Touring workups
Quoted: 3483 Post(s)
Liked 1,481 Times
One thing no one ever mentions? If you don't have a phone stuck on your handlebars giving you turn by turn routes, practice navigation. It is one thing to ride a bike up and down a route or area you know, it is completely different doing it on a paper map in an area you are unfamiliar with. Out of everything I thought I prepared for on my first big tour, that was the one that screwed me over that I had never really considered.
GPS navigation has become the norm for bicycle touring, but I always have the paper maps for bigger area planning purposes.
Currently workups include doing evening laps around the neighborhood block with a baseline load. I've been hearing a noises, I believe in the rear wheel and mybe teh from also.* It's my first bike with disc (mechanical), I'm going to have to learn how to service them. I'm assuming that the rear load does not effect disk's true. While, I'm wondering how much the rear load effects the wheel's / rim's true. I'll need to check spoke tension, and quick release tension. So the workups continue.
* Intermittent, but isolated once during a right turn at speed, that was persistent without peddling and stopped when I sharply engaged the rear brakes momentarily. I can periodically induce the noise when I do big slalom turns while goofing off.
Liked 1,481 Times
It is very possible that one of your hiking GPS units will serve well as a bike GPS. I have used a variety of general recreational GPS units on a bike over the years. Many Garmin general recreation GPS units have a handlebar bracket available, but a few it appears the bracket was an afterthought. I am currently using a Garmin 64 on my bike. Since I also use those same GPS units for backpacking, canoeing, kayaking, etc., I want a GPS that uses AA batteries.
Quoted: 1866 Post(s)
Liked 665 Times
Brooks dressing (Proofide) is a piece of cake. You can do the first coat when it's new. Get some smeared on your fingers and smear it all over the outside of the saddle. You ONLY want a THIN coating. Let it soak in and then go for a ride. If you can set it in the sun for a few minutes, that will help it absorb. They say wipe off any excess - I think that is worthwhile. The saddle should have a leathery aroma, the surfce should look more porous, and if you push the leather with your thumb near the rear cleat it might show a teeny bit more give, but I would not count on any of that.
Don't turn the screw in front at this point. I don't actually know when you should turn it, I think my vote is for "never". I tested this several decades ago and I was not happy with the tightened saddle skin.
Proofide is just for helping the leather become and stay flexible. It is NOT a waterproofer nor an accelerator to break in. Breaking the saddle in, as much as it may be destined for your butt, is accomplished by riding, not by smearing. Protecting it from water, as much as it may or may not be needed, is accomplished with a Brooks "shower cap" or a "saddle gaitor (do they call it that?).
