of squiggly as if tire pressure is half what it should be. I just keep grinding away and usually I forget about it.
Quoted: 769 Post(s)
Liked 1,748 Times
This was my day Saturday into a 15-20 mph head wind....
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times
I have got off the bike and spun the rear wheel to make sure it wasn’t rubbing on the frame or brake.
It wasn’t.
It wasn’t.
Sr Member on Sr bikes
You’re experiencing introinversiodirectional complex. Bicycle tires, it appears, thought to be otherwise inanimate objects, have a sensory aptitude and can sense when they’re going the wrong direction. When they sense this, wanting to go in the right direction, they can present a slight amount of resistance which can make the operator feel as if the tires are under-inflated. If you go to the other side of the road, or mount the tires backwards, the introinversiondirectional complex can be overcome.
Dan
Likes For _ForceD_:
Have gotten into a ride a short ways and the legs start saying we are done. I tell them to shut up and 5-10 minutes later everything is fine. Not sure if that is what you meant.
Likes For tornado60:
Bikes: 1995 Specialized Rockhopper,1989 Specialized Rock Combo, 2013 Specialized Tarmac Elite
Quoted: 213 Post(s)
Liked 588 Times
Headwind will do it for me. Also chip seal. Or a headwind on chip seal.
Quoted: 2604 Post(s)
Liked 1,934 Times
I'm not sure which I dread most -- feeling the tire(s) and finding it's not flat, or feeling the tire and finding it is going flat. Or done gone flat.
Likes For pdlamb:
Having been an in-line skate competitor in a previous life (i.e. Rollerblades) I found out pretty quickly why we feel a tire is low. I'm pretty sure it's the texture of the pavement that does that.
On skates, some pavement just glides and others, that are just as smooth just don't run fast. For instance, it was my experience that smooth pea-gravel sized asphalt even though it was rougher was usually pretty darn fast. Fine-textured asphalt although smooth, it felt like the skate wheels dug into the surface and was slower. Maybe less surface contact translates into more speed?
I think to some degree that applies to bikes also. However, now that I run a lower pressure on my road tires (Challenge Strada Bianca's) I don't notice it much any more.
Likes For drlogik:
Quoted: 365 Post(s)
Liked 419 Times
It's interesting that most people interpret the question as asking whether we feel slow.
I do, not infrequently, get a feeling while riding that a tire(s), normally the rear tire, is flat. But that is due to a feeling of squishyness, not slowness (well, I'm always slow, so...). Often it seems to be due to a change in the road surface, but sometimes I can discern no reason for the feeling. After checking (visually) a few times, normally the feeling goes away. Paranoia, maybe?
Likes For noimagination:
So what's with chip seal that makes you feel like you have a flat? Is it adding resistance to your rolling tire? Does it compress when your tire rolls on it? Are we actually slowing down?
Who here has a scientific answer for this phenomenon? I'm sure we all have a theory? What's yours?
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Now that I have started riding wider tires at less than the max pressure, I feel it all the time.
It's like riding a bicycle
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2591 Post(s)
Liked 5,660 Times
Not a scientist nor do I pretend to be but the answer seem rather simple - at least to me! The more friction of the surface, the greater the rolling resistance. Not to mention it is just sucks to ride on it. Of course if you get to ice, then the theory doesn’t hold.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Quoted: 970 Post(s)
Liked 1,632 Times
Yep... Just like an FOD Walk on an Aircraft Carrier or any flight line for that matter. And then if you find something ya damn better know where it came from too...
