Mounting Bottle brackets
Bikes: 1968 Raleigh Super Course, 1972 Raleigh Professional, 1975 Raleigh International, 1978 Raleigh Professional, 1985 Raleigh Prestige, 1972 Schwinn Paramount, 1980 Schwinn Voyageur 11.8, 1960 Carlton Franco Suisse Peugeot PX10, 1972 Motobecane Le Champ
Quoted: 323 Post(s)
Liked 690 Times
Likes For Pcampeau:
Likes For BertoBerg:
Bikes: BMC Road V2; '17 Marin Pine Mountain 2; '91 Marinoni Special TSX; '89 Specialized Stumpjumper Comp; '98 Salsa La Cruz; '79 Centurion Pro Tour; '77 Romic custom sport-tour; '77 Centurion Semi-Pro; '23 Kona Sutra LTD
Quoted: 62 Post(s)
Liked 220 Times
How about these https://kingcage.com/en-ca/collectio...l-support-bolt
Bikes: Yes
Quoted: 3235 Post(s)
Liked 3,883 Times
I got a pair of these on an old Stella I bought earlier this year (yes, the one that became the Smella).
I have no idea what they are. I tried them out on my Raleigh Professional tonight. They don't hold the cage as tight as they should. They've probably work well with more of a shim.
My Bikes
My Bikes
Quoted: 323 Post(s)
Liked 690 Times
Likes For Pcampeau:
Bianchi Goddess
Quoted: 2945 Post(s)
Liked 2,956 Times
Have you considered handle bar mounts? I actually have much better pics but can't find them.
This is a Minoura cage mount that use two U bolts to attach to the bars and I put a double bottle attachment I got of the amazon. For some reason my '90 Bianchi Proto only came with one set. For a few years I a set of nylong Zefla band type mount but it left marks on the paint. This set up allows to carry two bottle or if I want a bottle and this GU can with my spare tube and levers
Sugar "Kane" Kowalczyk
Quoted: 62 Post(s)
Liked 263 Times
5mm rivnuts. Purist might not like drilling their frames to install them, but you can install them anywhere as bottle bosses and rack mounting points. Installing them doesn’t damage surrounding paint (other than the hole you drill for them). Metal clamps can also do a number on the paint, but I have to admit they maintain a vintage look as a vintage solution to a vintage problem.
The only place I haven’t been able to use rivnuts is on the skinny top tubes on my mixte tandem. In that case I used the bottle cage mounts that came with cheapo Bell water bottle/cage combos sold in department stores. They have a Velcro strap mounting system (like the ones used to hold mini pumps in their bottle-cage mounts) that I can wrap around both of the top tubes. The bottle cage mounting holes are standard so you can attach your favorite cage to them.
