Is Rain Bad For Your Bike?
Quoted: 2112 Post(s)
Liked 663 Times
Rain and leaves are bad for you.
Rain and thermoplastic are bad for you.
Rain and your bike?
Wash it.
(If you don’t have access to outdoor water, a five liter hand pumped pressure bottle works great, plus you can fill it with warm water, which is nice.)
Clean the frame and wipe down the drivetrain and brakes and rims (if applicable) and let dry.
After it dries, use your favorite material for lubricating your drivetrain. (Lubricating material is the third rail of bike forums, don’t even....)
Don’t lubricate your brakes, except pivot points (if applicable).
-mr. bill
Rain and your bike?
Wash it.
-mr. bill
Likes For mr_bill:
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times
Rain is fine for your bike, but like others have noted, it's the grit from the road that can get on your drive train and wear it down. Ideally you should give the bike a hose-down after a wet ride, but I don't generally due to an issue of laziness. Slush and salt, on the other hand, is bad for your bike. But you might have guess that already. I try to hose down after a slushy ride.
Fenders are NOT over-rated. You can't prevent getting wet from the rain coming down, but the fenders will keep you from getting sprayed from the crap underneath. They will keep you feet dryer for longer when riding in the wet. Long front fenders will protect your bottom bracket from the road spray. My MK2's and 3's have an overlapping flange to protect the FD as well.
Best of all, fenders keep your backside dry. That alone is worth it!
Likes For mcours2006:
Perhaps you could gain some perspective by trying to wash chain lube off your hands with cold water, no soap.
Water left on steel, rust will ensue.
Salt and grit, definitely bad for bikes.
You did treat the inside of your steel frame tubes with some sort of rust preventative, didn't you?
Likes For Pratt:
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
I Use A Rain Cape, Which, When Used With Sufficient Fenders, Does A Lot To Keep Rain Off The Bicycle (As Well As Off The Rider) In The First Place. I Use A Rain Cape Without A Hood, As Hoods Aren't Compatible With Eyeshield-Mounted Mirror. But Also With Relevance, As Others Have Said, Wetness Isn't Too Bad For The Bicycle, Just Wipe It Down After You Get It Back Under Cover.
Likes For Nyah:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,648 Times
Commuted for in the rain years wearing a simple poncho draped over the drops to keep my legs dry, with full fenders front and rear. Would always keep the chain and gears clean and oiled with zero problems. No bikes were hurt riding in the rain.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Likes For Flip Flop Rider:
Quoted: 365 Post(s)
Liked 419 Times
Trying to see how this makes your bike wetter ... still trying ... still trying ,.. still trying ... aaannnddd ... nada.
Likes For noimagination:
Rain? Ride and wash. Wipe down the chain and re-lube.
Also, full fenders rock. Sometimes I leave them on when it's dry so I can ride through water puddles without consequence.
Likes For commo_soulja:
meh
Quoted: 1111 Post(s)
Liked 1,013 Times
To the OP, the only reason I don't ride a bike in the rain is that it's clean and I don't want to make it a mess. I have 6 bikes, 2 with full fenders, and these two are the first choice on a rainy ride (see above). Otherwise, all of my bike end up riding in the rain from time to time. I store all my bikes in the house, after a rainy ride, they go to the basement storage space to drip off; before the next ride add lube to the chain and off we go.
For reference, here's the conditions on a 100-mile gravel race I did back in 2018 ... we did have some dry times, but we also had heavier rain ... so heavy that traffic on a highway stopped! With some general maintenance and drivetrain cleaning, I turned around and used the same bike for The DAMn a two months later. So no real damage done riding in the rain.
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times
Trying to wrap my head around this, and failing. How would fenders make your bike wetter? There is the same amount of rain coming down, regardless of whether or not you have fenders. There is the same amount of road spray kicked up by your tires, regardless of whether or not you have fenders. The road spay from your tires, instead of spraying on your down tube, bottom bracket, feet, back brake, back, etc. gets sprayed on the inside of the fender and drips down to the ground.
Quoted: 268 Post(s)
Liked 80 Times
Full fenders are the most important accessory I ever put on my bikes. It has nothing to do with protecting my bikes from rain, but it's about protecting my clothing and backpack from dirty road spray, especially salty road spray during winter time and muddy road spray when riding gravel.
Quoted: 2952 Post(s)
Liked 3,106 Times
Suboptimal.
Likes For caloso:
meh
Liked 1,013 Times
Full-fenders, like on my commuter set up, end up with most water running off the leading or trailing ends of the fender, which in 3 of 4 places is directing the water at the ground and below the bikes key components.
Frankly stated, if your riding in the rain, you want some kind of fender to protect your back from the rear tires spray.
Likes For Hypno Toad:
Quoted: 365 Post(s)
Liked 419 Times
Fenders are, admittedly, not magic, and they don't keep your bike completely dry. But wetter? Not a chance.
