Disadvantages of small wheels over std bikes
Numpty
Bikes: Pacific Reach
Bikes: Dahon Mu Sport & Mu Ex
- Just my opinion, but I also felt it much easier to get a more powerful pedal-stroke on the Swift.
BTW, the last Smithfield Nocturne has been won by a Dahon MU SL rider. Second Airnimal. Then Swift. These bikes are all three fast. The Mu SL is a tiny bit faster than my MTB with slicks (don't have a full size racing bike to compare). But I feel quite a difference in speed between my Mu SL and my Mu XL Sport. I attribute it mostly to the gear hub and the wheelset, plus the stiffer handlepost on the Mu Sl (non telescoping). Also the pedals are important. Lastly the Pantour hub allows for better front traction and thus slightly faster cornering.
Bikes: Dahon Jetstream XP '04, a Dahon Cadenza '07
I don't think these are the reasons. In fact the Marathon Racers are among fastest tires - you can pump them pretty hard. Also more gears have almost no impact, see single speed racers. You can ride the Mu P8 in quite streamlined position. Its a bit Graham O'Brien like ;-)
yes, the single piece main tube design of the swift might be stiffer. And if you have a very strong stroke, the flex of the Mu frame can absorb some energy. But this won't be much.
Drops small screws
How'd you get 20 speeds on a Swift? I've got 24 with a Sram Dual Drive, but I can't figure out a 20-speed.
Numpty
As Sheldon Brown pointed out, the issue of frame flex 'absorbing' energy is a red herring: the energy does not get absorbed, it is fed back into the drive system as the flexed bit straightens out again (mechanical memory and all that, otherwise the frame part concerned would become permanently bent).
Numpty
10 speed block with two chain rings? Or Schlumpf drive? My Pacific Reach has gone from stock 8 speed to 16 speed by adding a second chain ring etc.
小型自転車マニアック \(^o^)y
Bikes: Mu P8, customized Xootr Swift
I was really wanting a dual drive for the simplicity, but the double ringed front was the easier, lighter route. Gear inch range isn't "huge", but the gearing/cadence for riding the in the sweet-spot is great!
Tuned the front derailer once, and no chain jump issues since.
Drops small screws
Aha--I forgot they can have derailleurs in the front now.
小型自転車マニアック \(^o^)y
Bikes: HP Grasshopper, Brompton, Claud Butler Tourer
Its interesting that you mention a Moulton, most of these rides are with a friend who has just recently purchased a moulton, he is certainly quicker uphill and also has the edge downhill, I think the slightly larger wheels and better suspension my help but on the flat we are evenly matched, Fitness is a contributory factor also keep swapping from a recumbent may not help.
Bruce beat me to it. I was going to ask what tires you have on the Birdy. I swapped the stock tires for Schwalbe Stelvios, and there is a very noticeable speed difference. No problems doing long weekend rides with friends on full size bikes. I have a Capreo Birdy though, no internal gears. I don't know if it makes a huge difference - I use to ride my Sturmey-Archer 8-speed equipped Xootr Swift on long (60-70 mile) road bike rides and have no problems hanging with the pack either.
If your bike is geared properly to compensate for the small wheel circumference then you can hang with the big wheeled boys but accomplishing that seems difficult and often problematic with most folders.
But wait, you have a Rolhoff! That thing has wicked gear ratio/range! You shouldn't have had a problem on those hills. Hmmm... Odd. How many teeth does your chainring have?
Pedaling fool
Bikes: 07 Schwinn Voyageur GSD, Next Avalon, 2007 Dahon Yeah
Still waiting on the answer from the OP on whether he has problems going uphill or downhill...
Bikes: Scott road bike, MTB, and Space Genie Folder + several others in bits
Unless conditions are exactly the same on exactly the same route, surely this 'faster' business is all a bit of an illusion?
Yesterday I cycled to work 30 seconds faster than today. Same bike though... 'Feels faster' is probably as accurate as it gets.
crazy bike girl
Bikes: '07 Orbea Onix, '07 Birdy Yellow, '06 Cannondale Bad Boy (stolen)
IMO the biggest disadvantage of small wheels is clearance when riding off-road.
Countries I've ridden in: US, Canada, Ireland, UK, Germany, Netherlands, France, China, Singapore, Malaysia
States I've ridden in: Illinois, Connecticut, Massachusetts, Pennsylvania, California, Nevada, Missouri, Colorado
Bikes: Giant Escape III
Faster?
"Faster" can be objectively measured but you're right that if you are comparing average speeds, you have to run the same route under the same conditions, only varying one factor at a time. The varying factor might be the bike, the rider, the time of day ... whatever you want to compare. You probably have to run each test several times to account for variables you couldn't control. Like, why were you 30 seconds faster? Maybe on the slower run, you had to slow for a pedestrian who wasn't there the second time. Or maybe you were tired. Or maybe 30 seconds is such a short time that it is just random. That's why statisticians have methodologies for figuring out if a difference of 30 seconds is significant.
Just a thought.
Another word for "memory" is hysteresis and the reason it's associated with losses is because unless your power source is in perfect sync with the memory delay your own force comes back to fight you, which increases the losses inside the source as it has to work harder to achieve the same output.
Think about it. It's like rowing a boat with a friend, except he's pushing when you're pulling. It's not a red herring, Sheldon Brown just prematurely declared aok after he missed the "leak".
People talk about frame flex absorbing energy on folders, but I wonder, does the handlebar or seatube really intercept any useful forces? You don't pedal with your butt or very efficiently with your arms, so why would anything need to be stiff except the bottom bracket? And wouldn't the bottom bracket be stiffer on a folder due to the lower top tube?
Furthermore my Dahon has the central hinge. Don't know how well it transmits torsional forces, but a slight loss might be attributed to it (but I would not expect this to be more than 1%).
When climbing or accelerating I go out-of-saddle. The handlepost/bar flex becomes an issue.
Moreover, I would not expect loses due to flexure of the central hinge to be more than 0.01% because I just can't see that part bearing/transmitting more than 1% of the useful forces. There's a video online somewhere of man riding a bicycle whose front and back halves are connected by springs instead of tubes and, except for the difficultly of controlling a bike with a changing wheelbase, he seems to move along just fine.
Of course, it also depends on technique. For example, if you ride pushing down on both pedals simultaneously you'll be lacking efficiency on any bike without rotor cranks.
I am testing my bike for a single speed conversion. And then you get into situations where arms contribute significantly. Periodically going out-of-saddle - that's what single speed efficiency is about. Stiff handlepost is a requirement.
Numpty
