How Does Chain Length Affect SI?
Quoted: 2514 Post(s)
Liked 2,995 Times
It's a metaphor. How do the chains (of capitalism) affect the Solomon Islands (SI)? OP is trying to start a discussion regarding how the economic imperialism of western nations contributed to the widespread economic, political and social instability experienced by many former colonial possession upon gaining Independence, which is illustrated by the ethnic violence between the Guales and Malaitans in the late 1990s, and how modern day expansion of Chinese business interests continues to contribute to the instability in the region.
When OP refers to splitting the chain, and then shortening it, he is referring to the frequent need for deployment of Australian and New Zealand troops to the region to quell simmering ethnic tensions. Yes, it solves the immediate problem, but fails to address the underlying conditions leading to the problems in the first place.
Quoted: 656 Post(s)
Liked 470 Times
Old fart
Quoted: 3599 Post(s)
Liked 3,424 Times
Quoted: 3389 Post(s)
Liked 5,562 Times
International System of Units (SI, abbreviated from the French Système International (d'unités))
Quoted: 1865 Post(s)
Liked 665 Times
Interesting that the OP never responded. I think this is a question that can’t be answered.
I just measured the side plates on my 8, 9, 10, and 11 speed chains. They vary a little by brand but are all very close to the same thickness. It’s the bushings between the plates are what vary in size. That’s why the myth the narrow chains break more often is just that, a myth.
Quoted: 2345 Post(s)
Liked 2,858 Times
he responded in a build your bike thread in mechanics he meant SIS so shimano indexed
Liked 665 Times
Quoted: 7359 Post(s)
Liked 2,497 Times
Si is the Spanish word for yes. It is also the French word for yes if in response to a negative question.
Quoted: 4475 Post(s)
Liked 1,615 Times
7 speed chain bushing - .092" 10 speed chain bushing - .090"
7 speed side plate thickness - .049" 10 speed side plate thickness - .030"
The bushings can't have gotten narrower because chainring teeth haven't gotten narrower. You can run an 11 speed chain on a 1980s six speed chainring.
Quoted: 935 Post(s)
Liked 1,327 Times
Old fart
Liked 3,424 Times
Yes, you can. But then you risk jamming the chain between the rings when shifting between them. Better to use a 7-speed chain with a vintage crank, if at all possible.
Liked 1,615 Times
None of which has anything to do with bushing width, which was the point I was making - 11 speed chains will work fine on any multispeed crank's chainring tooth profile going back to those for 5 speed chains. The chains got narrower by thinning the plates, which necessitated different pins because of the decreased contact.
Old fart
Liked 3,424 Times
Liked 1,615 Times
You can jam a chain of any width in the open gap between spider arms. I just don't think the danger of doing so with 11 speed chains is that much greater than it was with your 9 speed chain or a 7 speed chain.
Quoted: 3464 Post(s)
Liked 2,832 Times
Ride, Wrench, Swap, Race
Quoted: 1566 Post(s)
Liked 1,299 Times
The wider chainring spacing of today's compact cranksets is not an issue since the big ring now has it's inner surface heavily ramped and thus further offset from the plane of the teeth than on traditional chainrings.
The actual space between the small ring's teeth and the inner surface of the big ring at the outer radius of the small ring is what will affect the possibility of the chain slipping between rings.
I've retrofit modern 9s chain to a lot of very old bikes, some work perfectly while some allow a narrower chain to jam between rings or to merely skate along the tips of the teeth, depending on the model of crankset and to a seemingly lesser degree on the size difference of the two rings.
I once had a new 9s chain almost immediately get stuck between shimano 600 6s-era chainrings and gore the chainstay of a brand new Cannondale frame, so won't easily forget that.
I have yet to see a modern chain fit too tightly on a vintage bike's chainring teeth, but some "semi-modern" chains (from the 7s era) did actually have that issue because of too-narrow bushings. Those were brands no longer offered so of no concern today, and I suppose they were having difficulty maintaining a large enough inside width as they had to redesign the outside width for the then-new Ultra or 7s cog spacing.
Liked 2,858 Times
This is a bit like the command line unix/linux guys refusing to use a GUI editor. and VI is a terrible editor (fighting words for some )
Quoted: 2367 Post(s)
Liked 1,756 Times
Old fart
Liked 3,424 Times
Bikes: Hetchins, Dawes, Raleigh, Holdsworth, Standard Cycle Co, and others
Quoted: 34 Post(s)
Liked 6 Times
All this fuss over a typo
When I started this thread I was actually expecting a technical response. Its like being back at university, where every double-entendre is seized upon, and the original question is lost.
As I think everybody knew I should have typed SIS, but clearly no-one has a credible explanation. Please prove me wrong
Liked 1,615 Times
Despite that, a few of us did have technical discussion about shifting accuracy and chain length. Did you read it?
Quoted: 34 Post(s)
Liked 6 Times
This was not a question about shifting accuracy, although the conversation went that way. It was about why chain length, not its specification, was the sole factor in preventing access to all gears in such a major way, by reducing the throw distance of the derailleur.
Since I deal with vintage bikes in the main, SIS is considered modern. Mostly I build with friction shifters, although I do like to replace the downtube shifters with handlebar shifters. Since mostly, I am restoring the frame, then brazing a double guide on the frame downtube, and cutting off the old stubs is my preferred route.
The SIS technology may now be superceded, but that does not impact on its name, unless you want to start calling SIS a "legacy" product.
