Shimano Sora vs 105
Quoted: 2432 Post(s)
Liked 641 Times
I don't care about the chain because I run SRAM. I already mentioned the cassette. Cables would be no detectable difference. 300 grams away from 2 pounds is almost one pound, like I said lol
Quoted: 68 Post(s)
Quoted: 68 Post(s)
No one is arguing that heavier things are heavier.
* The OP was talking about a difference in just the groups (everything else kept the same).
* What real world performance difference is the OP going to see with a difference of < 2 pounds?
* Cost is the part of the equation that you conspicuously left out.
Quoted: 4286 Post(s)
Liked 1,377 Times
That's not a sufficient answer either.
How different is the acceleration going to be for < 2 pounds of bike (not wheels)?
And the difference in weight is might only be on the order of 132 g (1/4 pound).
The difference is going to be small. That small difference might be worth the usually significant increase in cost to a racer but it's likely not going to matter for the OP.
So an off the shelf Sora equipped bike and an off the shelf 105 equipped bike are likely to have almost identical framesets/forks and wheelsets with regard to weight and quality?
As an example: I wouldn't be surprised if the Sora bike came with an alloy or steel fork.
The point about partial groupsets is also useful when shopping around.
Perhaps the OP needs to share specific model names and year of the bikes being compared to get better feedback here.
"Cherry picking", is when you put something nicer looking where its visible, then scaling back the cost elsewhere on parts less visible, to compensate and still make the price point attractive..
Liked 1,377 Times
In any case, the OP was asking only about the group (keeping everything else the same).
If the OP is talking about actual bikes, he would do better letting people know what they are.
Bikes: 2018 Lynskey R 260 Disc; 2008 Trek 4.7 Madone; 2017 Framed Minnesota 3.0 Fat Bike; 1984 Nishiki International
Quoted: 111 Post(s)
Nothing like useless advice....
It is definitely the "standard" meaning it is more or less right in the middle of the pack.
Quoted: 6278 Post(s)
Liked 4,864 Times
Well you didn't say what model 105 or Sora. Those in themselves are just names for a performance level or product tier. Sora is and has been a 9 speed group since introduced I think. Current 105 R7000 or slightly older 105 5800 series are now 11 speed groups on the rear. But at one time long ago 105 was just 5 speed. I think, Let me know if memory is faulty though.
So from my opinion, it's all about gears. Why wouldn't you want eleven if it is a 105 5800 or newer? More choices for hills long and short. More choices for tired legs at end of long ride. Makes a big deal for me. Particularly the hills. It's nice to have gears so close in ratio that you can click once to the next higher ratio gear with out killing your cadence on a climb. Sure you can do it with a 3x5 but you kill your cadence still by having to shift mutiples and you have to know what gears you are in and what you have to go to to find the next. On my 105 5800, the front double is now thought of as a single speed and the action takes place on the back 11. Especially with a 52/36 or 53/39 front.
As far as weight, unless your body is to the point physically where you can't get any more watts out of it, then the little weight difference isn't going to help you. So don't buy for weight alone.
I think the op will get very poor quality hookers, porn, drugs, and guns at that price. Op should choose two out if the four to maintain 105 level of quality.
Likes For San Pedro:
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Quoted: 1031 Post(s)
Liked 208 Times
Liked 4,864 Times
Of course all this also depends on what you consider your requirements for your maximum tooth and minimum tooth. I run an 11-32 on the back of my 11 speed with a 52/36 on the front. That gives me 8 gears with just 1 or 2 teeth difference. I don't think any 9 speed cluster will do that with 30 or more teeth on the largest unless it's a custom built.
I'm still well in the 1 tooth gear range when I hit the hills. So since I'm not strong in leg muscle, having more one tooth shift options are a plus that allow me to accelerate on some hills that my former 7 speed cluster never gave me. With my 7 speed 14-28 a shift on a hill to a higher ratio killed my cadence and speed.
But true, the 9 speed cluster can give you the same number of 1 tooth shifts, but only if you don't need more than a 26 maybe 28 on the rear. Since I don't want to be bothered with shifting the front, I need a 32 as well as the 11.
It might.
I have Campy on the current bike, and it is old enough to vote... I am pretty sure Veloce and/or Athena would not have held up as well.
I rode two Specialized bikes this weekend, same exact model, one with 105, the other with Rival 22.
Personally, I though the Rival was superior, but then it is slightly more expensive.
No difference to ride quality.
...finding 105 technology on a new $900 bike won't be easy and assuming it's impossible-- further assuming it comes in at something in the neighborhood of ~$1,500, what then?
Liked 208 Times
Maybe, maybe not. Think it depends on leg strength which I don't have. I depend on cadence. So when in the higher ratio's on the back, it's nice to have that many extra one and two tooth changes before getting to the bigger tooth changes on the low ratio gears (bigs)
And, here are the ratios for a Shimano 9 speed 11 - 32 cassette. 11, 12, 14, 16, 18, 21, 24, 28, 32
Given what you said about not having the strongest legs, chances are you are climbing on the largest 4 cogs. With the 9 speed,, that is 21, 24, 28, and 32. And with the 11 speed, it is 22, 25, 28, and 32. The only difference is on the 9 speed, a 4 tooth jump between 24 and 28, compared to a 3 tooth jump on the 11 speed between the 25 and the 28. As you can see, the only difference between the 9 and 11 speed is one tooth jumps in the range of the cassette where you can't practically use for climbing.
Liked 208 Times
That was my thought. Sora is in the cheap and cheerful range. 105 equipped bikes are usually much more money, unless you are getting a screaming deal, or a generic bikes direct special.
But the OP's premise is off - I don't believe you would find the same bikes, one with Sora and the other with 105. Even Tiagra and 105, they usually have different wheels and other components, no? So I think it's kinda moot.
105 is better than Sora, how much $$ better is up to the individual.
Liked 208 Times
I just did a quick look at Performance Bike and they have sub-$100 bikes with 105, but probably not everything (Tektro brakes and that sorta thing).
Quoted: 1235 Post(s)
Liked 189 Times
I've seen more problems with 5800 come through my shop than any other shifter. R3000/4700 are objectively better from my point of view. They shift better for longer and are less sensitive to cable and housing quality. How many 5800 bikes have you worked on? I'm well into several hundred at this point in my career.
Bikes: Fat City Monster Fat, BMC Roadmachine, Trek Emonda, Trek 2100, Specialized Rockhopper
Quoted: 21 Post(s)
That's not how you use the term wheelhouse.
As an aside last time I test rode bikes, front derailleur performance/shifting was noticeably better starting at the 105(5800) level. Don't know how much has trickled down?
