Tubulars Safer for Crits?
I just don't get road tubeless. It's like trying to one up standard clinchers but is still lame compared to tubulars, imo.
Besides, the tires are just as expensive as tubulars... heavier and worse ride quality.
here's a good pro/con list
Road Tubeless Tire Benefits & Disadvantages | Bicycling Magazine
I stopped using sealant. It's ok when new and does work but on a high pressure road tire, it can also spray like a mofo before it seals.
That sealant ruins lycra. It also dries out fairly quickly and turns into another maintenance item.
It's a hassle and I never felt needed since I stopped using it. I still have a bottle of it in the garage.
Tubulars are easy. It is intimidating to newbies, but once you learn how to use them it is easy and the payoff is great.
Anyway, without further derailing the conversation, I would jump on those Zipps.
Tubulars are safe for crits and reap the rewards of lightweight and tubular comfort.
btw, tubulars feel and handle great because it is naturally a perfect circle in cross-section.
When you corner, it's still a perfect circle.
Clinchers are a U shape.
More anecdotal evidence. Sew ups are safer when they go flat. A buddy of mine flatted the rear during a race, had to go a couple of laps flat, was in the final sprint and placed.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Resident Alien
Quoted: 349 Post(s)
Liked 10 Times
Time marches on. At this point in time you can get tubeless tires at 240g that roll within a watt or two of the best tubular Crr. Great ride quality and the 25c tires are better than any tubulars I've ridden for traction and ride quality, which is a long list.
I can get them to mount without sealant on every rim I've worked with (another long list BTW), most of them within a few seconds (it did take time to learn how to do this). Put the sealant in through the valve core and I'm done, if I want sealant. I've run them without on tubeless specific rims for months at a shot.
If I flat I can repair the tire with an $0.50 internal patch, vs. sending things off to Tire Alert for repairs at $20 or so with shipping.
Installation: no glue, no glue fumes, no two day gluing process and time spent lining the tire up and making sure I have adhesion.
Removal: Much easier work with a tire lever, no Goof Off, gloves and a VOC mask to clean the rim.
Huge time savings.
No lumpy casings, no valve stem bulge, no glue deterioration, no heat causing glue to fail.
And the heat thing is worth noting as a safety benefit. I've had tubes fail just sitting out in the Texas summer heat and there are more than a few examples of glue loosening on a hot tubular rim. Tubeless will take all the heat you can give them until either the rim or the actual rubber catches fire. For another $500 I'll do a blow torch test to failure.
Mile to mile I've gotten far (far far far) fewer flats tubeless than with tubulars (or clinchers)...this might have to do with 240 of those grams being in the tire casing, vs spreading those grams out between a tire casing, a tube, a valve stem, glue, and base tape. And the tire is designed to (gasp...wait for it)
Hold air.
Most if not all tubulars vulcanize a tread layer on top of the casing, which stops making them a perfect circle before you even sit on the bike. There's nothing inherently beneficial about a perfect circle either. Go talk to a tire engineer about profile optimization.
Tubeless (clinchers) has benefits in terms of reducing pinch flats, but they are still clinchers. The rims still carry an unavoidable weight penalty, and if you do flat suddenly, you are still faced with staying upright on the 2 metal rails of death.
LOL you definitely should stick with clinchers
If I had all those issues, I wouldn't use tubulars either
Quoting a 2012 article from Bicycling Magazine's website? That's not lame?
Huge time savings.
Hold air.
Unless you and the bike weigh nothing you lose what you incorrectly think is a perfect circle the minute you sit on the bike. Weight causes deflection. The tire deforms and flattens.
Huge time savings.
Hold air.
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
Go to youtube, search crash St Augustine crit.
But I get your point,likely more crashes come from improperly glued tubulars.
You could get lost and die.
You could hit a tree and die.
Bikes: Yes
Quoted: 9 Post(s)
Safer? Debateable. Faster? Debateable. Lighter? Mostly no contest. I race on tubulars (Zipp 404 with Vittoria Corsa CX) and train on clinchers (psimet with GP4000S). I have not raced the tubulars in the rain. I trust the GP4000 so I choose them. Maybe someday I will try the tubulars.
I would consider tubeless for training and pit wheels if I could get a reasonably priced carbon rim with a modern profile, i.e. not deep V.
Resident Alien
Quoted: 349 Post(s)
Liked 10 Times
Given that you believe tubular tires are some magical perfect circle, I would guess you just breath the fumes and use Elmer's paste to glue your tires to whatever happens to be handy...a rim, a door knob, your dog...
Elite Fred
Bikes: 2009 Spooky (cracked frame), 2006 Curtlo, 2002 Lemond (current race bike) Zurich, 1987 Serotta Colorado, 1986 Cannondale for commuting, a 1984 Cannondale on loan to my son
Quoted: 60 Post(s)
Liked 42 Times
I have been behind a set of wheels with clinchers that have blown off the rims in a corner in a crit. Scary as hell. Just about as sketchy as a rolled tubular, but a properly glued tubular is OK.
And in training by myself I have had front wheel clincher catastrophically deflate and come off the rim when hitting crap on the road when doing 1 minute intervals around 30 mph and that was just crazy. I have no idea how I didn't crash. I have never had a tubular deflation scare me so badly.
gioscinelli
Classic & Vintage
47
09-10-14 06:37 PM
