Go Back  Bike Forums > The Racer's Forum > Track Cycling: Velodrome Racing and Training Area
Ask your small, random, track-related questions here
Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Old 04-07-18, 01:01 AM
  #5001
Poppit's Avatar
Quoted: 111 Post(s)
Liked 5 Times in 4 Posts
Nothing on the extensions, the Zipp carbon extensions that I use have a rough surface
Poppit is offline
Old 04-11-18, 01:29 PM
  #5002
theblackbullet's Avatar
Bikes: I don't even
Quoted: 81 Post(s)
Liked 193 Times in 77 Posts
I have cork on the bars and extensions. I feel like a little extra grip is nice at my quite bumpy home track. Might ride no grip on extensions if DLV was smoother.
theblackbullet is offline
Old 05-05-18, 10:56 PM
  #5003
Bikes: Marin Stelvio, Pogliaghi SL, Panasonic NJS, Dolan DF4, Intense Pro24 BMX
Quoted: 365 Post(s)
Liked 87 Times in 58 Posts
Some photos of the Araya and Realize 5 spokes form a race I did last weekend. By the way, the amateur level is really rising in Japan. Years ago the top kilo time you'd expect at one of these was 1:07 or so. Last year at the race there was a 1:05 and this year the winner did 1:03, pretty impressive.
Baby Puke is offline
Old 05-05-18, 11:36 PM
  #5004
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
Liked 23 Times in 20 Posts
The Araya is interesting. Very round and blunt looking. The Realize wheel could almost pass for an iO.
taras0000 is offline
Old 05-05-18, 11:46 PM
  #5005
Quoted: 365 Post(s)
Apparently the Realize and a Campy Ghibli rear were the set for the last Olympics for the Japanese team. Want.
Old 05-06-18, 05:53 AM
  #5006
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
I lust after the Araya disc. I think it’s more expensive than a Comete.
Where can I find info on the Realize 5-spoke? Searching is turning up a lot of Alibaba links.
carleton is offline
Old 05-06-18, 06:26 AM
  #5007
Quoted: 365 Post(s)
Hey Carleton, actually I don't know where to find info. I think it's made by a shop that normally does carbon bits for race cars, but I don't know how to find them, I've searched too. I know the wheel is relatively reasonably priced ($2-3000 neighborhood), and as I understand it comes in three different models, with the priciest being the Olympic wheel. That's all I got. But I really want one for my birthday. Hint, hint...
Old 05-07-18, 05:55 AM
  #5008
Not the Slowest's Avatar
Bikes: 2002 Seven Axiom
Quoted: 11 Post(s)
Bottom Bracket, Which One?
Hello all,
Picked up a nice lil 2006 Raleigh Rush Hour to use for my commuting. The bike comes with a Tuvativ Touro crank and 130BCD chain ring and uses a Tuvativ 68 x 108 power spline
BB. I want to swap out to a 144 BCD chainring just to keep my stuff in the same family and most likely a square taper crank.
So the question is if I do this do I have to use a 68x108 BB or can I go 68x109 or 68x 110 wide?
Can't find the 108's so easily and there are many options on the 110 around.
Comments & insight?
Thanks Robert
Not the Slowest is offline
Old 05-07-18, 07:14 AM
  #5009
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 344 Post(s)
Liked 58 Times in 35 Posts
It depends on the crank, since a crank and a BB go together.
But, figure that the difference between a hard-to-find 108mm spindle and an easy-to-find 110mm spindle is 1mm on each side. And that means that your commuter's chainline is "off" by 1mm. Which is perfectly fine and well within what your chain can tolerate.
queerpunk is offline
Old 05-07-18, 10:19 AM
  #5010
Quoted: 11 Post(s)
Thanks, Unsure which crank as I"ll be locking it up on the street,
Old 05-07-18, 11:06 AM
  #5011
Elitist
carleton's Avatar
It might be better to leave the 130 BCD crankset and chainring in that bike. Once you settle on a gear ratio for your terrain, it’s unlikely that you’ll change it.
Also, having all 144 BCD and using the chainrings on both bikes might make a situation where the chainring you need for a training or race day is on your other bike as opposed to being in your track sack. Now you gotta stop and take it off before leaving then put it back on when you return.
Further, if you are locking the bike up outside of stores, pubs, restaurants, etc... the nicer the components, the more you worry and your replacement costs go up.
But, if you want it nice, no problem with that either. I rode a race-spec Pista Concept complete with Mavic Ellipse, Sugino 75 cranks, Zen chainring, Thomson stem and seatpost, B123 bars, Arione saddle, etc...through Baltimore and DC back in the day without issues...but I was constantly paranoid about it being knicked or scavanged.
carleton is offline
Old 05-18-18, 01:13 PM
  #5012
Quoted: 48 Post(s)
do Dura Ace chain ring nuts/bolts (the knurled ones) work with sram omnium cranks? Sorry if this is a stupid question, but using 2 tools to remove chain rings is a PIA. If not, what glue do you guys use to secure the bolts into the crank?
JuiceWillis is offline
Old 05-18-18, 03:06 PM
  #5013
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
Tubular glue works well. So do silicone caulks/glue. You want something that cures with some give, not something hard like Crazy Glue (cyanoacrylate glues), because there will be some gap and the glue is too brittle for that. Epoxy works too, but you will never get them out if you strip one.
Old 05-19-18, 07:20 AM
  #5014
Morelock's Avatar
Quoted: 282 Post(s)
Liked 50 Times in 37 Posts
yep, they'll work. Sugino also makes some that are a little cheaper than the DA ones. Otherwise, as Taras suggested.
Morelock is offline
Old 05-19-18, 08:05 AM
  #5015
Quoted: 48 Post(s)
Thanks guys!
Old 05-22-18, 09:21 PM
  #5016
Quoted: 48 Post(s)
To anyone that uses a wahoo cadence sensor and wahoo Elemnt bike computer, has anyone had weird readings when doing higher cadences? I was doing cadence drills on the rollers, and i was hitting 120-145 rpms on the cadence intervals when i was able to glance at the computer. However, when I uploaded the workout to trainingpeaks it reads that my peak cadence was 110rpms for 5 seconds, but my speed sensor was accurate and was stating peaks of 35-45mph so I know its the cadence sensor not being accurate. Anyone else have this problem? Not a big deal but slightly annoying when i was analyzing the workout afterwards.
Old 05-22-18, 11:39 PM
  #5017
Elitist
carleton's Avatar
Originally Posted by spartanKid
IME I have found that magnet-less cadence sensors really aren't made to cope with high cadences. I can hit 240 with a magnet cadence sensor but my magnet-free one drops out or halves the cadence when it gets above 160 or so.
Bingo.
Whatever is inside of it (e.g. a ball bearing) simply gets slung to the side with the centripetal force of the really high cadences.
Get an ANT+ magnet type sensor. Bontrager sells them.
On a related note, I hooked up my Wahoo Ticker (HR monitor) to the iPhone app today and place it in my two hands to test and it worked...then I set the HR strap on the table as I cleaned my bike and apparently it registered a ghost's HR between 134 and 146 BPM! It did this for several minutes! Not sure if I can trust this thing, hahaha
carleton is offline
Old 05-23-18, 04:52 PM
  #5018
brawlo's Avatar
Quoted: 288 Post(s)
Liked 76 Times in 57 Posts
I got the Wahoo sensor when I bought my Kickr. It's rubbish for sprint style stuff where cadences change rapidly. I was using my Garmin speed/cadence sensor with Zwift and running the Wahoo Fitness app alongside it which was reading the Wahoo sensor. For steady state stuff after a few seconds it registers right in line with the Garmin, but for rapid accelerations or speed changes it's just not useable. Reportedly the gyro speed sensors are in the same ball park. "Old fashioned" magnets and sensors are still the best way to go for sprint style track/trainer work. I am now trying to find a speed/cadence magnet sensor with BT & ANT+ connectivity for my daughter and her road and track bikes. I am having to look overseas for them now!
brawlo is offline
Old 05-23-18, 05:47 PM
  #5019
Quoted: 365 Post(s)
Old school basic cycle computer + Carleton's track calculator app FTW.
Old 05-23-18, 09:42 PM
  #5020
Quoted: 48 Post(s)
tell me more...since all my workouts are now cadence based this lack of accuracy on my sensor really sucks.
Old 05-24-18, 03:14 AM
  #5021
Quoted: 365 Post(s)
I just have a Cateye Micro Wireless, and the only things I track are speed and mostly max speed. Using Carleton's app I plug in my gearing and get maximum speed/cadence for my efforts. That and my time for each effort are really all I need. With this I can see improvements over efforts in terms of speed/cadence and plan gear changes accordingly. Of course I'm a sprinter, so things are dumb with me and my needs are few in regards to data. Plus I hate fiddling with gadgets.
Old 05-24-18, 10:41 PM
  #5022
Quoted: 48 Post(s)
This is a question based on pure laziness and being cheap...Does anyone NOT wrap their sprint bars? I wear full fingered baseball gloves that have plenty of grip. I am also the most anal bar wrapper of all time and i just don’t want that stress in my life.
Old 05-25-18, 03:43 AM
  #5023
Elitist
carleton's Avatar
Sometimes I do not as in the photo below. I use either gloves or baseball resin. I've also used weightlifting chalk in the past.
One note, these bars are plugged by design. Most are not. You are not required to use grip tape, but you are required to have your bars plugged. This is because if you wreck, unplugged bars will take a deep "core sample" of flesh and muscle from you or someone else.
I haven't heard of this happening on the track, but I did hear a gruesome tale from my BMX freestyle days.
I can't get the photo to load from my album (grrrrrr...). Follow this link: Power meters for track
carleton is offline
Old 05-26-18, 05:53 AM
  #5024
Quoted: 194 Post(s)
Liked 2 Times in 1 Post
Pro tip: tennis/badminton grip tape is considerably cheaper than bike bar tape...and does EXACTLY the same job.
Before cycling I was a national-level badminton player. We buy this stuff by the reel. A 30pack for $39...will last you YEARS.
https://www.midwestsports.com/yonex-...xoCNb8QAvD_BwE
southernfox is offline
Old 05-26-18, 09:36 AM
  #5025
Bikes: Fuji Elite, 3Rensho track, Trek Madone 6.9, Specialized MTB, GT MTB, Cannondale Cad3 fixie
Quoted: 72 Post(s)
I use the BMX style slip on grips. Easy to apply, fills the hole in the bar ends, and works even if I forget my gloves (although that has never happened, Murphy's law rules, and so I figured making it fail safe is a plus).
rensho3 is offline
