Retro roadies- old frames with STI's or Ergos
#227
Dolce far niente
Quoted: 20 Post(s)
Liked 17 Times
Cinelli Super Corsa:
"Love is not the dying moan of a distant violin, it’s the triumphant twang of a bedspring."
S. J. Perelman
S. J. Perelman
#229
Quoted: 2953 Post(s)
Liked 3,106 Times
I decided to swap the 10 speed group from the Caldaro to the Gazelle. I like this bike a lot: light, stiff, fast.
#232
Running on plenty
#234
hi
Quoted: 7 Post(s)
1975 Woodrup with DuraAce 7400. Running an 8-speed rear with first year DuraAce brifters I believe. Works, looks, and rides beautifully I think some white bar tape would be better suited for it now that I look at it, but the black will have to do for now.
#235
bear
Bikes: '06 Scott S20, '04 Trek 3700, '88 Schwinn Tempo, '86 Schwinn Tempo, '85 Centurion Le Mans RS, '84 Univega Gran Tourismo
Schwinn Tempo with 105 and Tiagra shifters.
#238
Permanent Refugee .......
Bikes: Steel
One of my favourite bikes.
Merckx, Corsa Extra. Columbus SLX, Campag Chorus 10 speed and a dream to ride.
#239
Wow, I love this thread. My only road bike other than my beater commuter, is a 70's era Coppi Campionissimo, that I've upgraded somewhat, and now I'm thinking of going to STI shifters. I'm not going to post a picture until I can get the frame repainted, though.
These are some *gorgeous* bikes! This poor schoolteacher can't touch stuff like that.
#240
Bikes: Steel
#242
I love this thread. I have an 80s Cannondale that I've thought of upgrading to STI. It's got mostly Shimano 600 parts - 6 speed freewheel, 126mm spaced rear, indexed downtube shifters, etc. Could someone tell me if it would even be possible to switch it to STI, and what I might need? I've been under the impression that I could just get 7 speed Shimano brifters, a 7 speed freewheel, and maybe a new rear derailleur to make the switch, but something tells me it wouldn't be that easy. Thanks.
#243
Surf Bum
Bikes: Lapierre Pulsium 500 FdJ, Ritchey breakaway cyclocross, vintage trek mtb.
Quoted: 13 Post(s)
Liked 5 Times
I'm considering doing the same thing to my 85 trek 600 which also has shimano 600 right now. We'll figure it out one way or another: this thread is good inspiration.
#244
RE******
pacificaslim, you shouldn't have any trouble with an old Trek 600. You'll just need some downtube shifter-boss cable routers, along with whatever component group you pick.
#245
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
modernized rossin.
veloce 09' shifters with tiagra cranks, 105 RD, ultegra FD, mavic cosmos wheelset
fork was replaced because of an accident.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
#246
Liked 5 Times
not sure if you'd call this retro or roadie, but a columbus brain tubing CX bike
#247
The hardest part is going to be the spacing. Modern STI stuff (everything eight-speed and on) uses 130 spacing. It's not a big deal with steel road bike, because you just spread the rear triangle apart and insert your 130mm hub, but with aluminum (as your Cannondale is), you're stuck with the 126 spacing. Some people say you can cold-set aluminum, but I've never seen it done. What I have seen is bikes destroyed in the rear triangle from fairly minor crashes or from being slightly bent during shipping. I know that my shop won't reset aluminum, but you might find someone more skilled who can.
#248
Liked 5 Times
it's spaced for shimano 9sp so you'll be able to use shimano 9sp STIs or campy 10sp ergos.
#249
Kinda wish I hadn't seen this thread......Here's what I'm starting with:
Planning to add a Ultegra / Mavic Open Pro wheelset (annodized grey) and a new crankset (yet to be determined)
For the sake of saving money, I think I'm going to use downtube shifters unless I can find a screaming deal on some shifter/brake lever combos. (had to look up "brifters" might take a bit to work it into my vocabulary)
Great looking bikes fellas. Thanks for the inspiration
#250
bear
You could do that. I bought some 7 speed Sora's on ebay for about $100 and put them on my wife's commuter bike. You might be able to use the rear derailleur. I have on some bikes, but not others. My guess is that you will have to change the front derailleur. I haven't had any success using what ever was on the bike. The shifters came with the cable stops and then the front derailleur was $20. So she had STI shifting for about $120.
