Help me find an English Stronglight BB
Ride, Wrench, Swap, Race
Quoted: 1566 Post(s)
Liked 1,300 Times
Keeping a few worn/spent JIS cartridge bottom brackets around instead of discarding them is perhaps the simplest, most reliable way to ascertain (by a quick test-fit) what length JIS spindle is going to be the best one to buy.
Comparing the relative depth of engagement of different 2-degree tapers in any given crankarm is perhaps most easily done by locking a caliper to a 13mm opening width, and then simply comparing how deeply that any two different spindle ends will pass between the jaws.
You will still have to also compare at least the driveside lengths that the different spindles protrude past the face of the bb shell (unless both were known to be perfectly symmetric) to get the chainline right.
Yes, tapers appear (and are) different, but it's their thickness that needs to be compensated, not any nonexistent difference in their taper angles.
If the taper angles were different, the installation would not likely be reliable and the chainring rotation axis might not stay true under power.
Not that the reduced engagement depth of a JIS spindle taper isn't less than perfect, but does at least have a good track record of working properly, and I've seen OEM spec of a JIS bottom bracket with a Campagnolo Record crankset.
Taper-length differences are sometimes also cited, but since the taper dimensions reference off of the end of the spindle, the length difference rarely has any effect on the contacting surfaces, and exists only inboard (toward the center of the bb shell) of the hole in the crankarm so not touching anything but air.
Does stating something that is known true, versus not true, make someone an "expert" in any field? I mean did any of us here design any of these parts?
Should we then be praising your "expertise" for every one of the statements that you post?
blahblahblah chrome moly
Quoted: 1196 Post(s)
Liked 2,606 Times
The only differences I have seen are the size at the small end, and the length of the taper before it ends, usually at some sort of shelf. The only things that can go wrong are:
- going on too far, to where the back of the crank hits the shelf
- not going on far enough, due to the taper being too big, so the small end of the taper is too far recessed into the arm, inadequate engagement.
Chain-line is another issue, which can be dealt with a number of ways. I don't consider that a taper incompatibility per se.
Likes For bulgie:
Liked 1,300 Times
Like Carl Sagan said, extraordinary claims require extraordinary evidence. Since everyone else says all tapers are 2°, I think you need better evidence than "I held two spindles up next to each other". I am highly skeptical that you can see taper angle differences by eye. Good on ya if you can, but please don't be insulted if I doubt it. I've been mixing spindles and cranks since the '60s, was in the bike biz for ~30 years and have remained an active hobbyist in the 25 years since then, but I don't consider myself an expert. I know for sure I can't discern the difference in angle between say Campy and Stronglight (or any other brands I've tried) by eye, because I've tried. I have always gone on the assumption they are the same angle, and have never found any evidence to the contrary. Other than Lambert, I have never seen any spindle with any angle that wasn't compatible with Campy/Sugino/Stronglight/TA/etc. Yes, spindles and arms can be incompatible for other reasons, but never for a difference in angle. Other brands with other angles (Ofmega?) are rumored, but I've never seen one with my eyes, in the half-century I've been doing this.
For racing-grade setups, I guess maybe we shouldn't be mis-matching spindles and cranks at all, and perhaps not for stronger/heavier recreational riders either.
But (quoting Chas C here) "if it fits, it works" does seem to hold true in my limited experience of perhaps a half-dozen such "batard" installations.
One more detail of using a JIS spindle in a French, Campy or ISO crankarm has to do with the four visibly-bigger radii on the JIS square taper that effectively makes the contacting flats narrower. This is a bit sub-optimal imo, but hasn't caused me any problems as a spirited lightweight lightweight rider in the foothills. I am imagining that the narrower flats and reduced engagement depth will increase the outward force and thus pressure exerted along the edges of the flats via "camming" forces against the inside of the square hole, possibly leading to increased wear of the mating surfaces. But I have also noticed that the chainrings run perfectly true on French Stronglight cranks and ISO-sized Sugino Mighty cranks that I've mounted on JIS spindles.
Quoted: 4513 Post(s)
Liked 1,650 Times
Quoted: 981 Post(s)
Liked 1,844 Times
Sorry, but anyone who thinks they can measure within a degree of difference by eye across parallel lines interrupted by bearing races and different shades of metallic gray over the space of a few inches is full of it.
Likes For Kilroy1988:
Quoted: 795 Post(s)
Liked 1,812 Times
Okay, so it turns out I have a Sugino bottom bracket that I've actually been meaning to remove from the frame in question, and it has a 119mm spindle. The Stronglight crank arms seem to fit over it well, however, on the non-drive side there's ~30mm between the shell and outside of the arm, and on the drive side it's 40mm to the outside of the arm. I assume it'll tighten up another millimeter or two once they're pressed on. Does that seem like a reasonable distance to the outside of the arms and should it be slightly more on the drive side? I'm assuming this Sugino 119mm spindle is really meant to take a JIS triple...
By way of comparison, I have a 1982 Pro-Miyata sitting here and from the outside of the arms to the BB shell on either side is ~32mm with a double and it's more or less even on both sides.
Would a Stronglight 118mm spindle make the distance to the outside of the crank arms more even than this or would there be a slight offset on the drive side in that situation as well?
I hope that question makes sense. Thanks!
-Gregory
-Gregory
Likes For zukahn1:
Liked 1,650 Times
One spindle is horizontal and on the left. The other spindle is horizontal and on the right, just above the left spindle. You press the top taper on the right side of the left spindle to the bottom taper of the right spindle on the left side and hold them with firm pressure or a clamp. It is relatively easy to see whether that one 6" spindle is parallel or not with the other 6" spindle.
If you were unable to see that, you would also be unable to perform basic tasks like hanging a picture straight or aligning a disc caliper.
You are aware that 1 degree of offset over 6" is a tenth of an inch, right? Do you think you can see a tenth of an inch?
Quoted: 981 Post(s)
Liked 1,844 Times
Firstly, a 120mm spindle is 4.72 inches long. If you overlap the tapers in the center, you lose approximately half an inch in the middle. You cannot look out to the far ends of either because a half an inch on either end is also tapered and not straight. So you're looking at about 8" distance between the far ends that are straight (i.e. inside the tapers), and you have the bearing races completely distorting the view of those far ends anyway. Finally, and critically, because you are pressing them together in a central point, the offset of the 1° difference (assuming it is there) is halved again in either direction - it's a 1° difference from the center to either end, not end to end. So, you're really dealing with about 3.5" of offset at 1° at best.
What you actually have to compare the angles are only the absolutely straight sections between either bearing race, which are themselves less than 3" long and are separated from one another by about an inch and half that's being taken up by the overlapping tapers in the middle and the inside races. You can't look straight down anything, and you can't look across any unbroken space to see the two lines converging because of the fact that your spindles are offset (one on top of the other) and that you have the bearing races in the way.
That being said, across less than 8" with four different bearing races in the way (not to mention either your hand or a clamp), you are expecting me to believe that you can see with your naked eye an approximately 1.5mm offset that resembles a slight kink in the middle of a totally obscured line? It's no wonder you think the taper on different spindles are so dramatically different with such flights of fancy.
It's not comparable at all to hanging a picture frame or adjusting disc brakes or doing any other task that requires you to eyeball 1/10th of an inch on a clean horizon.
-Gregory
-Gregory
Liked 1,650 Times
Firstly, a 120mm spindle is 4.72 inches long. If you overlap the tapers in the center, you lose approximately half an inch in the middle. You cannot look out to the far ends of either because a half an inch on either end is also tapered and not straight. So you're looking at about 8" distance between the far ends that are straight (i.e. inside the tapers), and you have the bearing races completely distorting the view of those far ends anyway. Finally, and critically, because you are pressing them together in a central point, the offset of the 1° difference (assuming it is there) is halved again in either direction - it's a 1° difference from the center to either end, not end to end. So, you're really dealing with less than 4" of offset at 1° - or approximately 1/25th of an inch.
That being said, across less than 8" with four different bearing races in the way (not to mention either your hand or a clamp), you are expecting me to believe that you can see with your naked eye an approximately 1.5mm offset that resembles a slight kink in the middle of the line?
And by the way, I drew this all out with a protractor and a fine ball point pen, and the line drawn between the far ends overlaps the line representing the edges of the spindles for almost half the length on either end because the difference is so slight. Looking straight down the two spindle lines it's possible to see that they're uneven, but that's discounting all of the real-life variables involved with looking down the length of the spindles, which is absolutely impossible due to the bearing races.
-Gregory
-Gregory
If that is too challenging, hold them up in front or some other horizontal line, like a window frame. The angle of the second spindle to the window frame will be obvious for the same reason that you were able to align the first one to the frame.
People can see very small differences in angle between parallels, and we can see deviations from horizontal and vertical very easily as well. Your instance to the contrary does not change these facts.
And 1mm is 1/25th of an inch. 1.5mm is a 1/17th of an inch. Pick one.
Quoted: 981 Post(s)
Liked 1,844 Times
You don't "sight down" the spindles. You hold them up level if front of you. If you make one level you'll be able to see if the other is. Hanging pictures.
To the second point, that's not just using your naked eye and I never said you couldn't discern a difference if you were to create some frame of reference using a tool like a window frame. That's got nothing to do with your claim.
-Gregory
Quoted: 981 Post(s)
Liked 1,844 Times
And yeah, people can see very small differences in things. I used to play a game on my computer where all you have to do is try to create specific angles or parallel lines as part of a challenge. Sometimes I could be dead on and other times I could be a hair off. Just using your eyes without a frame of reference (like the straight edge of a ruler or a windowpane) is not a reliable way to say that you're discerning slight differences in the taper of a bottom bracket spindle. Sorry. There are way too many variables at stake when you have two small, unevenly shaped objects in hand such as that. If you think you can do it again, I call BS because you could just as easily be a degree off by thinking it's not straight.
Old fart
Quoted: 3601 Post(s)
Liked 3,429 Times
