Tube Tire Pressure recommendations
Old 02-25-21, 04:24 PM
Quoted: 2976 Post(s)
Liked 1,182 Times in 771 Posts
Originally Posted by milesf
Is it really ok to go below 25 psi with tubes? I thought that to go lower than that without getting pinch flats, you needed to be running tubeless.
As long as your not 300 lbs its fine.
I'm about 190 kitted up. I have tubes in my hardtail and I run 22 in the rear and 20 up front. Any more than that and the ride becomes less enjoyable.
prj71 is offline
Old 02-27-21, 06:53 PM
Advanced Slacker
Kapusta's Avatar
Quoted: 2762 Post(s)
Liked 2,537 Times in 1,433 Posts
At your weight, it may well be.
I’ll say this one more time: The ONLY way to know the best pressure to run is to start a tad on the hight side and drop a psi or two each ride until you start getting pinch flats, then bump it up a psi or two.
I guess the other way is start low and keep increasing pressure until you stop getting flats, but that could be a lot of flats.
Kapusta is offline
Old 03-06-21, 05:46 PM
Bikes: 2016 TREK Domane 4.5 Disc/2006 Marin Mt. Vision/2009 TREK Madone 4.5
Liked 7 Times in 3 Posts
OP and everyone who contributed to this thread, thank you!!
I just picked up my first ever tubeless bike (2021 DiamondBack Release 3) and learned quite a bit about tubeless set up!
HotLap is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
