Are all square taper fixed cups left hand threads?
Quoted: 4528 Post(s)
Liked 6,428 Times
One of the worst things as a tech is to have comebacks of any kind.
Many shops now days have zero tolerance and plenty of service managers never did, it was guaranteed to get you on their bad side where you could easily stay if they were really a hard azz whether it was your fault or not.
This was also the best reasoning for preventative maintenance that is what proper BB service is.
There is always time to do it right but never time to do it again.
Furthermore I'm not concerned with anyone else's opinion on this be it a manufacturer or St. Sheldon.
I know from vast experience what it takes to get down the road or track and back home.
Likes For merziac:
Quoted: 7359 Post(s)
Liked 2,502 Times
A few tips for removing BB 1 loosen the fixed cup first. 2 Clamp the removal tool to the cup. 3 set the bike on the ground with air in the tires, 4 stand in front of bike holding handelbars, press down on tool with foot, use cheater bar if needed. 5 loosen the adjestable cup. .6 put bike in stand and dissamble.
Quoted: 570 Post(s)
Liked 482 Times
I would strongly encourage you to get a proper fixed cup tool and use some method to hold it firmly in place, all thread, clamps, etc.
A fixed cup wrench encircles the cup for far better purchase when every last bit counts.
I have a Sugino that I have had for over 50 years that is the only one I really use, Campy is next with Park last, I have them all, the Sugino has never failed me.
Then have a good cheater set up, I have a 4 foot thinwall pipe that is flatened at one end and slips over the wrench when needed.
The big crescent wrench can work ok but most have tapered jaws that can be hard to hold flat, square on the cup and often try to "cam" out/off and round off the flats, once this happens, you lose the best footing and success is much less likely without extreme measures.
It can be imperative to get it very right from the jump.
Liked 6,428 Times
They have to come from efbay as do the Campy's and they often are not cheap but worth the extra, again IMO.
Plenty to be had but ones in could good shape may be a challenge, they are tough and don't have to be perfect but the better, the better.
https://www.ebay.com/sch/i.html?_fro...+tool&_sacat=0
You can look for Campy too but you need to check good pics closely.
Quoted: 2351 Post(s)
Liked 2,866 Times
Likes For squirtdad:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4690 Post(s)
Liked 5,838 Times
I'm surprised no one has mentioned the best method.
Chuck the adjustable BB and put in a sealed bearing unit.
Quoted: 570 Post(s)
Liked 482 Times
I had originally considered doing that. I would have to learn what to order and where to order it, how to make sure it's installed properly, etc. I didn't research it until I see if it's a necessary change or just an option.
Quoted: 570 Post(s)
Liked 482 Times
here is the link to the sheldon brown tool https://www.sheldonbrown.com/tooltips/bbcups.html
Likes For Reynolds:
Old fart
Quoted: 3602 Post(s)
Liked 3,430 Times
Old fart
Liked 3,430 Times
Liked 5,838 Times
Hey, that's what we're here for.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3911 Post(s)
Liked 6,525 Times
Likes For SurferRosa:
Quoted: 570 Post(s)
Liked 482 Times
I just meant that I was going to service the BB unless the races were so bad that I thought it would warrant a new sealed unit. I wouldn't know until I got it apart.
Likes For RH Clark:
Liked 2,866 Times
have to still get the fixed cup out
Liked 2,866 Times
also good idea to put some penetrating oil on and let it soak in (I like freeze off)
and you will also likely need a cheater bar
Liked 6,428 Times
Liked 6,428 Times
So once this is successful there is no reason not to keep it original as it was, clean, lube, adjust and properly torque so you're good to go.
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 178 Times
SteinTool has a very nice and effective fixed cup wrench clamp.
Touring Rocks
Working in a bike shop during the 80s we would leave the fix cup in for overhauling the BB.
If we had to take out a tough fixed cup out we would remove the wheels, turn the frame horizontal, clamp the cup in a vise with square jaws and use the leverage to turn the frame. Some cups have narrow flat portions so getting the bike perfectly flat in the vise was critical. This was a last resort and could scrape the paint on the BB frame edge if the cup flats were very narrow. Always worked though......
Quoted: 4519 Post(s)
Liked 1,657 Times
Risking damaging the frame and cup is pointless.
Liked 6,428 Times
I don't agree. The fixed cup is poorly designed for easy removal, and if it is a chromed steel cup in a steel frame, there is nothing happening between them that needs servicing. Everything necessary for bearing service can be accomplished with it intact, and that is the way bike shops do it.
This is why some are professionals or as good as, many things are not easy, if you're not competent or skilled enough, admit it and don't make up excuses for unacceptable practice.
We know you don't agree and I don't care if you disagree or if you and the bike shops shortcut the process on all those unsuspecting customers all those years.
Proper BB service includes the threads of the fixed cup and BB shell as well as proper torquing upon reassembly.
If you can't get the fixed cup out without damage then by all means kick the can down the road and leave it up to someone who doesn't know any better and is sure to screw it up for you.
There is no risk doing this if you know what you are doing, apparently that is not you.
I have NEVER, EVER damaged any tools, parts, frames, paint or flesh doing this my way.
Your argument is pointless, you go ahead and do you man, I'm sure it works just fine for you.
Liked 6,428 Times
There needs to be 2 separate containment's, one for the tool and one for the frame, especially when you have to really lean in.
The possible paint scrape is an unavoidable byproduct of the process and can always be touched up if necessary.
Many jaws don't align correctly over time, especially the worn top edge that is critical for this.
Liked 1,657 Times
And there it is, "easy removal".
I am a superlative mechanic, and can also remove and install fixed cups all day without damage. However, you and I aren't going to the OP's house to pull his cups for him. This is an advice forum largely for people that aren't necessarily great mechanics or DIYers, and the small engagement and high torque involved in fixed cup removal represents a risk that is largely unnecessary for the life of the BB. They are torqued down so tight that Italian cups won't move.
Do you remove headset cups crown races to do a headset service? I don't do that either because the cost/benefit isn't there.
You made your point; I made mine. Both are reasonable perspectives, but only one of us had to be insulting. The OP can decide to take any set of advice he wants on the merits, and hopefully not on who is ruder.
Liked 1,657 Times
