Have You Ever Broken a Frame Removing Headset Cups?
aged to perfection
Quoted: 851 Post(s)
Liked 1,278 Times
so the problem is not with you
unlike most newbie posters, we could not have imagined you had frame blocks and knew how to use a sledge
we are often faced with helping "newbies" figure out poorly defined problems "my bike is making a funny noise"
glad you got this figured out
/markp
/markp
That advice had already been tried, and it had failed, so how was it "solid"?
The eventual solution was not, in fact, suggested by anyone here -- so let's just call this claim "dubious", and leave it at that.
Expired Member
Quoted: 3711 Post(s)
Liked 5,558 Times
So shortly after asking for help, you came up with a genius solution for your problem. You could have just posted in the "Hints and Tricks" thread and avoided all the drama.
Senior member
Quoted: 945 Post(s)
Liked 662 Times
I would give it another reaming before re installing the headset.
Likes For Dan Burkhart:
Quoted: 3560 Post(s)
Liked 2,978 Times
You used the wrong tools and techniques. Glad you worked it out.
Liked 2,978 Times
With respect.
Likes For smd4:
Technically, I didn't ask for help. I just asked if anyone had broken a frame in this manner. More to the point, I did not say the solution was genius -- only that no one here offered it. And that it did work.
Yeah I caught that. I presume as someone who has built at least one frame, you understand that the head tube needs to be reamed to correct for any distortion and to ensure a proper fit of the headset.
Thanks.
Oh really. What are the right tools and techniques for removing pressed-in headset cups? ( Rhetorical question, since a headset removal tool very clearly is. )
Well, my tig machine disagrees, as does most of the bicycle market these days, although I do tig-braze some small bits, and other projects.
Alright folks, I'm guessing that we've beat this horse thoroughly beyond any use, and am going to suggest that unless anyone has substantive commentary on the topic -- like Mr Burkhart did -- we call it a night.
Quoted: 1148 Post(s)
Liked 1,773 Times
No, never.
However you appear not knowing with your starting techniques written, now lol you get the flame for assuming that everyone knows you built a frame without saying I built this frame, get some better paint next time. Did you paint this yourself? Why did you use such a junk paint for your self built? I agree if you used better paint you would have had better results.
Heat is always my second try on anything difficult. I'll put grease on the area that I heat. I'll heat to the point that the grease wicks into area that's of issue. Then try removing.
Clark W. Griswold
Quoted: 4426 Post(s)
Liked 4,072 Times
That was exactly why I made this post. Unfortunately, most respondents looked only at the age of my account, and decided that I didn't know what I was doing.
I was hoping for actual advice that I didn't know -- perhaps "Don't worry, a 5 lb sledge is nothing compared to a 200 lb rider" or "I'd sacrifice the cups and cut them off before risking that".
Didn't really get any, though.
I use Mobil 1 synthetic grease -- and probably way too much most of the time -- and whatever the Park product is called, on special occasions. I raced cars for about 25 years, and while there are certainly better wrenches than me, I understand the idea behind lubrication. These cups were greased when they went in, but the fit was apparently sufficiently tight that not much reached where it was required. Didn't know that at the time, but I do now, so I'll adjust accordingly.
Thanks.
Thanks.
Obviously yes it is a online forum and there are a lot of people who believe they are experts and yada yada yada but in the end you came in hot when you didn't need to be and no you shouldn't cut out a headset cup except as a way last resort if it is not moving at all and you have tried a lot of stuff to remove it and done it all as properly as possible and it really won't come out.
How so, exactly? Feel free to re-read my original message, or even the others, and explain how "hot" they are.
What actually happened was that I asked an unusual question, and received a few requests for clarification, a couple well-meaning suggestions to a question that I didn't ask, and some poor advice that doesn't even comport with the known laws of physics. When I observed that such advice was nonsensical, some people like FDinNY, shelbyfv, and smd4 resorted to attacking me personally, which I understand to be in violation of the rules here.
Expired Member
Liked 5,558 Times
Just in case anyone cares, like perhaps the administrator, I can explain why some of those people "aren't here for good." This forum is not at all friendly -- even by internet standards ( and I used to run some, decades ago ). Perhaps that's by design, in which case, carry-on, but if not, adjustments could be made. My skin is plenty tough, but I see why many folks bail on this forum without much delay.
Bikes: a couple
Quoted: 563 Post(s)
Liked 868 Times
I am, thanks.
Let's test and see if I can post a picture for the first time, which may be worth a few dozen words.
Will all due respect, I am sure that I don't know anyone who is stronger than a 4 1/2" vise bolted to a large steel workbench, so I am sure that having a person attempt to hold the frame will not work better.
Likes For Schweinhund:
Likes For TC1:
Clark W. Griswold
Liked 4,072 Times
I am curious who are all these people "bailing on this forum, without delay"? I am curious there have been a lot of us who clearly haven't bailed and plenty of new folks who are still active sure on any online forum there will be people who literally use it like google and don't come back but they aren't here as a forum member they are here because we are a more specific google search engine for them. They were never here to join the forums they saw it as let me just quickly run into their meeting and throw my hand up and then their buddy texts hey about to leave get in the car. It is common on any forum on the internet this is not a unique thing here.
When I said you came in hot I read what your wrote your initial post was fine but then you got rather argumentative quickly. There was no need for that. You are a new poster and that is why I said you came in hot not that your first post was hot necessarily but you started off your time here in the full sense being "hot". I got the feeling of "I know better" instead of "I could learn". Maybe I got the wrong impression it is in the end text on a page but I tried to be nice here and not totally lay into you but guide you a little. I apologize if you felt attacked or anything at least from me. I don't think anyone else was attacking you either but text on a page can be misinterpreted and I won't lie some of us can get a little snarky. It is the internet after all!
Bikes: a couple
Quoted: 563 Post(s)
Liked 868 Times
Thanks for the suggestion. I went the opposite way and used cold, not heat, and it worked yesterday.
@smd4 : What happened to your claim that "No one who’s ever worked on bikes would have suggested your solution"?
I appreciate that, and I don't feel that you specifically have said anything untoward. I cannot say the same for some of your compatriots in this subforum, unfortunately. But hey, apparently the administrator is cool with the behavior exhibited here, so far be it from me to worry about it.
Liked 2,978 Times
Quoted: 18417 Post(s)
Liked 4,532 Times
Glad you got the cup out.
For a lot of similar removals on cars or equipment, the suggestion is to use an air impact hammer. Lots of small impacts rather than a few big whops from a sledge.
Most of my headset removal, I'll find a big Crescent wrench and adjust it to grab loosely around the head tube and rest on the cup and pound the cup out. No special tool.
Clark W. Griswold
Liked 4,072 Times
Extremely so, in my experience here. Made even worse by how wrong those testy folks are.
I don't know, I was referring to your comment that "we tend to get a lot of new folks lately who aren't here for good..."
With respect, that was not my initial post here -- I have already been helping a few people, although not necessarily in this subforum. More to the point, I was polite, and not argumentative in this thread. Admittedly, I have been amazed by the resistance to learning exhibited in 'that other thread', which has devolved into an argument.
The folks here for no good aren't bailing quickly they are trolls here to troll and the only time they are gone is when they get banned for trolling. So who are these folks who are bailing? They aren't the folks I was talking about and well if they were the folks you were talking about you are missing everything here.
I guess I have missed your earlier posts but from what I am seeing it is not a good start maybe it started good and you started back sliding I don't know but it is not looking good right now.
Likes For veganbikes:
Liked 2,978 Times
Quoted: 1062 Post(s)
Liked 665 Times
Just as an aside, I've never clamped a frame while removing headset cups. I just hold the head tube in one hand and bang on the remover with a big hammer in the other hand. The remover is the old trusty piece of electrical conduit, slotted, and spread out a bit to form 4 tabs.
The opposing force comes from the inertia of the frame. I think it's the most gentle way to do it, without risking breaking the frame joints, bending the tubes, or gouging the frame in the jaws of the vise. Also, I wouldn't discount the use of ice, though I've never tried it myself.
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 253 Times
Clamping the frame in the vice ensures that much of the impact is being transmitted through the frame (which is acting as a spring) and is thus being absorbed by the frame and the vice.
Take the frame out of the vice, and have a helper simply hold the frame up loosely - grabbing it through layers of shop towels or the like, to ensure that the impact force isn't being absorbed anywhere but at the point of contact - and tap the the cup out gently (while moving the point of impact a few millimeters at a time) with a blunt punch or screwdriver or whatever tool you can safely adapt to the purpose.
I would simply place the removal tool in the headtube, hold the frame in one hand, while tapping out the bearing cup with a hammer or preferably a wooden mallet with the other hand. These cups are only a press fit in the frame, and only require a few light taps to knock them loose.
