Help me find lightweight fixie that can go mostly everywhere
Old 09-28-19, 09:53 AM
Philasteve's Avatar
Bikes: Surly CreamRoller. 98 Giant Rincon. SE UVT
Quoted: 5 Post(s)
Liked 12 Times in 9 Posts
Originally Posted by HourPlus
Thank you soooi much for this MUCH needed dose of reality. I love it when I see a $250 SS road bike w/23mm's (e.g., TheHour) beat a $2k mtb over the kind of terrain you mention. You simply can't buy the strength, skill and guts it takes to race a 48:16 against mtbs.
One of the most important aspects of a new bike that can completely ruin even the nicest bike. Is making sure that whatever you get fits your properly, use a fit calculator, take all of your measurements and see what you get. So you know what size frame you'll need. But keep in mind some run smaller or bigger and some measure their frames differently than others so you'll have to consider that too.
Philasteve is offline
Old 09-28-19, 11:01 AM
Your right. Being a complete novice I can't jump a 6in curb on my Windsor Hour. I think my seat is set too high. It feels like I'm leaning down over the bars. But my short legs gets much more leverage sitting high.
HourPlus is offline
Old 09-28-19, 02:04 PM
Loose Chain's Avatar
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 71 Times in 56 Posts
Your saddle height is a fixed number only altered a little bit for different shoes or pedal types and is determined by your cycling inseam. It has nothing to do with not being able to jump a 6 inch curb. If the saddle is too high, learn how to set the correct height, or too low, the same thing. Jumping a curb is a good way to ruin rims, bicycles, chainwheels and other expensive parts not to mention crashing.
Loose Chain is offline
Old 09-28-19, 02:21 PM
seau grateau's Avatar
Quoted: 1332 Post(s)
Liked 398 Times in 194 Posts
Don't feed the troll.
seau grateau is offline
Likes For seau grateau:
Old 09-29-19, 04:08 PM
Gresp15C's Avatar
Quoted: 1062 Post(s)
Liked 665 Times in 421 Posts
Bikes are not as delicate as people tend to think. Practically any bike is capable of being taken off road under a couple of general conditions: 1) We're not talking about trails that are deliberately designed to be challenging for MTB'ers. 2) We're patient about reaching our destination, willing to carry the bike over major obstacles, etc.
I have a couple of bikes that would fit the descriptions given here, except they are thrown together from old parts. One has 28mm, the other 32mm tires. In both cases, I've taken them on all sorts of terrain, including the longer bike trails in WI that are mostly crushed limestone and occasional gravel. Like @rustystrings61 says, good tires are the skeleton key. I'd add, a comfortable saddle and good fit, which mean getting close with frame choice and then fine tuning it yourself.
I've never seen a Kilo WT in person, but on paper it looks great, very much like the bikes I've built for myself. Gearing, and the overall sanity of riding fixed, well... you'll figure those things out. Budget for trying a couple different sizes of cogs.
Now, riding extensively on rough terrain will probably get old on any non-suspension bike, so I'm assuming that's not part of the plan. If things change, then it's time for a second bike.
Gresp15C is offline
Likes For Gresp15C:
Old 09-30-19, 02:24 PM
Super-duper Genius
Broctoon's Avatar
Quoted: 768 Post(s)
Liked 984 Times in 508 Posts
@eazyace, it sounds like you don't like the aesthetics of skinny (steel) frame tubes.
Aventon, Brakebrake17, and Dolan all make frames with oversize and/or funky shaped tubes, in other words, modern looking bikes. All have reasonably good reputation for quality, with Aventon perhaps being the most questionable. For your first adult bike, you probably won't go wrong with any of these, or the Throne brand previously mentioned.
Broctoon is offline
Old 10-07-19, 10:19 PM
Quoted: 850 Post(s)
Liked 344 Times in 247 Posts
I agree that $1500 is a lot to spend on a fixie/singlespeed that’s just going to be ridden around on roads and trails. It’s probably best to try and find a bike that can clear at least 28mm tires (the max for standard rim brakes). That’s a rarity with track bikes, since many of them use the narrowest tires they can find. Many won’t even list tire clearance because it’s largely irrelevant. Many SS/fixies will also have very aggressive geometry, which is quite fashionable or even useful on the track, but can get quite old for someone who is just riding around at a low intensity.
However, if you still want a light, fast fixed gear bike, the ribble eliminator seems like a good option that isn’t very well known (I have no experience with it). Stock, at $700ish, it weighs in at 7.05kg with no brakes or pedals. Add both and you’re looking at around 7.5 kilos. If you’re willing to splash out, you can build a nice alloy wheelset with Miche EDIT: Mack* hubs and chop 800g or so off. That will bring you to 6.3kg or so, which is extremely light.
The state bicycle co undefeated is a more well-known option that might weigh a touch more.
smashndash is offline
Old 10-11-19, 09:42 AM
Philasteve's Avatar
Quoted: 5 Post(s)
However, if you still want a light, fast fixed gear bike, the ribble eliminator seems like a good option that isn’t very well known (I have no experience with it). Stock, at $700ish, it weighs in at 7.05kg with no brakes or pedals. Add both and you’re looking at around 7.5 kilos. If you’re willing to splash out, you can build a nice alloy wheelset with Miche hubs and chop 800g or so off. That will bring you to 6.3kg or so, which is extremely light.
That's pretty light for a bike that costs 700 bucks.
Old 10-11-19, 09:47 AM
Quoted: 850 Post(s)
I’m just quoting their website. No idea how true it is.
Old 11-03-19, 06:43 PM
12boy's Avatar
Bikes: brompton sl, surly steamroller, fuji track, gary fisher bmx minivelo etc
Quoted: 156 Post(s)
Liked 16 Times in 12 Posts
My steamroller and I have gone thousands of miles with 72 gear inches and 35 mm tires which are slick, cyclocross or studded winter snows. Simple, easy to work on, a joy to ride, easily modified to meet changing needs etc. It's that reddish brown color that Surly calls beef gravy but others "bloody stool". I used to ride fixed but now single speed as it is hilly here and I don't love 140 rpm descents. I visited the Smithsonian space wing where I found a Wright Bros bike amazingly similar to the steamroller.
12boy is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
