Pick between 1x (40T) or 2x (46/30)?
Bikes: Kona Kahuna DL Drop Bar - Sensah SRX Pro 1x11 (2012 Frame), Giant Toughroad GX 1 - Shimano Road Hydro + SLX 1x10 (2018), Diamondback Sync'r - SRAM NX 1x12 (2020)
Quoted: 160 Post(s)
Liked 97 Times
I've gone 1x on all my bikes but the reasoning for me made sense. Before I was running 2x9 on the road with a 46-30 front ring and a 12-36 cassette. I knew I wasn't strong enough to push a 46-11 at the time and the 30-36 was enough of a bailout gear to keep me moving along if I needed it. I realized the jumps in the 9 speed cassette were fine to the point where I didn't feel like I needed the smaller jumps between gears with a similar 11 speed cassette.
My experience with the 9 speed setup really influenced my decision to go 1x, so now I'm running a 42 front with 11-46 11 speed cassette. It does the job for my type of riding which is just mostly urban, and I get the minor benefit of slightly more tire clearance.
If there's any point I want to make here it's know what you want to ride, where you want to ride, and what you *personally* need to make that ride as smooth as possible. Also if you find out something isn't working out well for you, don't be afraid to change things up!
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
Agreed that it just depends on your needs. For the riding/racing I do around here, I would never go 1x, too much fast pavement tying gravel sections together. My 48/32 11-34 setup works perfectly for what I need.
With a mighty wind
Quoted: 1091 Post(s)
Liked 879 Times
Mine is probably considered a monster cross or whatever. More aggro than a typical race bike.
I run 40 x 11-42 on a 10 speed setup. I've got the low gear I need. In fact, 90% of the time, I run my other cassette, 11-36.
The high end is a bit lacking and the gaps between gears screws up spinning.
I think with 12 speeds and 10-36, you could race on that. I don't know if that exists.
I've got a couple actual road bikes, all with doubles and I would never consider 1x for pavement.
1x seems a lot nicer for knocking around and getting messy. I don't know about racing on it though. Some people do though.
