Fatter tires, worth the trouble?
#201
Mad bike riding scientist
Quoted: 6243 Post(s)
Liked 4,262 Times
Friction? Really? That one is a gimme. A spring? What pushes or pulls on a spring to give it force to exert?
You seem to be conflating force and the effect of the force. The density of air changes with temperature, but the mass of the air does not. Thinking about this should make clear to you the difference between the drag force depending on air density and the drag force depending on the mass of the air. But you'll probably try to dispute that, so feel free to show me the force diagram you are using to understand aerodynamic drag at a molecular level.
Finally, you need to study up on density. The density of the air does, indeed, change with temperature. But what is density? It is the mass of air contained in a certain volume. Generally speaking, we don't vary volume when talking about density...it makes the math more difficult. Something has to vary and since you have 2 choices...mass or volume...you are left with mass. When the density of air changes with temperature, it is indeed the mass of air that changes. Higher temperature, less mass. Lower temperature, more mass. Think, for example, nitrogen. At 20C, nitrogen 1.165 g/l. At the boiling point of nitrogen (-195C), the density is 800g/l. A liter is still a liter so the volume didn't change. The mass, on the other hand went up significantly.
Stuart Black
Stuart Black
#203
Bikes: Yes
Quoted: 3236 Post(s)
Liked 3,883 Times
So do heavy wheels increase or decrease the force of my brakes relatively to how hard I squeeze the lever?
My Bikes
My Bikes
#204
Bikes: I own N+1 bikes, where N=0.
Quoted: 35 Post(s)
No, we're not. You're forgetting that the air has no knowledge of the weight of the Bike/rider system, and applies the same force to both, and only an equal force, independent of the bike/rider system weight, must be applied in the opposite direction to maintain constant speed.
#205
Liked 4,262 Times
If the force that the bicycle/rider express on the air is independent of the mass of the bicycle and rider, then a 40kg rider on an 8 kg bike should have the same speed for the same power output on a flat course as a 90kg rider on a 50kg bike. When has that ever happened in your life? I've never experienced that kind of joy.
Stuart Black
Stuart Black
#206
Liked 4,262 Times
You tell me. Does a more massive object require more or less frictional force to stop? Does it take more force to slide (dry friction) a more massive object than a less massive object? Still haven't seen any "massless" forces yet. But I haven't seen a unicorn, Sasquatch or a demonstration of cold fusion, either. They inhabit the same realm.
Stuart Black
Stuart Black
#207
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Again, we have this issue of some kind of "massless" force. This time you've taken the mass of the bicycle and rider out of the equation. Any force applied by the bicycle/rider to the air is dependent on the mass of the bicycle and rider because the bicycle and rider are providing the motive force. You can't have force without mass. Period....
The mass in the drag equation, (rho) is the mass of the air. The air presents a force on the bicycle, and is not dependent at all on the mass of the bike. Overcoming air resistance at a constant velocity means applying a force against the mass of air. Changing your velocity requires an added force against the mass of you and your bike. Two different things: moving the air, changing velocity of the bike.
#208
Bikes: Yes
Liked 3,883 Times
Requiring more force and creating more force are two different things. Sliding a heavy object involves the object's mass because the weight of the object provides the normal force, but in the case of braking the normal force has nothing to do with the mass of the wheel or the brake.
My Bikes
My Bikes
#210
Quoted: 35 Post(s)
That's because the increased mass of the bike/rider system also causes the air resistance to have a smaller effect on the heavier bike/rider than it has on the lighter bike/rider system. This difference exactly offsets the effect of the increased bike/rider weight. When you do the math, the mass term cancels out on each side of the equation.
#211
Quoted: 35 Post(s)
#213
Bikes: Tons
Quoted: 35 Post(s)
Bikes: Yes
Liked 3,883 Times
Ooooh, oooh! Have we gotten to the part of the discussion where we all start trotting out our degrees and work experience?!
My Bikes
My Bikes
#217
Bikes: Nashbar Road
Liked 341 Times
I'm confident that everyone can understand this bit of science, if the right concepts are presented in a way that makes sense to us.
#218
Quoted: 35 Post(s)
Quoted: 35 Post(s)
Bikes: 2005 Gazelle Golfo, 1935 Raleigh Sport, 1970 Robin Hood sport, 1974 Schwinn Continental, 1984 Ross MTB/porteur, 2013 Flying Piegon path racer, 2014 Gazelle Toer Populair T8
Quoted: 396 Post(s)
Liked 8 Times
#223
Bikes: Surly Long Haul Disc Trucker
Quoted: 1015 Post(s)
Part of the reason we don't see that is that it will be very complex. Show the math for proving or disproving the wisdom of fat tires and include the air displaced, differences in rolling resistance, sidewall flex, and on and on and show how that's applicable to all bikes and riders or only some. Pretty hard to prove mathematically. It's easier to just expouse on your personal and unscientific beliefs. That's fine. But it's not physics.
#224
Quoted: 5892 Post(s)
Liked 3,479 Times
Wow, these guys are going at it in 2 different threads,
https://www.bikeforums.net/touring/97...ng-gruppo.html
#225
Quoted: 35 Post(s)
I was actually referring to the discussion about how much energy is required to maintain speed of a heavy versus light bike (given identical surface area and shape of bike/rider systems) on flat, level ground. Only one poster seems to think it takes more energy to maintain speed on the heavier bike, and even the calculator to which he linked disagrees with him.
The format of Internet forums makes talking in math pretty inconvenient.
