A Yuuuuge Improvement in Braking Power!
I'll take this opportunity to point out why I like rim brakes. Because the rims are already there, and always will be. Rim brakes are an elegant solution. Disks for road bikes? Perverse. I won't deny their occasional advantages, but I just don't find them significant, and I kind of feel sorry for the people who think they're necessary.
Quoted: 131 Post(s)
Liked 21 Times
The newest Shimano brakes 105/Ultegra/DA use a roller cam design of the arms to increase the leverage and force to the rim. Something Campy or Tektro do not have. That's why they get rave reviews. It's not hype.
Quoted: 18883 Post(s)
Liked 10,646 Times
I don't care about the entire market, and neither do you. We care about bikes we own, and bikes we might in the future. We also care about how bikes are evolving.
In that sense, Cervelo has proven that from a frameset perspective, there is a weight benefit to disc brakes. We're not talking about the Walmart bikes that outnumber boutique bikes in the world, we're talking about what's possible.
Besides, there are other bikes than the R5 that have no or vanishingly small weight penalty. And there will be more.
Non omnino gravis
Quoted: 285 Post(s)
Of course one bike from any manufacturer isn't representative of the entire market, don't be silly.
note: this claim is clearly false. seattle is referring to a 20 gram reduction in the weight of a frame, which obviously does not offset the weight penalty of over 4/5 of a lb in the wheels and groupset. Seattle you should teach a course entitled Lying to Yourself and Others 101
Sadly, your inability to face facts means you must engage in constant duplicity by referring to a reduction in the weight penalty as a benefit and other such forms of orwellian doublespeak. Yes, a 20 gram reduction in the weight penalty is a tiny reduction in the weight penalty but this is in no way shape or form a "benefit."
I do enjoy your posts however. It's a glimpse into the strange delusions of someone who refuses to face facts at all costs.
Quoted: 285 Post(s)
There's no getting around the fact that a much larger surface area for the pad provides superior braking power.
I suspect that this single hack alone would narrow the gap between rim brakes and hydraulic disc brakes to zero in wet conditions.
This a massive assumption (and in my experience entirely not true) but even if it were, I'd still prefer discs because I would not be losing material off my rims every time I tried to slow down or stop.
Quoted: 285 Post(s)
The larger surface area does nothing for you. Friction force is dependent on the normal force and the coefficient of friction. By sticking with your original caliper and your same hands, you have not altered the normal force in any way. Your rims are presumably smooth yielding a consistent surface with which the brake pad will contact at any given time regardless of pad size so your coefficient of friction is not variable based on pad size. So the only way you are generating more braking power is by changing the coefficient of friction with your new pads. Your new pads would do that regardless of size, however, being larger does mean they'll last longer. But that's it. The standard road size pads in the same compound would give you the same braking power.
2nd, it's not an assumption it's a hypothesis which could easily be tested. Go take a look at the GCN comparison. Only an idiot thinks a crabon rim is an ideal surface for braking. Common sense dictates that wet braking disparity is significantly reduced, likely halved with alu rims, if not more. Add a larger pad, re: the hack I describe, and that reduces the gap even further, possibly eliminating it altogether.
I dare anyone to conduct a valid comparison. I guarantee no one will do so because the entire cycling industry will look stupid. Even if discs wind up with a small advantage very few riders appreciate an extra lb of weight plus a 10 watt disadvantage due to aero drag.
Discs are a gimmick and a marketing scam. I can see discs being advantageous for riders who a) ride in sludge a large percentage of the time and b) are too lazy to wipe down rims and pads after wet rides. Otherwise, there's precious little to recommend discs for road use.
And there's no reason to avoid wiping down rims and pads after a ride in the rain or mud. After all, you have to clean and oil your chain-what's a couple of extra minutes to wipe down rims and pads?
Let's say you ARE too lazy to wipe down rims and pads. What's the cost of total negligence? A durable entry level wheel costs $60 to $70 at an lbs. Even less online. Let's say you trash 2 wheels a year. That's an investment of $120 a year. Hardly a king's ransom.
How much does an entry level road bike with hydro's cost? $3K or so. It would take TWENTY FIVE YEARS of annual 2 wheel replacements every single year to match the expense of a new bike (after all you can't upgrade the brakes alone). And you wouldn't even be paying up front. You'd pay in tiny installments, and only if you totally neglected any semblance of maintenance whatsoever.
Farmer tan
To put it politely, this ^ is total drivel. I overestimated the size disparity but the linear pull pads are nonetheless much larger (if not 4x the size in total surface area) and generate vastly more stopping power. Try it yourself on your road. You'll notice a similar advantage especially the stock dual pivots are junk like the axis'. Armed with very large linear pull pads stopping power is excellent and very little effort is required at the lever.
1st of all, you don't have any experience with my setup because you haven't swapped out the stock pads on your dual pivots for the dual compound kool stop linear pull pads.
Discs are a gimmick and a marketing scam. I can see discs being advantageous for riders who a) ride in sludge a large percentage of the time and b) are too lazy to sipe down rims and pads after wet rides. Otherwise, there's precious little to recommend discs for road use.
Quoted: 285 Post(s)
To summarize briefly, there's no conceivable reason to "upgrade" to hydros. The only reason/s for doing so are to chase a fad or because the industry offers no choice.
In addition to the a) exorbitant cost, b) aero/watts disadvantage, c) impossibility of upgrading the brakes alone, d) lack of any discernible performance advantage, e) weight penalty, there is also the fact that f) disc brakes are inherently and objectively ugly.
What's interesting however is how emotionally traumatized and/or triggered road hydro users are at any hint of a rational, evidence based discussion of the pros and cons of different braking systems.
It's as if you were criticizing an estrogen addled fifteen year old teenaged girl about her choice of makeup.
Quoted: 4845 Post(s)
Liked 3,972 Times
I get a kick out of all there efforts to increase stopping power. Three of my bikes have more stopping power available than I find good or beneficial for good control, especially when I need to slow down a lot. (Two Shimano dual pivots, not new and Shimano old-school cantilever.) I de-power those brakes with V-brake levers and find I can stop much faster safely and without surprises. (Most of my brakes have various Kool Stop pads of normal road lengths.)
I have found however that some calipers are poor. With levers that work well on other brakes and my hands, I find the old Campy NR brakes poor in the dry, scary bad in the wet. I won't run Weinmann centerpulls or their copies in front, especially on a bike that will see rain. (I put them in back and use Mafac Racers in front.)
The funny one is that the $10 unmatched used (and partially trashed) sidepull calipers I put on my ultra cheap fix gear had, with ordinary Tektro levers, great dry road stopping power!
Ben
Ben
Quoted: 20810 Post(s)
Liked 9,456 Times
...A durable entry level wheel costs $60 to $70 at an lbs. Even less online. Let's say you trash 2 wheels a year. That's an investment of $120 a year. Hardly a king's ransom.
How much does an entry level road bike with hydro's cost? $3K or so. It would take TWENTY FIVE YEARS of annual 2 wheel replacements ...
BTW, an "entry level" road bike with hydros is not $3k; You can find a number of carbon bikes with hydros in the $2000-2500 range and I would imagine that going with AL would drive the price even lower.
Quoted: 285 Post(s)
Don't forget the kitty litter and adderall!
Liked 9,456 Times
Quoted: 285 Post(s)
Quoted: 7666 Post(s)
Liked 3,530 Times
Wow ... this thread is rushing sideways at a high rate. Even for a disc-brake thread.
Voice of the Industry
Quoted: 1188 Post(s)
Liked 8 Times
pan y agua
Quoted: 1459 Post(s)
Liked 735 Times
We've been this over this ad Infinitimum.
If you look at comparable bikes with comparable specs from the same manufacturer, the disc version typically ways more than the caliper version by +/- closer to 2 pounds.
Whether that difference matters, or is offset by an advantage from discs is a different debate.
But it's just not true to contend that there is not a total system weight disadvantage to discs as it currently stands
pan y agua
Liked 735 Times
And all this said I personally like my 622 mm discs
Liked 10,646 Times
Yeah because it's more than a pound.
Cervelo R5 Disc weighs 19 grams less than their R5 Rim, fameset only. Enve SES 3.4s with DT hubs are 50 grams heavier in disc. RS785 is 340 grams heavier in hydraulic disc. Grand total of 370 gram weight penalty.
Is a Cervelo R5 comparable to a Cervelo R5? Yes.
Is 370 grams 2 pounds? No.
Quoted: 1422 Post(s)
Liked 7 Times
Disc technology keeps evolving. This ^ is slightly out of date.
For example, it suggests that disc braking imposes a 70 gram frameset penalty. Cervelo’s best road bike (R5) is 20 grams lighter in disc than rim. Their next best road bike (R3) is the same weight regardless of brake system, down to the gram. We’re talking frame and fork here.
Enve’s SES 3.4 wheel with DT hubs (the ones I bought) is about 50 grams heavier in disc than rim.
Even at the Ultegra level (RS-785) hydraulic discs impose a 340 gram penalty for the entire groupset.
Lots of ways to build a bike. In this particular case, hydraulic discs add about 370 grams over rim brakes, about 3/4 pound, and we’re only talking about Ultegra stuff. Plenty of room to go weight weeny on that still.
Anybody that's stressing about 12oz is way too OCD.
Non omnino gravis
As a person who owns a bike with good disc brakes as well as a bike with good rim brakes, I can say with authority... they will both stop a bicycle. Discs modulate better, and absolutely do not care about the weather. I can brake every bit as well in pouring rain as I can on a sunny afternoon. Rim brakes are simpler, lighter, and less fussy.
I've said this in other threads, and I think it bears repeating: We can actually exist in a world where we all like different things. Personal preferences exist. Rim brakes are not intrinsically inferior to disc brakes, and vice versa. They both work. They can stop a bicycle.
