Mechanical discs (TRP Spyre), lever pull too long?
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,221 Times
Adjust the pads in. They should just clear the rotor. Think about the thickness of a sheet of paper or even less.
Stuart Black
Stuart Black
Liked 4,221 Times
Work on straightening the rotor more. Go with small adjustments with your adjustable wrench. Sight through the gap between the pads and rotor. Once you have gotten the rotor straight, recenter the caliper like I detailed above. If you can’t get the pads closer to the rotor, compressionless housing won’t help.
Stuart Black
Stuart Black
Quoted: 427 Post(s)
Liked 339 Times
Truing your rotor may help immensly to get pads closer without rubbing
Yeah. That's the biggest issue with the front, but it seems impossible to do with an adjustable wrench. Maybe a shop would have a special tool? I can get it close, but... I think a better rotor would help. The TRP brand 140mm in the rear is almost perfectly true. The Jagwire 160mm in the front is way off and seems to change by the day.
Liked 4,221 Times
One other tip, when you fix a flat, be sure to keep the rotor side up. Sometimes, while you are wrestling with the tire bead, you can put pressure on the rotor if it is down and bend it. Speaking from experience here.
Stuart Black
Stuart Black
