Seating tires with a compressor
Quoted: 317 Post(s)
Liked 685 Times
I use a compressor to seat all my tubeless tyres. Is it necessary? Not on all combinations, but it makes life easy.
My compressor cost about the same as a good-quality track pump with tubeless charger tank, and I can use it for a bunch of other tasks. The main downside is that it is LOUD when filling the tanks initially! I wouldn't recommend a compressor if you live in an apartment block. 😅
I do, yes. Mostly because I remove it anyway to add sealant to the tyre. Once seated, deflate slowly, add sealant, then pop the core back in.
Likes For tempocyclist:
Lots of good advice on this thread. But have you noticed that are a variety of answers, techniques, etc? That's because it all depends on the set up. I've tried just about everything and all the pro tips I could. In the end, it just depends on the set up. What I have found that works most of the time for a wide variety of tires and rims is a pancake compressor with valve removed from stem. Pop Pop!
Dave
Method to My Madness
Quoted: 1994 Post(s)
Liked 1,505 Times
Also tried putting a blow gun into the valve without a valve core. Tired of bodging this without good results. Managed to seat a few tires with a floor pump, but want to do things the easy way. Im still leaning towards the Arundel, contacted them directly since I haven't found much info about it.
You managed to empty the tire before or after seating the tire beads?
It is almost impossible to hold an blow gun tip into (i.e., within and against) the Presta valve body (without the valve core). Much easier to use a blow gun soft tip over and around the Presta valve body (without the valve core). Does your blow gun have a 1/8" NPT fitting? If so, I can just send you one of the tips I bought if you cover shipping.
I tried screwing the presta to Schrader adapter into a tubeless valve as an experiment. The tire was already inflated, but I suspect the valve wasn't on well and the air leaked out from behind the seal, so possibly user error.
Looks like my blowgun is 1/4" NPT, appreciate the offer though 😊. Maybe I just need a different blowgun, can you link one that would work?
Liked 1,505 Times
Hi,
I highly recommend jaxgtr's suggestion to use something that fits over the Presta valve (with its core removed, of course). I use these tips:
8PCS Black Rubber Air Tool For Air Nozzle Tip, Blow Gun Rubber Tip For Air Tool, Parts Air Nozzle For Air Blow Guns Tool For Air Tool Parts & Accessories Air Blow Guns Tool - Amazon.com
The tip has a male 1/8 NPT thread and so fit into any standard air tools, including a blowgun. The tip can stretch over and seal against the Presta valve body, but can be pulled off quickly too, unlike an adapter that threads onto the Presta valve body.
Which one do you have? Mine is quite loud so I would not mind an upgrade.
Dave
Quoted: 4482 Post(s)
Liked 4,955 Times
Are you spreading the tire at all? I've found fatbike tires to be some of the easiest to mount and seat. So far I've mounted hüsker du's, jumbo jims, bud, lou and al mighty's with a track pump. My rims are MOBD with a double layer of full wide tape and one layer of somewhat narrower tape to keep the main tape from peeling off so nothing special there. Also the bud was defective with a large hop and still mounted no problem.
Somehow I have managed to ride tubeless now for 20 years without using a compressor. Although if I had one already I would probably make use of it.
If all you are trying to accomplish is to seat the tire beads, then what I outlined above is going to work. I am not 100% sure, but I think all blow guns are the same size. The 1/4" NPT end is the end for the air hose to the compressor. The tip for aiming the air is 1/8" NPT. You can order the tips from Amazon.com via the link in my post #19 above to try.
Dave
Thread Killer
Quoted: 3191 Post(s)
Liked 1,726 Times
I *highly* recommend the Park inflator as it was the single, greatest improvement in my tubeless cycling life.
I tried blow tips, Prestacycle inflator, and schraeder adaptors, but all are utter garbage compared to the efficacy, ergonomics, and ease-of-use of the Park Tool inflator.
I k ow it costs a grip, but man, it makes doing what needs done a breeze.
Regarding the Arundel inflator, it looks pretty decent (particularly in being rigid unit and not with a hosed portion), but has a couple of apparent shortcomings: 1) the flow lever is on the upper side, so when depressing it, you’re pushing away from the valve, potentially compromising the connection and requiring the extra effort of balancing opposing forces, and 2) the head does not swivel, restricting use angles (because the guage wouldn’t be visible), which may seem like a small deal, but would be a frustration given my daily inflation uses.
Liked 1,505 Times
Yeah, for sure. After you get the bag of tips, you can slightly stretch one using a Philips screwdriver of the appropriate diameter, so that you can more easily get the tip over the Presta valve body (with valve core already removed). Cutting the tip does not make the opening larger; shortening the length of the rubber piece actually makes it more difficult to fit over the Presta valve body.
Quoted: 1117 Post(s)
Liked 1,213 Times
I use the cheapest digital presta inflator I could find on EBay several years ago when I was looking for one for the car, "Azuno"- less than $50. There's other brands of similar price point and quality, certainly on Amazon, Home Depot, etc. as well. It came with both Schrader and Presta heads. I've used it dozens and dozens of times with the car tires for several years and a few times with the tubeless bike tires. It's plenty solid for years of use. Don't get sucked into an expensive unit, the cheap one I have is solid, accurate and durable.
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 474 Post(s)
Liked 554 Times
They may well use the same sensor. But there is more to an inflator than the sensor.
In defense of the Azuno, I do keep my bike stuff in an unheated garage, and here in the lesser white north that means below 0F, which they may not have been designed to survive. My work experience tells me that is not trivial.
Likes For DangerousDanR:
Liked 1,505 Times
It is very handy to have a compressor, to inflate motor vehicles tires, to blow dust off electronics, etc.; seating bike tires is just a bonus.
I find that the tires will do their initial pop at about 30 psi so that they seat and temporarily hold air without sealant. Then I air down and open about 12 inches of the bead on one side and pour in the sealant. Then reset the bead and hit it lightly with the compressor until I get a pop. From there I'll air up to about 40 psi with a floor pump which usually causes a second, louder pop. Then back off the psi to about 20 to 25 psi for riding. This is for tires in the 48mm to 2.2in size range.
Doing it this way seems pretty unlikely to create a blow off.
Road tubeless is not my thing and seems riskier with the higher pressures necessary.
$129...
and it gives you an excuse to also buy a nail gun.
When trying to seat a new tire...
1. Remove the valve core, install the Shraeder adaptor, and air up the tire with no sealant to about 30 psi so the beads pops, then let the air bleed back out.
2. Open up about 12" of bead on one side an pour in the correct amount of sealant. Push the tire bead back over the rim.
3. Air the tire up again with the compressor until it pops - still no valve core - let the air bleed out again.
4. Remove the Shraeder adapter, install the valve core and air up the tire again using your floor pump to reach 40+ psi. This should firmly seat the bead - you may hear a second, louder set of pops. This eliminates the problem of using a compressor with a Shraeder adapter and a valve core.
5. Spin the tire, wave the tire overhead, etc. to fully distribute sealant around the inside bead.
6. Air down to the desired riding pressure, 20 - 25 psi.
You can skip step 1 but if the tire doesn't seat for some reason then you have a mess of sealant to deal with while trying to figure out why the tire won't seat.
Liked 4,955 Times
Pure conjecture here: Narrower tires designed to be run at higher pressure have tighter beads which thus make them harder to seat?
When I got a gravel bike and went tubeless, I read about the soapy water technique, which appears to predate tubeless. I wonder how the soap / detergent would interact with the sealant?
Maybe this contradicts my conjecture above, but I wonder if there is a max pressure difference between GP 5000 TL vs. S TR at the same size?
Over the years I have had the odd stubborn tubeless mtb tyre and that’s when I would use soap to help seat. But I wasn’t using any sealant in those days. I doubt it would be a problem though.
For sure a compressor is handy for other things, but certainly not necessary in this case. I do actually have a small compressor for car tyres, but I prefer using a track pump for bike tyres.
Quoted: 474 Post(s)
Liked 554 Times
I know, you do it all the time and you haven't seen anything break. Most of the time any damage is not going to result in immediate failure, but it does reduce the life of the electronic device.
This is an alternative that works quite well:
https://www.amazon.com/dp/B01BJ4MXQY...lig_dp_it&th=1
Basically a pony bottle that you can put air in at a very high PSI and then send a blast to tube to pop the tire into place. There are pumps that do this but if you already own a good pump this is a $65 add-on.
Quoted: 229 Post(s)
Liked 319 Times
I don't find air compressors to be the end-all of seating tire (tubeless of course). While 90% of the time it works fine for me, for difficult tires, I need to use an Air Shot. Now, a compressor has a tank and ideally could be set up to function the same as an Air Shot. But you need a very short hose to do this, and the Air Shot is simply easier to use than my compressor because the Air Shot is very portable.
Likes For Mtracer:
Quoted: 1100 Post(s)
Liked 1,039 Times
I bought the ryobi 18v air compressor for this purpose since i already have a load of batteries. I've got it set to 80psi which is sufficient for everything but my road bike. Easy to carry to the shop, basement, driveway, or even bring to an event where I might need to do lots of tires. One 4ah battery will do 15-20 tires or several car tires as I recently test out. I've got the air nozzle for cleaning out caged bearings and such. Just very convenient and not too loud for being oil-free.
Quoted: 2730 Post(s)
Liked 488 Times
Cleaning electronics with compressed air can easily lead to static electricity damaging them unless you are using an electricaly conductive and grounded hose and nozzle.
I am electrically illiterate despite attempts to learn, and the extend of my knowledge about this is that some delicate electronics want people handling them to wear “ground straps ” around their wrists to protect them. How related is this?
Thanks.
Quoted: 474 Post(s)
Liked 554 Times
The WIkipedia article on this is not too bad as an introduction to static electricity. https://en.wikipedia.org/wiki/Static_electricity
The basic idea is that when dissimilar materials rub against each other electrons will move from one to the other. In the case of blowing a circuit board clean with compressed air, the air rubs against the circuit board. Unless the air stream is treated to eliminate the electrons (there are ways to do this) the moving air will deposit electrons on the surface of the circuit board.
Once enough electrons build up on the surface of the board, they can jump to a conductor, such as one of the contact pins on an integrated circuit. With traces that are just a few nanometers wide, the current may be enough to cause localized heating. If the charge is great enough or the part is sensitive enough it may cause immediate observable damage. Or it may cause damage that accumulates over time that shortens the life of the component.
Thread Killer
Liked 1,726 Times
I seat road tires all the time off +50ft of hose and a 4.5gal tank on a compressor rated for 3.0 scfm at 90psi. I keep the system charged to 150psi, and can seat a pair of tires without even running the compressor (IIRC; I don’t really pay attention because I don’t have to. It just works seamlessly).
Likes For chaadster:
Bikes: Way too many
Quoted: 921 Post(s)
Liked 609 Times
I use one of the charging track pumps. It's basically got an air chamber you can fill and pressurize up to about 160psi and then unload into the tire, it sometimes takes a couple of attempts but works great.
