#3826
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,183 Times
[QUOTE=Nemosengineer;21824522]Here you go.
20201208_170542 by nemosengineer, on Flickr
Mike,
It's been said before but the color scheme on this bike is super!
Best, Ben
Mike,
Best, Ben
Voltaire
Voltaire
Likes For xiaoman1:
#3827
Likes For Kdogbikes:
#3828
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
1978 Raleigh Super Course
#3829
Zip tie Karen
Liked 1,542 Times
I have Chinese reproduction headbadge coming...
#3830
Zip tie Karen
Liked 1,542 Times
Wheelset and derailleurs are SunTour Sprint. I had a set of SR Apex rings in 52/40 plus SR bolts. Used the original spider and crank arms, bottom bracket bearing. The Modolo levers and SunTour barcons were salvaged from a 1980s Peugeot that got donated. I hdd to grind and paint the lower headset race (silver) because I failed to unstick the stem. Not so shabby compared to the abused frame's condition when I received it.. Note the headtube lining...
Cable housings will be gold as will the chain. Bar tape black. Tires black (28mm). Saddle a Wrights narrow from the period. Ugh...what a project. Most of the parts were on-hand, so I bought the mistreated frame.
#3831
Overdoing projects
Quoted: 784 Post(s)
Liked 1,266 Times
Trying and failing to build a front wheel.
I'm going to have to take everything apart and measure again to see if I missed something.
I should have plenty of room with 3-cross and 278mm spokes on this rim but in 3-cross I cannot for the life of me connect the 3rd lacing and only 2-cross seems to work but has too long a spoke of course.
The twisting of the hub after the first two sides doesn't connect cleanly either so no idea what's going on here.
It's almost like this hub is weird, or a couple of different sized spokes snuck in here.
2-cross build with spokes being too long
#3832
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
https://billmouldwheels.com/product/...el-building-2/
Hang in there, brother. You'll get it.
Likes For J.Higgins:
#3833
Overdoing projects
Quoted: 784 Post(s)
Liked 1,266 Times
Sometimes its a matter of process. The following video is good for that.
The wheel is almost finished. I just need to pop by a bikeshop tomorrow and buy two spokes in the correct length. There are some weird tensions going on right now but I will figure things out in daylight.
One other source I came across today that I really liked is this one: Troubleshooters.com
A bit more detail than our venerable Sheldon Brown.
Likes For JaccoW:
#3834
Not a great picture but I have been building up this Zeus Competition that I bought over the summer. The frame is 531 main tubes and I think the rest is Durifort tubing. My plan is to outfit it with Zeus Criterium components and Zeus Super Alfa brakes. I think its around a 1972 or 73 bike. This is the second Zeus I have had but the first one in my size.
Likes For Realsteel95:
#3835
Liked 2,183 Times
Curious about the cleaning, when you used the polish, did it remove the anodizing....I like the matt finish on some of my parts and don't want it removed.
Thanks, Ben
Voltaire
Voltaire
#3836
Quoted: 2338 Post(s)
Liked 5,123 Times
Today has been a little bit of everything for me. Cut about 2 inches off my son's Mountain Bike Seat tube for him. That'll keep him happy until he can afford a true dropper seatpost. I also sorted out some wheel issues with the Lecoulant bike. Re-centerd the axle on an old set of Superbe hubbed tubulars that will be going on my Opus II eventually also.
And then I fought some more with the Stella. Got the right crank puller in for the Stronglight crank but found jacked up threads on the driveside so unable to pull that yet. Need to sort it out somehow. Cleaned up all the parts I could get off and did some more polishing of others. Oh and I got a better fitting toothed spacer for the headset on it. Just had to file away on the flat keyed portion of the spacer to get it to fit on the steere. No flat spot on this steerer.
I've got the Ochsner staring at me right now. Figuring on pulling the Shimano 600 7 speed DT setup for a Dura Ace 7400 8 speed STI setup. Not sure if I'm going to start that project this evening or not.
Steel is real...and comfy.
Likes For jamesdak:
#3837
Overdoing projects
Quoted: 784 Post(s)
Liked 1,266 Times
#3838
Quoted: 7370 Post(s)
Liked 2,516 Times
@JaccoW, it's beautiful. Check the alignments on the dynamo and headlight.
#3839
Overdoing projects
Quoted: 784 Post(s)
Liked 1,266 Times
The headlight is definitely something I will check out once I wire up everything to the rear. Not sure whether I will keep the sidewall dynamo on. It's no longer connected to anything but does fit the looks of the bike.
#3840
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 521 Post(s)
Liked 434 Times
ghost in the machine
been chasing a noise- clicking/creaking/annoying- for about a week.
thought it was just a dirty chain, but after replacing the chain, cleaning the drive train and pulleys, replacing the cassette and changing rear wheels, I think I got grit in the free hub.
i was hoping for a cracked frame so I could get a new XOXO from Handsome Cycles. But no joy. Pretty sure it’s a noisy hub.
next project is to disassemble the Velocity hub
or figure out how to.....
#3841
Bikes: 2013 Wilier Gran Turismo, 1983 Trek 760, 80's Colnago Super, 90's De Rosa SLX, 2009 Waterford 22 Series Singlespeed, 85 Medici Pro Strada, De Rosa Alumino frameset, Dave Molten Fuso frameset, 70's beater Peugeot PX10, Zizzo Liberte, 2022 Yoeleo R12
Quoted: 122 Post(s)
Liked 200 Times
I'm a novice when it comes to polishing. I'm only cleaning off dried grease (softening it up with WD40, alcohol or lighter fluid), then using jewelers files to deburr any rough spots, then gently hand polishing the anodized parts with Mother's polishing compound. I'm not using steel wool or rubbing too hard so the anodized finish is not harmed. In the future I plan on removing the anodized finish on some parts and machine polish them to a high gloss finish, but for now I'm just doing a major cleanup and am not too aggressive in polishing anodized parts.
#3842
Liked 2,183 Times
Best, Ben
Voltaire
Voltaire
#3843
Zip tie Karen
Liked 1,542 Times
Wrenching on a ... wrench?
4th Gen Craftsman 3/8" ratchet.
We find so many ratchet handles on the road. How many go to the trouble to get the rebuild kit? I do for Snap-On wrenches, for sure. This one deserved some love...
Likes For Phil_gretz:
#3844
Quoted: 4533 Post(s)
Liked 6,440 Times
Normally bulletproof for regular constant use, great fit, great lever placement for switching on the fly, all good imo.
I have 2 or 3 that are at least 30+ years old, they are the ones my hand goes to when I reach for a ratchet of which I have at least a dozen 3/8 standards like them.
Likes For merziac:
#3845
Liked 2,183 Times
Honey do list.....asked the wife to make sure the power was off and .......got a slight tingle, and not the good one!
But some of the exterior outlets are now done.
Tickled red!
Almost Fried, Ben
Tickled red!
Almost Fried, Ben
Voltaire
Voltaire
Likes For xiaoman1:
#3846
Bikes: Teledyne Titan, Bob Jackson Audax Club, Bob Jackson World Tour, AlAn Record Ergal, 3Rensho Katana.
Quoted: 215 Post(s)
Liked 623 Times
: Mike
Booyah Hubba-Hubba!!!
#3847
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3915 Post(s)
Liked 6,527 Times
#3848
Liked 2,183 Times
From a man that has a serious complement of tools, expertise and a bike with some of the nicest details, I'll take that as a compliment.
Best, Ben
Voltaire
Voltaire
#3850
Got my old mountain bike back on the road, next in line is a disc brake upgrade that I've put off for years. With the disc brake swap I will also change over to tubeless.
Likes For rogerm3d:
