Please help picking 1st road bike
#51
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1127 Post(s)
Liked 255 Times
More than a few steel bikes have had lug failures. So maybe @beng1 should do a search for that!
There is a reason why all steel bikes back in the day were warranted for life, while CF bikes today are warranted for 3 to 5 years.
Why Carbon Fiber Bikes Are Failing (outsideonline.com)
(2) Throwback Thursday: Why you should be riding steel and not carbon | Road Bike, Cycling Forums (roadbikereview.com)
Bike frame materials compared: alloy vs carbon vs steel vs titanium - BikeRadar
I'm not slamming CF, just pointing out that there are issues that can cause a major and sudden catastrophic failure. Look, I have a Lynskey TI bike, it uses a CF fork, so I'm not against CF. However, since I knew this stuff when I bought the bike, I opted to go with a tandem rated CF fork, a Enve 2.0, I only weigh 173, so this fork is designed for that weight and up to 240 pounds, PLUS another person! I opted to go with an over-engineered fork.
You can go to any bike shop and walk up to any CF bike on display and take your finger and thumb and squeeze the middle of the top tube and you will feel it give slightly, not reassuring! Additionally, because CF is so weak you have to use a torque wrench for anything you need to tighten on it, and you better make sure you have the correct torque specs, over tightening something could cause that part to fail; there is no room for error with a CF bike. You can't even clamp a bike repair stand clamp to a CF tube, it has to be clamped at the seat post.
This guy is extremely knowledgeable in this stuff, this is highly educational, pay attention: (39) Carbon Fiber Bikes - Are They Strong Enough? (ft. Raoul Luescher) - YouTube
If you like, you can watch his other videos, very informative stuff.
Likes For rekmeyata:
#52
Quoted: 4494 Post(s)
Liked 4,966 Times
#53
Liked 4,966 Times
Guys running 100 psi on 25 mm tyres have no advantage unless your roads are super smooth and even then it is not significant. On rougher roads you will have the advantage, especially on a long ride where fatigue is a major factor.
#54
Quoted: 7666 Post(s)
Liked 3,534 Times
As for tire pressure, I recommend testing. Everybody rides differently .... I weigh an eighth of a ton but I ride "light" in that I rise up over obstacles, big cracks, train tracks, and such, so that my legs, not the bike, absorbs the impact. That is how I get away with 24- and 28-spoke wheels despite my weight.
With new tires wheels, or a bike, I generally start my tires stiff (so if I press with a thumb there is very little give,) and then let out air ride after ride (or just don't pump them so hard) until I like the feel .... if the tires--particularly the rear--feel like the wheel is shifting sideways over the contact patch, I know I need more air,. if I get a pinch flat and didn't hit some obstacle I didn't see, then I know I need more air.
32-mm at 70 psi for me would be worthless. I know because I have 32s on my Cannondale and I run 90 optimally. 70 and I would be crashing or walking ... but if you weigh less, or have different wheels, or different personal preferences ... you might be fine at 65, who knows? Only you can say what works for you, and only through experimentation can you learn.
I recommend against extremes .... drop a few psi per ride, not 20--but do experiment. As was noted above, hard tires only really help at the track. On the road, a little give is a good thing.
Likes For Maelochs:
#55
Quoted: 6269 Post(s)
Liked 4,863 Times
All bikes have had some issues no matter what material they are made from CF isn't any different in that respect. It's much of the early design mistakes that keep getting put forth by fear mongers that CF is bad. And along the way there have been and will be other design mistakes or manufacturing mistakes as were those lug failures.
Carbon Fiber bike frames also enjoy a lifetime warranty too. Just like some steel frames only have a 3-5 year warranty. Depends entirely on the manufacturer or brand of bike and the tier level a model of bike belongs too.
#56
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Carbon fiber frames are like anything else. There are good ones and there are bad ones. Granted that metals won't shatter to pieces, but they can still fail in a way that makes you kiss the pavement.
It is in fact possible to make a carbon fiber frame that is way stronger than any alloy frame. Note that jets are made of carbon fiber and planes aren't falling out of the sky. Trouble is most people buying a carbon fiber bike want the lightest weight there is and don't want to pay a fortune for it. And as the saying goes, light, cheap, durable.......pick two.
#57
Liked 255 Times
#58
Liked 3,534 Times
I hear that there are still people claiming that only some materials are suitable for bike frames .... and the Earth is still flat, right?
#59
Liked 255 Times
I find it amazing how many smart arse cyclists there are on these forums. Another igiot who didn't bother to comprehend what I said or look at all the videos, just mouthing off.
#60
Liked 3,534 Times
At least you feel at home here, eh?
#61
Habitual User
Quoted: 5039 Post(s)
Liked 8,264 Times
CF is brittle, and a lot of people sell their CF bikes after a crash because they don't know if the frame was damaged or not, and unless you have the frame x-rayed there is no real reliable way to tell unless it actually cracked, the problem is most damage that happens occurs on the inside of the tube not the outside. It's a lot like an iceberg, what you see on the surface could look like a scratch but underneath the surface it could be fractured or delaminating. I would never buy a used CF bike, but that's not to say you can't get a good one, just saying the risk isn't worth it.
The next thing I'll hear is how you bought 1,000s of used CF bikes and never had an issue, and that may be true, but like I said there is a risk. I don't know about you, but when I am riding at 20 or coming down a steep grade, I'm not sure if I would want to find out that the bike was compromised before I bought it and it took a while for it rear its ugly head as I land on mine!
I have a 20+yo CF MTB, that is pretty beat up, and I still ride pretty regularly. I have a CF road bike (bought used) that I spent a good amount of time doing 30+mph on today..and many other days. I have another CF MTB (bought used) that I have ridden hard in some extreme conditions for over a year with no sign of any issues. I also have a CF gravel bike (bought used) that has been pushed hard for some pretty long and tough rides. Which one should I expect to assplode first?
#62
Habitual User
Liked 8,264 Times
Likes For Eric F:
#63
Quoted: 2529 Post(s)
Liked 3,014 Times
Checking just 2 of the biggest names, both Trek and Specialized have lifetime warranties on their frames, regardless of material. This is really easy to verify. Please stop making things up.
Or, I can go to my garage, and squeeze to top tubes of 4 different CF bikes. Zero give on any of them. Please provide specific makes and models of bikes where you personally experienced what you describe.
As for carbon requiring the bike to be clamped in a stand by the seatpost, the only frames I've seen that were damaged by being clamped in a bike stand were two steel bikes, where customers had wheeled their bikes in and clamped them in the stand by the seat tube, not realizing that the clamp was currently adjusted to clamp the seatpost. The seat tubes ended up optimized for crosswind aerodynamics.
A little-known fact about steel frames: different steel tube sets have different recommended weight limits. The Columbus SL tube set, for example, was recommended for racers up to approximately 180 lbs, and KL was recommended only for record attempts and was therefore considered too fragile for other forms of racing. Similarly, the lightest Reynolds tube sets were intended for light riders and record attempts.
The new higher-strength steel tube sets enable frame builders to sell frames that are lighter than the frames built with the older steels, but higher strength equals greater brittleness in steel. Luckily, the riders who are wealthy enough to afford to buy bikes built with those new high-strength steels tend to be older (and to have their racing days well behind them) and are thus unlikely to ride the bikes hard enough to put them to the test.
Likes For Trakhak:
#64
Sock Puppet
Liked 863 Times
#65
I had a Trek Madone 7 series with what they called Kamtail tubing. It was very easy to deflect the flat side of the tubing, but not the sides. Like someone else said, thin walled chromoly frames from decades ago could also be pinched.
#66
Liked 255 Times
Please help me understand how CF material can suffer catastrophic internal damage without any external evidence.
#67
Habitual User
Liked 8,264 Times
No. It’s pointless. CF has too long a history as a proven material for bicycle frames and parts for you to convince me otherwise. Additionally, the credibility of your arguments is already shattered with your BS about squeezy tubes and warranties. It’s regurgitated nonsense that has been circling for years.
Likes For Eric F:
#68
Quoted: 1514 Post(s)
Liked 735 Times
IMHO it's never a bad idea to buy used for your first bike. You're likely to get ideas of what you want to change after riding for a month or two, and by buying used you'll still have a budget to work with; be it for upgrades on that bike or buying a second one (n+1, baby!) Have a friend that knows what he's looking at help you..
Likes For BlazingPedals:
#69
Liked 255 Times
#70
Liked 255 Times
You darn right know, unless you're weak, you can take your thumb and index finger and squeeze a top or down tube on a CF bike and it will give in slightly, try it to your bike. 4 to 6 NM on a torque wrench setting for mounting stuff on a CF frame or handlebar is not that much pressure, and that is the standard they tell you for mounting stuff, that is a fact that you would know if you wrench on your CF bike. My grandson who is 16 didn't believe a person could squeeze those tubes either, so I took him to a bike shop and had him walk around to several bike and do it, to his amazement he could feel them give a tiny bit, I told him to do the same thing with several aluminum bikes they had in the shop, he couldn't do with those.
Your refusal to watch those videos is because you refuse to learn anything, not even from professionals in the field.
#71
Liked 3,014 Times
Just pressed my thumb down on the flat top of my coffee table. I could swear I felt the veneered half-inch-thick particle board compress. I'm stronger than I realized.
#72
Habitual User
Liked 8,264 Times
There is no perfect material for bike frames. All materials can break, especially when subjected to high-speed impact. I’ve ridden and raced on steel, aluminum, titanium, and CF bikes. My preference is CF.
Likes For Eric F:
#73
Habitual User
Liked 8,264 Times
I suppose there might be some frames out there that might deflect under this test, but it’s hardly a universal thing for all CF frames.
#74
Liked 4,966 Times
But it would appear that I was mistaken and you are not really slamming CF at all. I can see now that you are just attempting to educate us as to why we should all be riding metal frames with perhaps "tandem rated" CF forks if we are feeling brave.
Edit: I just read your first 2 links. The first raised a few sensible points, the second one about why we should choose steel was as lame AF. But the reference to diesel engines was funny with the benefit of a decade's hindsight.
#75
Quoted: 8335 Post(s)
Liked 9,170 Times
eRoad bikes are speed machines – bicycles designed to take you as far and as fast as your legs can manage with an extra e-help. The road bike gets its name from the terrain it is designed to be used on; pavement. eRoad bikes are optimized for riding on smooth pavement. It usually has skinny tires with a very light tread.
