It wants to be a Sports: Rusty 1954 Ralegh Superbe Tourist content lurks within
www.theheadbadge.com
Quoted: 2425 Post(s)
Liked 4,410 Times
I tried straightening the headtube today. Instead of straightening the headtube, this monster of a frame bent the solid stainless propeller shaft I've been using in lieu of a HTS-1.
Looks like I'm back in the market for an actual Park HTS-1. Shouldn't have sold my previous one.
No change.
There's also a significant bow in the top tube; still sprung from the front-ender. It should straighten out if the headtube finally get popped into where it belongs. But that isn't happening today, apparently.
Those "Raleigh Sports" decals get me every time. Who goes through all that effort to put on the decals from the wrong model?
-Kurt
No change.
-Kurt
Likes For cudak888:
Liked 4,410 Times
Likes For cudak888:
Quoted: 3817 Post(s)
Liked 6,742 Times
Might be best if that thing just melts in the bath! That frame damage is concerning.
Liked 4,410 Times
Neal, I literally jumped on this frame upside down (I usually pull up on the chainstays when I use the propeller shaft) and yanked as hard as I possibly could to try to get this bastard to cold-set. Diddly squat happened. The only concern anyone should have about this frame is whether it'll cause an immediate roof collapse if one crashes into a building with it.
Also, the slack headtube angle allows me to see the brass penetration in the upper headlug. It's plenty.
I'm not worried one bit about the strength of this frame. Not one bit. I am worried about how I'll be able to maintain the overall weathering if I have to repaint part of the top tube to get the wrinkle out. I know I'm not going to be able to tolerate it as-is.
-Kurt
Freewheel Medic
Quoted: 1459 Post(s)
Liked 2,206 Times
So much love and devotion. And just think, you've only known this "Sport" (sic) for less than a week. BUT YOU ARE SOAKING IT IN ACID!!!! Egads!
Bob
Bob
Liked 4,410 Times
Likes For cudak888:
Liked 4,410 Times
A couple steps forward, some back. First off, I was able to cold set the front end:
However, the top tube remains bowed significantly:
More importantly, I discovered that the impact had not been across a single axis. The top tube is also bent to the left, significantly. I haven't checked to see if this is likewise reflected on the downtube. Not good.
Many apologies to the frame and to the forum for pinching the seatlug.
This also came with some pretty decent progress around the lower seattube and downtube areas, all things considered:
-Kurt
-Kurt
Passista
Quoted: 874 Post(s)
Liked 727 Times
Great to see such efforts to get this bike back on the road!
As those are thick walled tubes, maybe you could straighten them with a hydraulic press? I'd make some wooden cradles and try it.
Strange they put the BB oiler on that side - all I've seen are on the NDS.
Liked 4,410 Times
If anything, I want to put this on a frame table to find out exactly what is tweaked where, and then formulate a game plan.
The NDS ones - were they on Sports or 28" rod brake DL-1/2/5 models?
-Kurt
Liked 4,410 Times
Don't let the decals throw you, this is most definitely not a Sports.
Just checked my '51 and '52 Sports; both of them have a spring bearing ball oiler on the left side. Interesting.
-Kurt
-Kurt
Freewheel Medic
Liked 2,206 Times
Kurt, I have an answer to your mystery:
By the looks of all those bends, kinks and curves, the previous owner (or a rogue thief) had a few too many pints at the pub, before attempting the ride home (or to his den of iniquity). Multiple crashes occurred that night after pub departure, but the PO (rogue thief) just kept on going, each time righting the bike, brushing the road grime off his trousers, and pumping towards his final destination.
Once arrived, the PO (or rogue thief), still in a haze of alcohol induced stupor, held onto the shed wall for balance, and exclaimed while admiring the sturdiness of this classic British Roadster, "By golly you are a jolly old Sport!" And immediately scraped off Superbe Tourist and applied the current downtube decal.
Bob
Bob
Likes For pastorbobnlnh:
Liked 4,410 Times
And so began a life of constant knocks for the Jolly Sport, for the damage was so great that one could only balance it whilst drunk...
-Kurt
P.S.: I don't believe the 28" rod brake bikes ever wore model names. It would make identification of Raleigh's inane naming convention so much easier.
Quoted: 7359 Post(s)
Liked 2,497 Times
This thread is fun. I'll keep reading it.
Maybe the owner wished he had a Sports, hence the decals. We can only guess.
Likes For noglider:
Liked 4,410 Times
This may sound ridiculous, but the frame is fairly aligned now, and the top tube is reasonably straight.
Aligning the frame involved fairly typical cold-setting, but getting the top tube straight involved some pretty ridiculous antics with a Park FFS-1. I may have tried hanging from the ceiling to stand on the tube at one point too...
Looks kinked, but its not. There are a few TINY flat spots on it; still an improvement:
Now to figure out what to do about the wrinkles.
-Kurt
-Kurt
Liked 2,497 Times
Bravo. If anyone could do it, it's you. How is the fork?
Likes For noglider:
Liked 4,410 Times
Tweaked to the left a bit, but completely workable. Not concerned about it in the least.
The only thing that I'm still antsy about is the wrinkle at the top tube. It's pretty significant now, so I'm going to talk to the same neighbor who painted the BlasphTwenty to see if he thinks he can repaint that section only, after I put frame blocks to it. Perhaps fog a bit of paint around it to blend it in after that.
Might have Mike Terraferma torch some silver into it if the wrinkles remain. So long as the paint loss can be confined to the top tube and the upper headlug area, matching everything up may be doable.
-Kurt
-Kurt
Liked 4,410 Times
Tried to take out the top tube wrinkle today by giving the top tube a squeeze without twisting. Had a bit of success, but the threads on one side of the block popped out (!).
I realize these screws aren't supposed to be load bearing, but this is a bit ridiculous.
Anyway, without actually twisting the blocks, a bit of progress was, indeed, made.
BEFORE:
AFTER:
Still not anywhere near tolerable for me, but closing in on it.
-Kurt
BEFORE:
AFTER:
-Kurt
Liked 4,410 Times
Incidentally, I have to give props here to Paragon Machine Works - they've already arranged for a replacement and created a shipping label.
Mark did make note that these aren't really made for dent removal even though they're popular for the task:
I like the sound of that specialized dent remover block.
-Kurt
...the tube blocks may incidentally work on dents, but that's not the design. If I were to make a block specifically for dent removal, it would be longer and have 3 to 5 M6 bolts on either side, depending on tube diameter. In any case, leave the bolts out entirely, and use a vise or C-Clamp to apply pressure. Keep the frame tube well lubricated with grease.
-Kurt
Liked 4,410 Times
Liked 4,410 Times
Likes For cudak888:
Liked 4,410 Times
I hemmed and hawed about what to do about the tube warpage. I haven't really wanted to mess with doing any refinishing on this one, but there's no way out of it.
While having the downtube of the Marinoni looked at (from this thread), I brought along this frame too. Mike went ahead and filled the wrinkles, though there was a bit of experimentation about how to fill it.
The top was done with silver, but it didn't flow well - Mike warned me as such, so this was on me asking to see the difference, just for learning purposes more than anything else.
The thick tubing made brass an option, so that's what was used on the bottom.
We were under time pressure though, and while the results did improve things, the results look a bit meh - there are still some low spots that could do with yet more filler. Doesn't help that the top of the lower headlug stamping has a lot more material on the top than the bottom.
I'm going to re-verify the angles, just to be sure. What drives me nuts though is that it still looks like the clear victim of a front-ender.
My fear is that it might be impossible to get that lower lug to look square with the tubing, even if filled a bit better. Perhaps this one should be put to bed and given up on, but it's fairly difficult to dig up mid-1950's Superbe Tourists. Granted, I know our very own SirMike1983 has one listed, but - alas - it's the 22" variety.
-Kurt
-Kurt
Likes For cudak888:
