Garmin 130 Battery Life is Short. Any solutions?
Should Be More Popular
Quoted: 22714 Post(s)
Liked 9,075 Times
I bought this unit when it came out 2-3 years ago. It has been reliable but battery life has always been sucky. It’s supposed to last 12+ hours but I usually get 5. On today’s ride it died after only 4 hours. I have NO sensors or devices connected to drain the battery other than my iphone.
Anyone else use this unit and found a good solution?
Liked 9,075 Times
Some Garmin units were doing a poor job of reporting battery. Run it down to zero, then turn it off and back on, Keep doing this until it won't come back on at all. Do a full charge.
How's your cell coverage where you ride? There's been some discussions about poor cell coverage causing the Garmin to constantly reconnect blue tooth which in turn drains the battery. You could try a ride without your phone connected to see what happens to the battery life.
A more drastic option is to do a full factory reset. You loose your setup and accumulated data, but it may help.
Likes For tntyz:
Hear myself getting fat
Bikes: Sir Velo A Sparrow
Quoted: 335 Post(s)
Liked 265 Times
When my wife was having battery problems with her 810 we found it was an issue with the unit repeatedly trying to find Garmin Connect on her phone. Once we quit connecting to GC it improved a great deal, and turn off BT on the unit too since you don’t connect sensors anyway.
Maybe not connecting it to your phone will help you as well?
Are you on the latest firmware? I’ve heard of battery issues on the 130 for a while Garmin might have addressed the issue in a new firmware update.
Liked 9,075 Times
Likes For datlas:
Quoted: 6335 Post(s)
Liked 4,929 Times
How do you charge it? Are you certain you are getting a full charge. Battery meters on these devices guess the battery capacity based on voltage profiles looking at very small fractions of a volt. So if you are unplugging the device as soon as the battery meter say 100%, then maybe it's not fully charged. I leave my 10 year old edge 500 plugged into my PC after uploading the ride data till I go to bed that evening. Might be six to eight hours or more. And it seems to have every bit of battery capacity it had when new.
Also, sensors like power, wheel, cadence and HR don't drain the device battery. The device only listens to them, never talks to them. What does drain a battery is backlighting. Also anything that requires it to transmit, like sending data to a phone app.
Likes For kissTheApex:
Quoted: 3320 Post(s)
Liked 2,156 Times
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
i have the 130. I live and ride where cell phone coverage is spotty to nonexistent. I have the battery problem as well. (I also connect a radar to it.)
Etrex series GPS. Runs on AAs and lasts for a loooooong time on them. It doesn't support the Varia Radar though (but I don't care), and it's a bit thicker and heavier (I care even less). They also have a stable system that doesn't make you lose data in the middle of a ride.
Can't understand why people keep buying devices whose battery can't be easily replaced and after 3 years it lasts nothing.
Quoted: 18883 Post(s)
Liked 10,646 Times
Liked 9,075 Times
I had online chat with Garmin support. They said I could try deleting unused files but that’s about it.
They told me I could exchange my unit for a factory refurbished unit, which I might consider but will try it on some longer rides with Bluetooth off on my iPhone as I expect this may be a battery drain. If that does not solve the problem I may send the unit back.
Liked 4,929 Times
Do you need it connected to your cell phone? If so, then try removing the app and reinstalling it. And if you loaded other Garmin apps to try connecting with that device but don't use them, make sure they are not running in the background still. Remove them if you don't need them for anything else.
Still, the biggie is back lighting. Do you use it? Do you have to use it? On my Garmin 500, I can usually tilt the handlebar mount to give me an angle that I can see the display without having to use any back lighting at all.
And make sure you a charging it long enough. Don't go by the little battery meter they show you.
Likes For Iride01:
Likes For Bmach:
Quoted: 243 Post(s)
Liked 234 Times
Garmin released a new firmware, v 3.70, with the following updates:
Changes made from version 3.60 to 3.70:
- Fix recovery advisor not syncing to other Garmin devices
- Prevent odometer from showing distance from discarding activities
- Improve battery life while paired to a phone
- Improve radar error handling
- Update for CIQ security
Likes For RGMN:
Quoted: 668 Post(s)
Liked 529 Times
Can you hook a cell phone back up battery to it while riding? Consider a small handle bar bag with a wire to the unit.
Occam's Rotor
Liked 2,331 Times
I actually upgraded to the 130 because I was frustrated by the battery life of the 25. (i.e., it can be a lot worse).
I've also noticed that the charge indicator can report 50% charge (when it should be fully charged) and then a few minutes later report a 100% charge. My Edge 25 never reported anything better than an 80% charge (4 bars out of 5).
Liked 9,075 Times
Liked 9,075 Times
Bump.
My battery life has gone from bad to worse, which I expect is due to age. Now lasting only about 3 hours, the ONLY connections I have are BT for my Phone and Varia radar, which I consider both essential. I retried all the tricks for battery life as well. No improvement. I contacted Garmin and they did say they could exchange out a "refurbished" 130 (presumably with a new/fresh battery) for my old unit for $50. I really do need the unit to work for my longer rides which are typically 4-5 hours. I don't really want a fancier GPS unit so I did take them on their offer and am hoping the new unit will meet my needs.
Will update after I get new unit. I am also open to other suggestions, but don't want to pay $300+ for a larger and fancier GPS unit, although that may eventually happen in the future.
I had an Edge 500 then a 520 which both exhibited shortened battery life when using the connection to the phone. My solution was to stop using the Edge to phone connection. To handle "incident detection", installed the Road ID app on my iPhone which tracks if you've been stationary for 5 minutes and then sends a distress signal. I guess you have to have a phone that has GPS.
What other features do you feel are essential that require the phone connection? Though $50 is a reasonably priced solution.
Liked 4,929 Times
Are you just going by the battery percentage shown on the device or running it till it actually dies? I never pay attention to the battery meters on any of these devices as they don't actually measure the capacity going in or out. They just simply rely on a voltage profile to make an assumption.
