I broke my 2nd derailleur! what am I doing wrong?
Quoted: 3514 Post(s)
Liked 2,927 Times
Not sure if he's necessarily in over his head, but he needs to 1) get educated on what he's doing--and why (i.e., read, watch videos, etc.), and 2) tap into his inner mechanic. The one that would say, "instead of me putting the derailleur hanger into a bench vice, standing on a stool and torqueing the entire frame to bend one small piece, maybe it's easier to keep the frame still and just straighten the part that's bent? In a manner where I could actually--even if just visually--determine its alignment."
As a corollary, we've got to get rid of the part of him that wants to say "How else would I do it??" With responses like this, he's showing he can't (or seemingly doesn't want to) think outside the box. And with bike mechanics, this is something you need to do a lot.
Likes For smd4:
Bikes: Cannondale Bent 2, Fuji Royale, Mongoose Snare
Quoted: 103 Post(s)
Liked 8 Times
It's essential if you plan on working on your own bike that you have a decent stand. There are several available, some fairly inexpensive.
If I didn't have the proper tools, I would use a large adjustable wrench (i.e., a Crescent wrench). You should be able to get a pretty good vertical and horizontal alignment with that. STAY AWAY FROM PLIERS!--especially the "30 lb" version.
You can get a derailleur hanger alignment tool for probably the same cost as a good adjustable wrench:
Hanger Alignment Tool
This one will definitely get the job done--and as for as many derailleurs as you seem to be going through, may be a good investment. The fact that it threads in makes it better than an adjustable wrench right off the bat.
And for the love of god, keep that bench vice away from that poor bike frame.
Quoted: 103 Post(s)
Liked 8 Times
+1 on the need to find a good shop.
Quoted: 103 Post(s)
Liked 8 Times
Looking into derailleurs, any reason to consider these older styles ones that mount with the axle?
Liked 2,927 Times
Likes For smd4:
Liked 2,927 Times
If you already have a frame-mounted derailleur hanger, why do you want one built into the derailleur? Things may have changed, but those were always the cheapest derailleurs.
Quoted: 103 Post(s)
Liked 8 Times
Oh wow, it looks like just a little alignment tool. Doesn't look like it bends metal. I'll take a look into them then
Quoted: 839 Post(s)
Liked 1,064 Times
RJ's list of very useful vids. RJ The Bike Guy - YouTube YouTube has plenty of vids from other users as well to do just about anything on your bike.
Likes For Crankycrank:
Liked 2,927 Times
The derailleurs I’m aware of that “mount to the axle” have a built in hanger—the part that would mount to the axle. The picture you posted shows you already have a hanger as part of your frame. It allows you to hang any derailleurs from it you want (as long as they can handle your gearing). The derailleur pivot bolt screws into the hanger. Your hanger may be (likely is) bent, which misaligns the entire derailleur.
Likes For smd4:
Liked 2,927 Times
Watch the videos Crankycrank posted...especially that last one.
Likes For smd4:
Quoted: 103 Post(s)
Liked 8 Times
Yeah, whoever suggested him originally I found him and subscribed. Will be going to school
Yeah, my hanger is absolutely bent way more than the first time, so I was thinking this axle derailleur might be helpful, plus cheaper. Gotta get the alignment tool and see what I can do first.
This is how I pay my tuition for my education.
Liked 2,927 Times
Quoted: 2338 Post(s)
Liked 2,827 Times
Yes I've got the stand already. That's what got me started on this journey. I'm confused though. How is this tool going to bend my hanger? It's just for alignment right? I DO have a good sized adjustable wrench. Didn't think of that. But that's all they're is? I would have hoped they made something for this presumably common issue
Seriously you should look for a bike co-op or siimilar as place to help or learn. Maybe a class if you can find one, Doing wrenching wrong can end up causing pain in if things fail badly
I am guessing that you threw on the derailler that everyone told you not to throw on and this is the result of it not working. I suspect it did not have the needed range and a good chance the chain was too short
what is the size of the rear cassette smallest tooth cog to largest tooth cog? how many speeds? What is size of chain rings? biggest? smallest? what are your shifters this info will help identify what is needed for the rear derailler
Likes For squirtdad:
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
Be prepared for the hanger to break. It's aluminum and it sounds like it's been bent a couple of times already.
One way to assure it will not break is to buy a replacement ahead of time.
Liked 2,927 Times
Does he have a replaceable hanger? It's sort of hard for me to see from the picture.
Quoted: 6198 Post(s)
Liked 4,814 Times
I've been doing my own bike DIY for over 50 years and have never had the need for a hanger alignment tool. Maybe it's just good luck, or I was about to trash that bike anyway.
But probably your DIY education will be complete when you can look back and wonder why you have a tool box full of expensive tools you don't use very much and realize you will have spent way less money letting the bike shop deal with certain issues.
Likes For Iride01:
Liked 2,927 Times
I love having a toolbox full of unusual specialty tools--even if they don't get used that often. Just the fact that I have them if I need them is enough for me.
Quoted: 18380 Post(s)
Liked 4,512 Times
One thing I won't skimp on are rear derailleurs. Well, at least that much.
The cheapest ones are so flexible, I'm not sure they can be properly adjusted.
The newer ones are made with a much more rigid body structure.
I'm not quite sure what I'd choose. It appears as if you have 9-speed on the rear, with pretty large sprockets.
What brand of derailleur/shifters do you have? I believe most are Shimano compatible, except for SRAM or Campagnolo.
For Shimano, you are limited mostly to 8 or 9 speed rear derailleurs (changes in shift ratios for 10 and 11 speed).
My preference for derailleurs would be Deore, XT, XTR, 7000, 8000, 9000, m7000, m8000, m9000 (noting, of course different shift ratios for 10 and 11 speed which can mess up indexing).
I also like the Shimano "Shadow" technology.
When buying a derailleur, you will have the rear sprocket range, to look at (maximum teeth on the rear sprocket), as well a the capacity (rear large-rear small) + (front large-front small).
As noted above, there are three types of derailleur adjustments.
- high/low stops. This is what keeps your derailleur from over-shifting either into the spokes, or between the last sprocket and the dropouts.
. - Inline adjustment. This helps you maintain indexing. Somewhere along the cable path, allows fine adjustments of cable length.
. - B-Screw or similar. Near where the derailleur bolts to the frame, adjustment that does fine adjustment of how far the derailleur comes to the sprockets. You need to keep it as close as possible to the sprockets through all shift combinations without actually hitting them.
Likes For CliffordK:
Clark W. Griswold
Quoted: 4360 Post(s)
Liked 4,001 Times
Park Tool, EVT Shimano, Abbey all make excellent hanger alignment tools and yes they do cost money but they are a very important tool and should not be taken lightly. If you don't want to spend that money which is fine find your local shop and they can help out with it which will save you a lot of money and time and while you are there if you have a replaceable hanger I would pick up a second one and have it on hand.
In terms of replacing a derailleur tourney is always going to be a poor replacement it is the bottom of the barrel in terms of Shimano and while they have different variants of it they are all of low quality and not really designed for holding tune and being reliable, OK for a short term usage bike or maybe a light use kids bike but that is about it.
Liked 2,927 Times
Well, it's not the Large Hadron Collider or the Space Shuttle. I'm sure most folks here without Ph.D.s could figure out how to use it, and get their hangers back very close to spec.
Quoted: 1110 Post(s)
Liked 1,204 Times
A derailleur is adjust using a hanger alignment gauge and is done by a professional, it is not something you want to try at home with no knowledge of how to use it.
Park Tool, EVT Shimano, Abbey all make excellent hanger alignment tools and yes they do cost money but they are a very important tool and should not be taken lightly. If you don't want to spend that money which is fine find your local shop and they can help out with it which will save you a lot of money and time and while you are there if you have a replaceable hanger I would pick up a second one and have it on hand...
These tools are very easy to understand and use, especially with simple online video instructions. For example if Park has a video on how to use their tool (haven't checked), it would be useful to see how to use any cheap alignment tool.
The one additional suggestion I would make is - if you can - get a spare derailleur hanger for your bike. When you straighten it, it might break (that's the way they're designed). Even if it doesn't, it's nice to have a spare for if/when you might need it.
+1
Likes For Camilo:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Sometimes I think "Professionals" are a bit too full of themselves.
Likes For dedhed:
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
If your bike has indexed shifting, as do most bikes sold inthe last 30 years or so, Flintstone alignment with a bench vise and a stool isn't likely to be precise enough. There are special tools to properly align dropouts to get indexed shifting to work. Any decent bike shop can do it, or you can buy one for ~$30-50.
Quoted: 969 Post(s)
Liked 1,632 Times
Just gotta pipe in... Don't forget to check the Dish on your rear wheel before doing anything else...
