Do I Have the Right Rear Derailleur?
I didn't notice or have second thoughts when I had to replace my DA 9100 with an Ultegra R8000 after a minivan rear-ended me. It just fit and looked right. Different hanger? Now I need to dig up my R8000 to see if my version had it (replaced it with Sensah Empire Pro and set aside the bike for trainer duty).
Quoted: 564 Post(s)
Liked 422 Times
The OP was the one that f'ed up by installing it wrong.
Members here can't see the bike, all we can do is guess at best to bad photos.
If they don't like the suggestions that might fix their f-up, they can just bring their bike to a LBS, which is encouraged and not bad advice.
Do you know how many smart folks ask for advice on the internet on why their car won't start, when all they needed was to put GAS in it? It's not up to forum members to figure that out for them.
Quoted: 5886 Post(s)
Liked 2,728 Times
I don't speak for others, but I'll consider the source before taking it to heart.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 855 Post(s)
Liked 1,088 Times
I've learned to always read the setup instructions for any new groupset I encounter. Things have changed quite a bit since even 10 years ago when mounting F & R derailleurs was mostly the same procedure with only a couple little idiosyncrasies as compared to now with something like the OP's mounting issue. All mfrs publish instructions that can be easily found on the net if not included with the component. Even mounting the shifter cable on the wrong side of the clamp bolt is still a pretty common mistake so check out the instructions first.
Quoted: 4539 Post(s)
Liked 1,676 Times
Which is pretty damn typical.
Likes For Kontact:
Quoted: 3576 Post(s)
Liked 2,997 Times
Thing looks like it has at least one too many pivots and a superfluous lug, so yeah, I wouldn’t know where to start!
https://bike.shimano.com/en-EU/produ...-R8000-SS.html
Likes For Hondo6:
Liked 1,676 Times
The 11-30 is messing it up with a chain too long because that is expecting a 1x up there.
You'd be able to remove one link with a smaller 11-28T, thus taughting the chain when it's on the 11T.
There exists aftermarket bolt-on dropouts that let's you place a RD even lower.
Quoted: 387 Post(s)
Liked 873 Times
Likes For bboy314:
I've rebuilt this bike 3 or 4 times with new components - this last time i screwed up something I didn't know it was possible to screw up.
as i said - i thought when i put t on that it looked odd, but I didn't see the mistake.
so the lesson is that if you think something looks weird and can't figure out why.., keep looking.
Likes For jgf310:
Quoted: 443 Post(s)
Liked 474 Times
Glad it got worked out. The only thing I would have contributed was that I've ran 32t cassettes with short cage derailleurs so that couldn't have been the problem.
Likes For tFUnK:
Over the hill
Quoted: 1006 Post(s)
Liked 1,226 Times
I can't figure that out either! You were nothing short of respectful to all of us, right or wrong.
And good eye from KCT1986 !
It's like riding a bicycle
Everyone who has installed their own parts has had issues of some kind or other. I’ve done a number of boneheaded things in my time, and, according to my wife, will probably do many more.
Quoted: 2544 Post(s)
Liked 3,025 Times
who did i blame...?
It's a normal road cassette, the same as Ultegra 11-32, and on 12s 11-34 ....
105/Ultegra rear mech with medium cage works well with 11-32 cassette as well, just avoid maximum cross chain (Di2 will block it for you - small/small - so no full slack situation and risk of dropped chain, however big/big is allowed (as an emergency I guess, or if you miss gears) )
(MTBs cassettes are from 42 up now )
Over the hill
Liked 1,226 Times
The OP was the one that f'ed up by installing it wrong... If they don't like the suggestions that might fix their f-up, they can just bring their bike to a LBS, which is encouraged and not bad advice.
ignominious poltroon
Quoted: 2275 Post(s)
Liked 3,499 Times
I've gotten that derailleur to tolerate an 11-36T cassette, with the B-screw screwed in almost all the way.
The Big-Big chainring combination is best avoided. Ideally, you want to be able to shift into it so that if you do it by accident, it won't rip your drivetrain apart.
My wife seems to have a perverse need to ride in that combo. But normal people don't need to, since the gear ratio can be replicated elsewhere.
Hers is a Di2 system. Interestingly, it doesn't prevent the big/big combo by default, but it does prevent the user from shifting into the small/small combo, presumably to avoid slack.
Here is the best way to size the chain: https://bettershifting.com/installat...and-direction/
