#3526
TXHC
Installed the titanium Phil bottom bracket and Record crankset with Stronglight 42T along with the cockpit on the Mercian.
Waiting for brakes and levers, chain, and possibly a matching set of 650b wheels.
28s seem so skinny these days!
#3527
Quoted: 4520 Post(s)
Liked 6,406 Times
Likes For merziac:
#3528
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3896 Post(s)
Liked 6,498 Times
Shakedown ride and first pics of this '86 Miyata tourer I finished about a week ago, but had to wait until it was safe to go outside and breathe.
This is the first bike with cantilevers I think I've ever had my wrench on, which was kinda fun. The overhaul went down without a hitch. Much of the outside of bike was perfectly encased in a thin layer of grime, protecting it from decades of non-use. But I'm still really surprised how little rust there is anywhere. The top tube guides and interior of the bb shell look brand new. Miyata paint jobs are most rad.
#3529
Quoted: 796 Post(s)
Liked 522 Times
Be careful SurferRosa late 80s Japanese tourers will start you down a slippery slope ..... to more late 80s Japanese touring bikes. Nice 610
Likes For ryansu:
#3530
Quoted: 638 Post(s)
Liked 1,302 Times
Just did my first wheel "build". My neighbor asked me to work on his grandson's 60's Murray built Foremost tank bike. His grandson is autistic and is very attached to it. Basically he trashed the front axle bearings and hub. The bike isn't worth the price of a new wheel so I made a couple calls and found another chrome drop center steel wheel off another Murray. It was a freebie so I wasn't expecting much and it did not disappoint. I was able to salvage the hub, axle, bearings and a few spokes. I told him since this would be my first time lacing up a wheel from scratch it was on the house.
I had to cut most of the spokes to get the hub out. When I loosened the spokes on his wheel the rim went all over the place. It had dips, twists, waves..... you name it. I've been able to true some pretty out of whack wheels but this was on a whole other level!
I got it laced up that's when the "fun" began. I've never had a rim move around like this. Not only did I have to fight the hop and lateral runout but the rim wanted to roll or twist on what would be the centerline of the tire. I finally got it where it was at least better than the original and called it good but it's definitely nothing I'd write the folks at home about.
Frustration aside, I'm anxious to try it on a better quality rim now. Even though it didn't come out like I wanted it was still very satisfying.
Likes For Murray Missile:
#3531
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 429 Times
.... the quick release is on the wrong side the bike....... must..... fix..... OCD - help!
Likes For mrv:
#3532
señor miembro
Liked 6,498 Times
#3533
Quoted: 1110 Post(s)
Liked 1,329 Times
Tandem freewheel removal
Just got the first one off, was too tight for my standard method (tool in vice, wheel on tool, hands grip rim and BIG grunt).
I tried the big grunt several times, realised I wasn't willing to grunt any bigger. Took the freewheel apart, hit the body with a propane torch for a minute, and a normal big grunt worked.
And I didn't (yet) loose any of those bloddy balls, got each race's worth with a supermagnet and a ziplock bag.
#3534
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,182 Times
#3535
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Working on this Giant townie-type bike I found that was missing the seat and post. Found a brochure online that says it takes a 30.9 and the largest one I had was 30.2 so it was off to a local Giant dealer to try a few things. A 30.9 from a different Giant bike did fit so the question is: new post or shim an existing one? I have plenty of 27.2 posts in my stash and the shop had a 27.2/30.9 shim for five bucks, so that is the route I took. Now to dig out a long 27.2 post from the depths of the garage.
Lest you think this is not C&V, the post I have in mind is a 400mm Ritchey still in the package left over from my repping days, a sample that I've had for about 25 years.
#3536
Quoted: 741 Post(s)
Liked 818 Times
Nothing much to show, but the rear wheel on my '64 Legnano had a lot of side play. I didn't measure it, but you could grab the tire and it moved side to side way too much. These are old high flange Legnano branded Campy hubs original to the bike, but hung on the garage wall for 20 years after I switched to a different clincher wheelset. I had new spokes and clincher rims laced onto these just before 2019 Eroica, and the bike probably has less than 500 miles since then. Anyway, yesterday, I tore into it. I know I serviced the bearings (new balls) and adjusted the cones before the wheel build, and never saw wheel "slop" till just a few days ago, on a 38 mile Malibu ride. In that short time, the bearings needed grease, so I gave them a good cleaning, and finally got the cones right. All good now, just surprised it needed it so soon. I have these same type hubs on several bikes, and haven't needed to touch the others in years.
#3537
Quoted: 7354 Post(s)
Liked 2,488 Times
I finally finished my 1971 Raleigh Super Course which was a project that dragged out too long. I'm pleased with the result. More of the story is here.
Likes For noglider:
#3538
Liked 6,406 Times
#3539
Quoted: 741 Post(s)
Liked 818 Times
I just updated the wheelset on my $20 (from CL) '78 Super Course. It was just a frame, BB, stem, bars and calipers, no drivetrain or wheelset. It was a spare parts bin special, and I really enjoy riding it, so I decded to go for for new wheels, instead of the mismstched set I was using. These low flange Campy hubs with MA40 dark anodized rims popped up at a price I couldnt pass up. Not sure about the dark finish on the rims, but the clean straight brake tracks are a big improvement over the old wheels. I transferred the 28c Gators over, but plan on new skinwall Paselas soon.
Likes For Slightspeed:
#3540
Quoted: 659 Post(s)
Liked 595 Times
Thrashing this ‘89 Trek 830 Antelope, my winter bike. Winters are hard on bikes and this one needed an overhaul. Entire drivetrain replaced, new chain, upraded to newer wider tires, had to torch out the bottom bracket to R&R that, swapped out a froze up freewheel, new cables and a tune up. It’s back in snow riding condition and ready to go.
#3541
señor miembro
Liked 6,498 Times
Likes For SurferRosa:
#3543
Liked 6,406 Times
#3545
Liked 2,446 Times
When I begin digging in my parts boxes in the garage I keep a mud bucket handy and toss in anything I think I might use, whether on the project bike or a different one. Today I found a rear axle kickstand and thought, "I can use this." My Cresta GT needs some help standing up in the shop area and the gap ahead of the chainstay bridge is a little tight for a center mount stand.
The actual object of the exercise was to find the 27.2 post to be used with the new 27.2-30.9 shim on the found Giant townie bike. I did find the aforementioned 400mm Ritchey post but also came across a 25.4 Tamer suspension post and a 25.4-30.9 shim so tried that on the bike and it is long enough to work in making the 18" frame fit 25" frame me. I can still use the Ritchey if I decide to do so. That's a Kalloy 27.2 with the black shim I bought yesterday but that post is too short for me.
And here's the Giant ready to go with post and shim, strap-on NiteRider lights, rear rack and trimmed original kickstand so the bike won't tip over.
So, we have the Kalloy 27.2, a Giant 26.8 and a Trans X 25.0, all from my repping days, so from last century. C&V enough?
#3546
Quoted: 1372 Post(s)
Liked 1,753 Times
Applied the water slide decal art a couple of days ago. Shot four coats of clear top coat, the next day. Rubbed the paint out yesterday and started assembly today...
#3547
Liked 2,446 Times
Pump fix day for the two house floor pumps, a Zefal Husky I bought in the '80s and a Vetta that I found in the alley at our old place probably 20 years ago. All solid C&V stuff. The Vetta with its two-way head has been getting the most play lately while the Husky has been relegated to travel duties (for bike and auto) in the VW Westy. The Vetta has a cracked and leaking hose and the Zefal has a bad gasket in the pump head.
I cut out the bad section and got a brass barb fitting at Lowe's to rejoin the hose sections. Could have used one smaller than 3/16" but this is the smallest they had. It'll do.
The cracking comes from having been folded double for years in the clip for that purpose on the pump body.
The mighty Zefal just needs a new rubber washer to replace the original that got all crusty and disintegrated, and I also need one for my large metal PV adaptor that lives with that pump. Some vendor likely has both.
Plenty of other pumps in the house; a dozen HPs and HPXs, plus many different mini Zefals and some Topeaks as well. No lack of pumpage but the floor pumps get the job done more easily.
Oh, and I leveled up the rear rack on the found Giant by using the longer of the stay pairs that came with the Giant rack. Something else from the repping sample bag that's over 20 years old.
#3548
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 570 Times
Doing a 1996 Trek 970 build as an upright commuter/city bike.
Got the BB, crank, headset, fork, stem+bars, and wheelset installed. Still have drive train and brakes yet to do. Taking my time, as it's been decades since I've done more than a couple of parts swaps.
Photos here: click.
Photos here: click.
#3549
Liked 1,753 Times
Getting closer to ride time...
Likes For randyjawa:
#3550
señor miembro
Liked 6,498 Times
Hey, @thumpism, thanks for the inspiration. I need to overhaul my floor pump. Do you put a light oil or anything similar around the plunger or full length of the cylinder? Or ... how do I lubricate it?
