Wacky 48/38/18 crankset on vintage touring bike???
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
On my bikepacking bike, I have a slightly lower gear due to the 26” wheels but I would like something even lower. While we don’t usually put large grades on paved roads here in Colorado, the gloves come off when it comes to dirt. When that attack chihuahua becomes an attack Great Dane by the combination of steep roads and high altitude, there’s almost no gear that is low enough. I’m not sure there is a gear that will allow me to ride a 25% grade at about an inch below 12,000 feet
Untitled by Stuart Black, on Flickr
The sky is so blue because that’s just the darkness of space.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 1034 Post(s)
Liked 1,292 Times
Hey now! The driftless region in Eastern Iowa is no joke for hills, especially in my neck of the woods with the steep river bluffs of the Mississippi River. It's hard to find a 50 mile road ride that won't net you 3,000-4,000 feet of elevation, and pretty easy to find 100 ft per mile if that's what you're looking for. The rolling hills are steep and relentless. I am no slouch up an incline, the low gear on my touring/commuter is a 24 /32, and does get used from time to time!
I live in Wester PA now, where there are nothing but hills, but never discount Iowa for hills.
Likes For phughes:
I have lived in Iowa in Iowa for 15 years and lived in nine other states before Iowa. Florida was the flattest. For about half of my 15 years in Iowa I did a lot of work with elected officials. One of them quite seriously told me he felt Iowa is too hilly to be able to make use of cruise control in a car. I thought that was hilarious, odd, and not true as there are long flat stretches of highway in Iowa where cruise control is handy, but yes there are areas with quite a lot of challenging climbs. I discovered this while riding several RAGBRAIs (but I haven’t been able to ride one since 2014 due to work and family demands).
Likes For RoLo50312:
I do not see how you can get a 3-4000 ft ELEVATION change in a state with its highest point of less than 1700 ft. Don't get me wrong, you might CLIMB that much on a ride, though I'd have to see it to believe it, but I don't see how that much elevation is possible.
Quoted: 18424 Post(s)
Liked 15,582 Times
+2. When riding across the country unsupported we went into Iowa from the Browning, MN, area. Had some nasty grades in the state, and I don’t think we were in the worst part. Ended up in Davenport then crossed into IL. I was glad I had my 22t ring, especially when it was 100 degrees with no shade.
Likes For indyfabz:
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
If you're ever in northeastern iowa i will take you on a gravel century ride with some serious climbs......either bring your granny gears or your walking shoes!
Liked 4,222 Times
If you go down in a hole, you have to climb out of it. It adds up.
Stuart Black
Stuart Black
If you go down a hole, then climb back out, your elevation did not change. Your elevation refers to height above sea level. If you climb a total of 4000 feet, and descended a total of 4000 feet, your elevation did not change.
Liked 4,222 Times
I did a ride recently from my house up to a place called Rocky Flats. I climb 2027 feet to the top of the ride and then came home. By your measure, I had no elevation change because I returned to my starting point. My GPS actually says that I went up 2027 feet and came down 1925 feet which means I ended up 100 feet over my house.
We count the uphill bits because we have to put energy into riding up a hill. The downhill bits are freebies for putting the energy into climbing that hill.
Stuart Black
Stuart Black
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
I'd rather have this gearing setup than a compact double-chainring crank.
Quoted: 1324 Post(s)
Liked 927 Times
Cheers
