Help me identify this Pinarello
Bikes: 1973 Raleigh Super Course - 1981 Velo Sport Criterium - c.1988 Colnago Master Piu - 1991 Merlin Road - 1991 Eddy Merckx Corsa Extra - 1995 Pinarello Cromovan - c.1999 Lemond Maillot Jaune Team Saturn - 2002 Colnago C-40 - Also modern stuff
Quoted: 51 Post(s)
Liked 38 Times
Oups! I think we forgot this along our search.
Another funny thing is that all images I see from the 1984 Montello with Campy 50th anniversary on the Net DOES NOT have the riveted head bagdge. It is ovale and looks like a decal.
OMG we are never done with Italian bikes
Quoted: 1079 Post(s)
Liked 1,900 Times
I'll try. We first saw the Montello in the 1985 catalogue - although there are some 1984 examples. It was their top tier model which used the relatively new Columbus SLX tubing with helicoidal reinforcing to the tubes adjacent to the bottom bracket shell.
To show off this 'new' tubing and highlight the workmanship of Pinarello, the chainstay bridge was excluded in favour of a gusset reinforced bottom bracket shell.
It was even mentioned in the '85 catalogue:
(Although plenty of other frame builders were doing something similar at the time, so I'm not sure how 'innovative' it was.)
They even took a photo of it (with cable guides, despite the description):
There's SL, SLX and TSX versions of the Montello, but as far as I'm aware they all had the reinforced BB shell sans bridge. Fast forward to the later years of the 80's and early 90's and several models lost their chainstay bridges - Gavia, Asolo, Treviso...
Here's something else I've come up with regarding Montellos: they all have a small raised GPT logo between the seatstay caps and the seat post clamp. I've only ever seen it on Montellos:
So there you go. How did I do?
Likes For P!N20:
Veteran, Pacifist
Quoted: 3901 Post(s)
Liked 4,844 Times
@Pin20 - you did great.
This pic is of an 84 or 85 SL framed Pinarello - has chainstay bridge, no internal cables route.
Is this the seat stay cap treatment you have only seen on Montello??? Full chrome on chainstays and seatstay.
Showing seat stay dent and seat post cluster.
Señor Member
Quoted: 284 Post(s)
Liked 299 Times
In the 1982 catalog, both the Tre Cime (Columbus SL) and the Prestige S (Columbus KL!!) have internal routing so it was certainly available. But do note that both bikes shown have the rear (exit) port very close to the seat while your bike's is forward.
Earlier it was noted that your frame was likely repainted, so it's possible that the internal routing was added then, using non-factory spacing on the ports.
Señor Member
Quoted: 284 Post(s)
Liked 299 Times
Can you take pics of the ports so we can compare to factory? I'd be curious if the reinforcement has the same shape - it looks the same from what I can see in your pics so far.
Quoted: 51 Post(s)
Liked 38 Times
Well, if a cable guide was damaged or rusted, some brazing work would have been needed anyway. Many painters offer brazing work as an option between strip and paint.
Señor Member
Quoted: 284 Post(s)
Liked 299 Times
OP - what is the branding on the dropouts? I think Pinarello switched to their own branding around 1987, so that could help with dating.
Yep, branded dropouts front and back, and here are closeups of the cable guides
Señor Member
Quoted: 284 Post(s)
Liked 299 Times
Those do look factory. Are they chromed as well? It looks like plain steel where the paint is missing but hard to see. Lack of chrome would point to a retrofit.
Here are some on a Montello with lots of paint loss showing both primer, and the chrome under that:
I found a photo of a restored Maxim with the same cable port spacing, but mine is definitely not a Maxim...
Quoted: 51 Post(s)
Liked 38 Times
Just to know, how sure are you about Pinarello branded dropouts being 1987 and after? I just got a Pinarello (very likely Treviso but hey, we never know ) with dropouts exactly like OP's bike. The seller, the original buyer, bought it 1985 or 1986. Haven't see the invoice but it is equipped with first gen Campy C Record.
Liked 1,900 Times
It's more than likely they were playing around with Pinarello stamped dropouts before the catalogue came out.
Bikes: Peugeot, Legnano, Fuji, Zunow, De Rosa, Miyata, Bianchi, Pinarello, Specialized, Bridgestone, Cinelli, Merckx
Quoted: 430 Post(s)
Liked 476 Times
This looks a lot like an early 90's Pinarello Cadore I used to have (and regret selling).
Sort of hard to tell from this pic, but the internal brake cable routing and stay bridge were both present. Same down tube sticker and lugs look the same too.
Think it was a 1993 or so.
Columbus Cromor, 27.2 seatpost.
Pretty much, like I alluded to in post #2 .
Now this is interesting... ! The odd thing about the Cadore is the cable entrance/exit tubes were sometimes rotated around the top tube, but the exit distance from the seat tube looks very similar!
edit: closer inspection of the Cadore revealed a plastic cable guide under the BB and an entirely different chainstay bridge.
Liked 1,900 Times
Indeed But I have never seen a Treviso with internal cable routing. It just seems odd that it would be the only one. Otherwise, everything else about the frame matches the Treviso exactly. I have heard that Pinarello would occasionally build frames that would not show (or show differently) in their catalogs.
And here's another one: https://bicyclebuysell.com/user/item...steel-frameset
You're right - the catalogues should be used as a guide only. For instance the Maxim and Gran Turismo models didn't even get a page in the (known) catalogues, yet we know they exist! Whenever Pinarellos come up for ID, there's always something that isn't consistent with the catalogue specs - sometimes it's too easy to get hung up on the details (guilty!)
Who knows, perhaps a wholesaler ordered a bunch of Treviso frames with internal routing? Maybe a previous owner had the cable guides removed in favour of the internal routing? It's all speculation - it's a pity Pinarello are only interested in the here and now so we could find out a bit more about these things (like, what the hell do those serial numbers mean?)
After all that, do you have the head badge?
No, I don't. It was hard enough just finding a restorable frame like this and someone in the past decided they wanted to keep the head badge for themselves. I really doubt I will be able to find another one, but I can have a reproduction made, so I have choices. Rest assured I won't be replacing it with a sticker !
Liked 1,900 Times
I was looking* for one for a while, not that my frame has any holes to accommodate one, but I thought it would have been cool to have one. A couple came up, mostly in average/poor condition with mint price tags. There was only one that came up that was in good condition for a reasonable price - it got snapped up before I even got to the sale page! Settled for the decal instead.
I wonder if you could find a 'cheap' Lungavita, remove the head badge and sell the bike? Although their head badge is an adhesive job - no holes for rivets:
* When I say looking, I mean a saved search on ebay.
Last week I took the frame and fork down to D&D Cycles in San Lorenzo to be stripped. Once that is done, the mystery about the internal cable routing will be solved. The owner noticed a very small divot on the top tube where it appears a cable lug was removed, and he also noted that the brazing job for the internal cable routing was very well done. He also agrees that this is a early-mid 80's Treviso.
Regardless, this will be a late summer rebuild project for my wife.
