Tubes are faster
Likes For robbyville:
Quoted: 446 Post(s)
Liked 1,045 Times
That video went from talking about tubes and tubeless to investing in contemporary art? WTF!
Anyways, I generally like tubeless once setup, but for hill climbing I do prefer TPU tubes and clinchers.
Likes For jonathanf2:
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
As soon as you add sealant to a tubeless tire, the rolling resistance advantage changes. A clincher with latex or TPU tube has lower rolling resistance than a similar tubeless with sealant. At the same pressures.
Should Be More Popular
Quoted: 22609 Post(s)
Liked 8,930 Times
I still prefer latex but TPU is certainly a fine option. I have yet to drink the tubeless kool-aid.
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
I thought the video was pretty well done. He obviously spent quite a bit of time with camera angles, different shots and editing. I wish he had done the tests using the same tire model tubeless versus tubed tires though. Especially since he worked at a bike shop I would think he could access the tires.
He made good arguments for why he preferred tubes and running at higher pressures. I also thought he did a pretty good job describing how the ride quality was the different between the set ups.
Did he convince me one was faster than the other? No, but I liked the presentation
Likes For Symox:
Quoted: 3241 Post(s)
Liked 2,512 Times
Liked 2,512 Times
As a 5'8" 200lbish rider, with that weight somewhat concentrated, squishy feeling tires are not good. When you get out of the saddle to climb, most of that weight shifts(or at least feels like it) over the front wheel. Suddenly it feels like you're front tire's going flat or the brake is dragging. For me the feeling gets worse as the rim/tire gets wider.
Quoted: 338 Post(s)
Liked 408 Times
I've ridden latex tubes for a while with tube type GP5000 tires, the decision to go to tubeless was a deliberate sacrifice of a small amount of rolling resistance to get the puncture resistance and comparatively less faff of tubeless (I've even toyed with airliners which really do work as a run-flat system, but now I only do it on my commute bike because honestly the tubeless GP5000s have had one puncture in 6000km and even that held a rideable enough amount of pressure to get home, without changing tubes in the dark).
The differences in the video, anyway, are due to the pressure difference. You're going to be hard pressed to measure a speed difference in the wild between latex, TPU and tubeless (with, say, 30ml of sealant) at the same tire pressure because we're talking about differences of about 0,1 W per tire at 100 psi.
