Tube pressing into spoke holes blowing tube?
This is what works for me with my high pressure tires:
https://www.ebay.com/itm/Bicycle-Rim...wAAOSwW4ZbnnAu
https://www.chainreactioncycles.com/...waAu36EALw_wcB
Bikes: 80's Schwinn High Plains, Motobecane Ti Cyclocross
Quoted: 108 Post(s)
Liked 30 Times
I had the "nipple pimple" problem with one particular rim/tire width combination and solved it by using a layer of Shwalbe Mylar high pressure rim tape and then putting the Vellox back on over it.
Neither one worked by itself.
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
Have you thought of trying the Velocity Veloplugs rim plugs? If it's a double walled rim, they work nicely.
https://www.amazon.com/Velocity-Velo.../dp/B07BQBSDYF
They are a big, big convenience. No more worry about rim tape moving, bulging, or blow through (Note: I NEVER had a problem with Velox, but it ws not carried by some of the LBS, who carried the plastic strips).
THey do not work with all rims, or even all velocity rims, but they have different sizes.
With a mighty wind
Quoted: 1089 Post(s)
Liked 871 Times
You got a screaming deal on those wheels. Got any pics to drool over?
If your bike can fit 28's, try that.
Are you using regular tubes or ultralights? Should be around 100g per tube, otherwise too light for durability.
There used to be a product that went in between the rim and tubes to prevent pinch flats on mountain bikes, when people still used tubes on them. I'll edit this post if I find something like that.
Quoted: 2364 Post(s)
Liked 1,751 Times
Quoted: 405 Post(s)
Liked 430 Times
For 50 bucks.
PHIL WOOD HUBS!!!!!
FOR 50 BUCKS!!!!
Dude... the hubs alone are $650 a pair. That's like a 900 dollar set of wheels.
And, yes, you will get far fewer flats, and be way more comfortable, and probably ride noticeably faster, if you run wider tires.
Also. you should send that guy a bottle of good single malt, cuz he's a righteous dude.
--Shannon
Post some pics of those, including the inside without the rim tape. One thing I've seen happen on my wheels a few times is that even though the rim tape is covering the holes, it will slide when mounting the tire. It's happened a few times to me and is usually a sign to get new tape. I had that problem with a bike I just resurrected from the basement a month or two ago.
Quoted: 6199 Post(s)
Liked 4,816 Times
What is limiting you on tire size for the Trek 1? The frame or brake calipers? The Rigida 1320 was a wide enough rim to hold more than a 27 x 1 safely. It was a crappy rim though. IMO. They don't stay true.
Are the spoke ends poking out of the nipples?
