Specialized Sequoia ideas
Bikes: 2007 Bianchi Castro Valley, 1985 Specialized Sequoia
I actually don't have a freewheel in hand, I'm deciding on what kind to get, new chain too obviously. 6 or 7 speeds, gearing range, quality? It seems a 13-28 or 14-28 would give me plenty of range. Any suggestions as to what the barcons would work smoothly with?
Thanks! It was a CL ad that just said "Road bike $100" so you had to look at the third or fourth picture to see what make/model it was. Measured mine, turns out it's a 60cm.
Gouge Away
Okay! "Finished" with just minor tweaks to do. Unfortunately we're in the middle of a snowy, icy winter so I won't be riding this beauty until we get a big thaw. I'd flipped a couple of c&v bikes before, but something about this one smelled like a keeper. There's something so simple and refined about the vintage designs. I kept it with 5 speeds, but installed a new freewheel to get 1 more low gear (the old freewheel looked passable, actually). Popped on new pedals (shimano spd). Also, new chain and brake/gear cables, new bars, and new-to-me salvaged barcons. Rebuild added up to $175 give or take. Melt, snow, melt!
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,704 Times
It looks fantastic- those early Specialized bikes sure are special!
Your downtube cable stops are on backwards if it matters to you.
Congratulations! I can't wait for the ride report!
Commence to jigglin’ huh?!?!
Thanks, and ride report, hopefully by March.
Spin Forest! Spin!
Bikes: I used to have many. And I Will again.
Quoted: 7 Post(s)
Liked 11 Times
Hahaha!
That's one LBS to avoid!
Great score for $100. May you have many happy miles with it.
Likes For WNG:
Quoted: 117 Post(s)
Liked 72 Times
Nice score! For brakes, keep the Gran Compe or Superbe long calipers; they'll clear fenders better than dual pivot brakes. Upgrade the cables and pads and, if you decide to use brake/shift levers you'll find that any modern controls are also a superior brake lever. If for instance you decide on Campy parts, it's amazing how well Nitto Noodle bars and Campy Ergo levers fit together. Springing the 126-128mm (manufacturing tolerances) dropouts apart to 130 will hurt absolutely nothing. One thing to not "upgrade" are the skewers. If I remember right, those frames had horizontal dropouts with chromed faces and a modern Salsa-style skewer won't get enough of a bite on them. Inexpensive, all-steel generic skewers with closed cams (like old Campy, Atom, etc.) skewers will work best. Shouldn't cost more than $20/pair. Happy riding--those are a superbly well designed and built frame. You can't match them anymore without spending nearly 2K for a custom build.
Quoted: 1627 Post(s)
Liked 630 Times
One word on that balky rear brake, in case no one has said it already: apart from disassembling, cleaning and regreasing, please try replacing the pads if you haven't already. That brake caliper is not junk and should work just fine if everything is set right and the cable run is clean.
Likes For Lascauxcaveman:
Quoted: 117 Post(s)
Liked 72 Times
I think the Specialized bikes were about the best of these, but in the 80's the Japanese yen was really cheap currency--at @300 to the dollar, it was about a third of the price that it is now! There are a lot of sleeper bikes out there, super quality bikes that couldn't be duplicated today for prices that people might pay for steel production bikes--Schwinn Voyageur, Fuji America and S12 series, Bridgestone 700 and Mile 112's just a few examples.
Thanks for all that advice - for a second I considered "upgrading" the skewers. I knew they were nice frames, but wow I feel lucky when you put it like that. How the bike is upgraded for now is how it'll stay for a bit. Once I wear out the wheels I may try some of the upgrades you mentioned, though!
Liked 1,704 Times
Anything you do to "upgrade" that bike will never out-class that frame.
Finally got a ride in, 25 miles, mostly flat. The ride is so dreamy, quick but predictable. Its like driving a top of the line BMW from the 1970s with hardly any miles. Liking the half step plus granny gearing, too. The Suntour barcons fit the bike perfectly, work flawlessly, and suit me well. I'll post a real ride report after a few more rides with some pics.
Liked 1,704 Times
Now, I mostly ride on the middle ring and live with the jumps, use the big ring as the "overdrive" or 5th gear.
I've been looking at the weather- I REALLY want to get out- but I don't know how the cold will be on my hand (old crush injury).
I'm so glad you're enjoying it- it's a really "Class A" bike, and your build is really nice.
Congratulations!
I haven't done it in a while, and I don't like doing it because I don't like counting. Who am I kidding... I can't count... Anyway- the half step gearing works best being able to keep your hands on the shifters, and being able to upshift/downshift simultaneously.
Congratulations!
Congratulations!
Thanks! I too found myself mostly in the middle ring and happy about that. I'm glad the drivetrain has remained mostly original so I experience how the bike was designed to be ridden. Its easy to see the class of this bike after riding it. Only con: It looks like I won't put bigger tires than 700x28 in the future, I need to deflate the tires to slide out anything bigger than 28s from the dropouts. I might not add fenders because of that.
You'll need some tektro r559 brakes.
Liked 1,704 Times
gobs and gobs of love...
gorilla girl, funny you mention 650b conversion. This is my plan once I wear out the wheels! Looking forward to tryin it, though I'll have to do a little research to make sure the bottom bracket doesn't wind up too low. 'Til then I'm going fender-less on the Sequoia!
Liked 1,704 Times
Quoted: 5 Post(s)
My 198x sequoia
Hi guys, joining this thread because in the past year I came across an early specialized sequoia. Based on what I’ve read around it looks like early 1980s.. wish it was a 3rensho, but I it had the common welding on the seat stay.
Id also like some ideas and see photos of what others are doing to their bikes. I’ve done a few things which I’d love to share photos of but I gotta fill my 10 post quota!
Ride Aloha!
FlyingSquirrel
Ride Aloha!
FlyingSquirrel
