silly design challenge
Quoted: 238 Post(s)
Liked 353 Times
As far as turning back to a 10 speed, if you want to do that and and some "quirkiness" , how about make right shifter front derailleur and left rear?
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 390 Post(s)
Liked 699 Times
Alright, I have ideas. But before I can spill the beans, I’ve a few questions about your spec and design constraints:
1– are you amenable to more cable stops being clamped onto that lovely paint job?
2– must the bell stay on the stem?
3– is that front brake nutted or recessed mount? (looks recessed but want to confirm)
4– how much clearance is available between tyre and fork crown?
Use a 3D printer to make a shift lever replica which just slips over the existing bell ringer and latches on.
It will poke up more than the one you have and will be easier to actuate.
You don't have to change anything and the bell will ring as well as ever. If it gets lost, stolen or breaks, print another.
bironi
Quoted: 101 Post(s)
Liked 298 Times
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Quoted: 142 Post(s)
Liked 316 Times
Thinking of handicapped painters who have headgear to hold the brush, why not attach a drumstick to your helmet? The Nod-bell (patent, not pending even a little).
Quoted: 1836 Post(s)
Liked 3,430 Times
In my work in the electronics part of the Big Yellow Machine company, one of the folks handled all of the horns, alarms, etc. that were used on the machines.
He had some air horns on his desk, and I was quite tempted to ask for some used parts for my bike!
The thought of getting buzzed by some jerk and then hitting the button of a big air horn was quite enticing!
However, once I started running the numbers for the size of the battery required to power the horn, I decided that it wasn't really worth it.
If someone does want to play around with an amplifier and speaker, there are mp3 files of train horns available on the web.
Steve in Peoria
Likes For steelbikeguy:
Quoted: 4853 Post(s)
Liked 3,990 Times
I like the quirkiness and going against the C&V ethos.
Instead of rigging the bell to the shifters, I'd rig up some Roman candle launch tubes and sparker from Bic lighters to the shifter levers as ignition sources. Plenty of times I'd be awful tempted to retaliate against hostile drivers with some fireworks.
Of course, this doesn't answer the OP's question. I think the shifters look just right as is on the DT so I'd go a different route. Maybe a silver spoon (or would lowly SS sound better?) I'd want the pivot on the stem under 6 o'clock on the bell. Striking at 10 o'clock. So you brush your hand back beside the top of the stem to pull back the lever to strike.
Likes For 79pmooney:
Along for the ride
Quoted: 111 Post(s)
Liked 213 Times
boy, when I was still working, I bike commuted and dealt with a few rude motorists (but have to give credit to many folks who were very considerate and respectful!)
Steve in Peoria
Steve in Peoria
Likes For retswerb:
Quoted: 1617 Post(s)
Liked 2,225 Times
Have one of these and it is loud enough to get car drivers attention.
Amazon.com : Hornit dB140 Bike Horn (dB140 V3) : Sports & Outdoors
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4699 Post(s)
Liked 5,857 Times
In all seriousness, shifter bosses are threaded M5. If you can find a bell that has an M5 thread, just screw it in. If the bell is female threaded, a bit of M5 threaded rod will work to mate them. Or hack off the head of an M5 bolt, clean the threads, and use that.
If you have a bell that you'd like to use and it doesn't have an M5 thread, the Atelire could silver braze on a bit for you. I've done it before for another application. If you want or need a vintage bell, I know a guy.
Likes For gugie:
