Moore's laws for lights?
(But we're now splitting hairs here. Yes, some might describe me as a "computer nerd", also an "electronics nerd".)
I think the OP was referring to the fact that the lumens light output seems to be racing ahead much like the number of transistors in ICs (i.e. Moore's law) and much like transistor density, eventually we're going to hit some brick wall where we reach a limit and have to use parallel LEDs to gain further brightness. (Like todays CPUs: going to multiple cores)
I am a caffine girl
Bikes: 2012 Stumpjumper FSR Comp...2010 Scott CR1 CF...2007 Novara FS Float2.0...2009 Specialized Hardrock Disc...2009 Schwinn Le Tour GSr
Let's look at this another way ...
One amp at 8.4 volts is 8.4 watts. 3000 lumens/8.4 watts = 357 lumens/watt, which is significantly higher than the theoretical limit for a white LED, and significantly more efficient than any light of any sort in the real world.
Either 8.4 volts, 1 amp or 3000 lumens is a lie ... they can't all be true simultaneously.
I am guessing each LED with be consuming about at least 3 watts of power since the forward volt is at about 3v when the emitter is driven at 1 amp. The light might be consuming at least 21 watts of power. The claim on the runtime may be accurate depending on the size of the battery use. I see the 2-3 hrs runtime claim as possibly true only if the 1 amp claim is the spec for the drive current of each emitter and not actually the draw from the power pack.
I think DX is quoting the 1 amp spec as the driver current for each LED. If that is the case then each Led is drawing 1amp at the emitter. The Cree spec for 1 amp at the LED will yield 388 lumens. The light has 7 led and thus the total lumens should be about 2716 lumens. The claim 3000 lumens is close enough for me considering how wild some other company or seller will claim exponential lumens from their light.
I am a caffine girl
Sounds feasible, in which case someone who wrote their specs up forgot about Kirchoff's Current Law, there are probably in a couple of strings of LEDs that are then parallelled. Maybe 3 pairs of LEDs then one lone one on its own PSU channel?
Bikes: Bacchetta Giro, Strada
I didn't say or even imply that it did. I also invoked the largely tongue-in-cheek suggestion that number of blades in a razor blade might follow a similar progression, to further suggest that it would be absurd.
All of that was really just a joke, one that I thought was quite obvious ... but the seven emitters in this ugly beast certainly is quite an oddity.
BadBurrito
26
07-30-16 08:21 PM
claystevens
13
01-22-14 10:00 PM
dougmc
6
08-05-11 06:44 PM
