Handlebars?
I had an upload issue but tried again and it worked.
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Quoted: 275 Post(s)
Liked 417 Times
most moustache bars will work fine with road levers on the bend. many have a drop and so you can mount them upside down and get a rise. you can shim the clamp if it's 25.4 and you want to re-use your stem.
other alt bars like velo orange tourist probably won't work well with road levers but they're a good option. older mtb levers for cantis should have the right pull and work on those, and only be a few dollars.
I'm a fan of high drop bars but if drops are just not actually what you want then don't suffer them
Likes For Soody:
I was kinda thinking about the mustache bars, here's a sample similar to my bike,
Quoted: 275 Post(s)
Liked 417 Times
Those are bullhorns
also if the bullhorns or pursuit bars have a sweep up at the end then you can use your road levers with them fine. I did that for a while (below)
It's cool, but hardly more 'comfortable' than drop bars
Likes For Soody:
Likes For Soody:
Quoted: 741 Post(s)
Liked 818 Times
+1 on the Nitto Technohomic stem. I wish I was pushing 60, instead of being the wrong side of 70. I have ridden this Legnano since new in '64. Back in the day there was more bike and less me. I hated to swap out the old original Ambrosio stem, but the Nitto provided a better "old man" reach, looks good, and they offer several fit options. I also used a Ritchie adjustable stem while recovering from a broken arm. It's another alternative to finding a fit that suits you, then you can decide on a proper stem option. Good luck with your situation.
This is not a Ritchie, but similar deal:
https://www.amazon.com/FOMTOR-Adjustable-Degree-Handlebar-Mountain/dp/B07QRPVKKL/ref=pd_day0_hl_468_2/130-1401786-6054505?_encoding=UTF8&pd_rd_i=B07QRPVKKL&pd_rd_r=9b48b7c7-08db-4c16-88a0-f21717bb51f9&pd_rd_w=GYQzm&pd_rd_wg=xxDzR&pf_rd_p=0501877d-5f8c-4ec8-9861-e0476eecc53e&pf_rd_r=JFC8BJH43735REM6686M&refRID=JFC8BJH43735REM6686M
The Nitto has gotten me thru two Eroica rides.
Likes For Slightspeed:
Quoted: 275 Post(s)
Liked 417 Times
very cool legano
Quoted: 235 Post(s)
Liked 350 Times
I didn't notice that when I suggested the Nitto; that's an important point to confirm first.
In the catalog it says alloy handlebar (SR-CTB Alloy) and stem (SR-CLS Alloy)
The M spoken of is identical to the M in a sprocket logo standing for Miyata.
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 338 Times
I went to an 80cm Nitto Technomic with a Nitto noodle bar. Changed everything for me.
Whatever you do trial your new setup without wrapping handlebar tape. You can clear tape the brake housing though. That way you can adjust, test ride, adjust, test ride, swap bars, test ride.
Likes For mechanicmatt:
Quoted: 4806 Post(s)
Liked 3,932 Times
Ben
Likes For 79pmooney:
Car free since 2018
Bikes: Mostly japanese ones
Quoted: 259 Post(s)
Liked 269 Times
soma sutro is 180mm, 1 cm shorter than Nitto deluxe. Also amazon.com has cheaper quill riser stems if price is an object.
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,612 Times
Another option:
Quoted: 246 Post(s)
Liked 338 Times
My setup
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 533 Post(s)
Liked 1,007 Times
I have both the Soma Sutro and the Nitto Technomic. The Sutro is about 1 inch taller than a normal stem, the Technomic is about 2 inches taller. Since the head tube is angled, the reach is shorter as the stem gets taller.
Quoted: 1609 Post(s)
Liked 2,216 Times
OK I will take a different approach. I think you frame is too small! I am pushing 70 and think I am the exception, but my bars are 2" lower than my saddle. I find that doing sit ups and abdominal exercise helps with the back issues. Strengthen that core and you will do better.
This is my main ride which I enjoy the most. Note that the stand kicks up the back a bit.
P1010551, on Flickr
P1010551, on Flickr
minimalist cyclist
Bikes: yes please
Quoted: 1120 Post(s)
Liked 1,643 Times
I've used these Cromo quill extenders with good results. Being very tall and not always finding the bike I want in a frame as large as I need these raise the stem up to 8½ inches. That wording "up to" leads me to believe it can be cut down if 8½" is too much. I think they were about $15 each.
What are these called? With the taller stem I may become cramped but with these I could still stretch out and not be so low. Especially with regards to to brakes. As they are currently awkward to access.
In theory would something like this work with shims?
https://www.ebay.com/itm/Bike-Handlebar-Cycling-Bicycle-Aluminum-Alloy-Sports-Parts-Replacement/303290728205?hash=item469d893f0d%3Am%3AmpoT1YIzrYnZI9nxmZIArag&LH_BIN=1
For reference only what size bars do I need?
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,491 Times
Actually, that looks like a Cinelli 1R stem which means a 26.4mm bar afaik. So you'd be looking at replacing both the stem and the bar since 26.4 was a Cinelli-specific size.
Quoted: 2338 Post(s)
Liked 2,827 Times
try tilting the handle bars up a little bit. a bit first.... i know classic is drops parallel to the ground but simple no cost to try first is tilting the bars up a bit....made a difference for me in more than one case YMMV
