ISO and for trade thread part 5
#5776
Señor Member
Quoted: 1500 Post(s)
Liked 1,103 Times
Sun Tour friction shifters. Prefer short with rubberized/plastic covers.
I'm in DIY bar-con mode, and I have a good start with the parts that fit into the end of the bars, but I'm lacking the levers, washers and tightening mechanisms. If you have a set of borked bar-cons, or neglected clamp-ons and are looking to get something useful in trade, give me a ring.
#5778
Quoted: 1116 Post(s)
Liked 1,340 Times
Wanted - Suntour Symetric shifter mounting band(s)
I have these three and would like to try at least one out, it sounds like a great idea - why didn't it catch on?
#5780
Bikes: many
Quoted: 1457 Post(s)
Liked 1,408 Times
My guess is timing. Shimano was probably perfecting early versions of SIS about the same time. That, and the trend toward integrated groups, making it less likely that a mixed group would be on a new bike.
#5781
tantum vehi
Quoted: 1169 Post(s)
Liked 993 Times
I’ll check when I get home, but if I have one, you’ll have to take the entire thing.
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#5782
Quoted: 1625 Post(s)
Liked 2,671 Times
There was also a clamp version. There's a few on eBay right now, like this one:
https://www.ebay.com/itm/255782638400
#5783
tantum vehi
Liked 993 Times
Found - PM sent
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#5784
Bikes: Motobecane C41, Matsu$hita Nashonaru
Quoted: 215 Post(s)
Liked 439 Times
#5785
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3918 Post(s)
Liked 6,540 Times
I don't find it difficult or exhausting to trim either derailleur, so the use of Symmetrics never appealed to me. I did though enjoy overhauling them and the chance to reverse the internal cam to use a reverse normal fd for the rare flip that had one.
Likes For SurferRosa:
#5786
Quoted: 215 Post(s)
Liked 439 Times
Oh, there's no problem with that. I just grew lazy and complacent. My main commuting bicycle has BB spindle a few mm shorter than specified / recommended for the correct chain line and also the casette currently at the back is 7sp instead of 6sp freewheel to match the era of the other components. As a result I can basically shift from highest to lowest gear (on the big chainring at the front) and back without ever catching the front derailleur cage (not that I use more than 5 gears on that one). Which is not the case with my other bicycles. Trimming is a thing whilst riding them.
#5787
Edumacator
Quoted: 2513 Post(s)
Liked 3,282 Times
The elusive search for the perfect length continues!
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Likes For jdawginsc:
#5788
Edumacator
Liked 3,282 Times
That was my precise plan. I also send 8 speed derailleurs when people ask for 7 speed. I know they underestimated...
#5789
Bikes: a few..
Quoted: 82 Post(s)
Liked 150 Times
Likes For mtbikerjohn:
#5790
Edumacator
Liked 3,282 Times
I can screw that up too!
#5791
Quoted: 4538 Post(s)
Liked 6,454 Times
Campy NR or Sugino Mighty Comp track/pista crank, the longer the better, DS arm only to complete, with or without chainring.
Will trade complete road minus BB of either, $$$, or?
TIA
TIA
#5792
Quoted: 1320 Post(s)
Liked 1,945 Times
Van, Like this?
Lemme know, Smiles, MH
#5793
Señor Member
Liked 1,103 Times
ISO - 7 speed freewheel in good condition with 28 tooth large ring.
Have - a reasonably good assortment of things - ask.
#5794
señor miembro
Liked 6,540 Times
In case you don't find a nice vintage one, I've been very happy using these the last five years or so:
https://www.ebay.com/itm/175249444991
#5795
Liked 1,340 Times
(Still) looking for Super-Maxy left crankarm
Had a lead on one but it's turned out to be a nogo, so I am still after a non-drive-sidearm to match the niceish triple what would suit a particular project....
#5796
Señor Member
Liked 1,103 Times
#5797
Liked 6,454 Times
#5798
Señor Member
Liked 1,103 Times
#5799
Señor Member
Liked 1,103 Times
Perhaps I've gotten used to some cassettes and also some freewheels that have cutouts - and consequently weigh a good bit less.
#5800
Ride, Wrench, Swap, Race
Quoted: 1566 Post(s)
Liked 1,302 Times
I think that the newer Shimano freewheels might be the lightest ones in this day and age, the body is pared away and some of the cogs are pinned (so with a much larger central cutout).
Maybe silver paint can save their looks? I've seen it done and the paint seems to make minimal contact with the chain except at the teeth.
I've found spray paint hard to remove from a freewheel for what that's worth.
The E-bike industry has has resurrected freewheel development, some are even 10-speed now! Many hub motors still use freewheels and solid axles (with perhaps the non-drive side of the axle made hollow for the power wire).
I bought the Sunrace 11-36(?)T 10s freewheel, and was going to narrow it by removing the 11t and shortening the threaded (for a lockring) body using a grinder.
But the thing 1) weighed a ton, 2) positioned the big cog a bit too far from the spokes, and 3) oddly had the freewheel tighten/bottom onto the hubshell shoulder against a plastic sealing ring that deformed and caused drag immediately. So I sent it back. Mine also had a rare spacing error between a couple of it's cogs!
I did communicate with Sunrace, who offered as "an exception" to replace it (even though it was considered by them to have been sold out of their controlled market), but I ultimately simply returned it to the Ebay seller.
