Simple carbon fork extension for scooter
Quoted: 49 Post(s)
Liked 13 Times
I think you would have been better off just buying aluminum close to the final shape needed and drilled and bolted them to the existing forks. If they worked you could then take them apart and refine the shape a bit.
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
The O.L.D on the wheel would have to be different since the aluminum bolted to the outside would widen the gap, but I could just put some washers on the axle to compensate.
Quoted: 2345 Post(s)
Liked 2,859 Times
While not a frame builder yet, I have built a lot of things over the years (included hacked roller set up so a luge sled could be used for training on roads).
My concern, especially i used for skate style vs classic nordic style, that there will be a lot of lateral forces in play, and with the amount on length added to fit the larger wheels that unless using really thick plate, there will be way to much flex, especially with 16 in wheels
maybe flat, with stiffener welded on outside, but that sound's like it is going beyond OP's current shop toolset
Doesn't hurt to try,
Disco Infiltrator
Quoted: 3130 Post(s)
Liked 2,111 Times
As you design, don’t conflate stiffness with strength and don’t forget about either. You need more of both just because it’s a longer arm from the platform to the wheel. If you replace steel with carbon the carbon has to be thicker… it’s “stronger” and “stiffer” per weight but much less dense.
Genesis 49:16-17
Genesis 49:16-17
I like bike
Quoted: 267 Post(s)
Liked 283 Times
Or so is my impression of this stuff.. I'm no expert. I am using this page as a reference.
Re: how much stiffness is needed, I don't think it matters all that much as there are not many side-to-side forces on these skates. You are not twisting in NCS, it is not like downhill skiing. Having less stiffness will in fact be good I think, for the up-and-down forces for which some dampening would be good.
Quoted: 327 Post(s)
Liked 265 Times
It's a bit like if you do the math you will find that in theory you could stand up vertically on a piece of TIG wire. In theory the strength is there. But a tiny perturbation and you won't be loading it straight down any more so of course it will bend.
Quoted: 716 Post(s)
Liked 804 Times
This seems to have really gone into the weeds with all the theoretical discussion of strength and stiffness. Sometimes you just have to build it and see if it works.
I like bike
Quoted: 267 Post(s)
Liked 283 Times
Indeed. I decided to order some full side panels in aluminum and use those to prototype. Its $12 a panel including materials, cutting, shipping, and tax .. it seems worth the cost to get a realistic prototype. Here is my simple design if you are curious. I had to learn a few more features of my CAD program to get this done.
